I successfully installed NVidia Graphics Drivers - NVIDIA-Linux-x86_64-390.87.run
Then I tried installing CUDA Toolkit from - cuda-repo-rhel7-9-2-local-9.2.148-1.x86_64.rpm
Most of the install went well, but I got the following errors -WARNING: Your driver installation has been altered since it was initially
installed; this may happen, for example, if you have since
installed the NVIDIA driver through a mechanism other than
nvidia-installer (such as your distribution’s native package
management system). nvidia-installer will attempt to uninstall as
best it can. Please see the file ‘/var/log/nvidia-uninstall.log’
for details.
Installing : 1:xorg-x11-drv-nvidia-396.37-1.el7.x86_64 31/70
Error unpacking rpm package 1:xorg-x11-drv-nvidia-396.37-1.el7.x86_64
error: unpacking of archive failed on file /etc/vulkan/icd.d/nvidia_icd.json;5b87486f: cpio: rename
Installing : libICE-devel-1.0.9-9.el7.x86_64 32/70
error: xorg-x11-drv-nvidia-1:396.37-1.el7.x86_64: install failed
Installing : libSM-devel-1.2.2-2.el7.x86_64 33/70
Installing : libXt-devel-1.1.5-3.el7.x86_64 34/70
Installing : libXmu-devel-1.1.2-2.el7.x86_64
Towards the end I noticed -
Verifying : 1:xorg-x11-drv-nvidia-396.37-1.el7.x86_64
Dependency Installed:
…xorg-x11-drv-nvidia-gl.x86_64 1:396.37-1.el7
However at the ver last line -
Failed:
xorg-x11-drv-nvidia.x86_64 1:396.37-1.el7
Complete!
I am not sure how to interpret this. Did the xorg-x11-drv-nvidia get installed or not. If not how do I fix this??
Please advise…
Thanks,
Raj
