It seems that it is not possible to independently run kernels on a multi-GPU system in parallel from a single process, with multiple threads. When using multiple processes to do so, it works fine. Note that this issue manifests at random times. Sometimes I need to run the program a couple times before it starts. When it does start, the issue does not go away (even though the amount to which it affects runtime varies).
I originally reported the issue here: TensorRT unnecessary synchronization in multi-GPU system. But it seems it is not TensorRT-specific.
Environment
TensorRT Version: 8.5.2.2
GPU Type: 10x RTX A4000
Nvidia Driver Version: 525.60
CUDA Version: 11.8
CUDNN Version: 8.7.0
Operating System + Version: Ubuntu 22.04.1 LTS
Baremetal or Container (if container which image + tag): Baremetal
System
CPU:
Info: 2x 20-core model: Intel Xeon Silver 4316 bits: 64 type: MT MCP SMP cache:
L2: 2x 25 MiB (50 MiB)
Speed (MHz): avg: 916 min/max: 800/3400 cores: 1: 801 2: 801 3: 800 4: 800 5: 800 6: 800
7: 801 8: 801 9: 801 10: 801 11: 800 12: 801 13: 800 14: 801 15: 801 16: 800 17: 801 18: 801
19: 800 20: 801 21: 801 22: 800 23: 801 24: 801 25: 800 26: 801 27: 801 28: 801 29: 2302
30: 801 31: 801 32: 1890 33: 801 34: 801 35: 1085 36: 1403 37: 801 38: 1413 39: 1243 40: 801
41: 800 42: 801 43: 801 44: 801 45: 801 46: 801 47: 801 48: 801 49: 801 50: 1648 51: 800
52: 800 53: 800 54: 2301 55: 800 56: 800 57: 801 58: 801 59: 801 60: 801 61: 801 62: 801
63: 801 64: 802 65: 800 66: 801 67: 801 68: 801 69: 1416 70: 801 71: 801 72: 1758 73: 800
74: 800 75: 846 76: 801 77: 801 78: 1440 79: 897 80: 801
Graphics:
Device-1: ASPEED Graphics Family driver: ast v: kernel
Device-2: NVIDIA GA104GL [RTX A4000] driver: nvidia v: 525.60.11
Device-3: NVIDIA GA104GL [RTX A4000] driver: nvidia v: 525.60.11
Device-4: NVIDIA GA104GL [RTX A4000] driver: nvidia v: 525.60.11
Device-5: NVIDIA GA104GL [RTX A4000] driver: nvidia v: 525.60.11
Device-6: NVIDIA GA104GL [RTX A4000] driver: nvidia v: 525.60.11
Device-7: NVIDIA GA104GL [RTX A4000] driver: nvidia v: 525.60.11
Device-8: NVIDIA GA104GL [RTX A4000] driver: nvidia v: 525.60.11
Device-9: NVIDIA GA104GL [RTX A4000] driver: nvidia v: 525.60.11
Device-10: NVIDIA GA104GL [RTX A4000] driver: nvidia v: 525.60.11
Device-11: NVIDIA GA104GL [RTX A4000] driver: nvidia v: 525.60.11
Display: server: No display server data found. Headless machine? tty: 238x51
MRE
I modified the matrixMul sample in the CUDA samples. See code attached. The modified version runs one worker (in a thread) per GPU and then concurrently executes kernels from them.
Single-GPU
This runs a single worker thread, on a single GPU (to establish baseline):
CUDA_VISIBLE_DEVICES=0 ./matrixMul
[Matrix Multiply Using CUDA] - Starting...
GPU Device 0: "Ampere" with compute capability 8.6
MatrixA(320,320), MatrixB(640,320)
Computing result using CUDA Kernel...
done
LAUNCH!
Performance= 1445.88 GFlop/s, Time= 0.091 msec, Size= 131072000 Ops, WorkgroupSize= 1024 threads/block
Checking computed result for correctness: Result = PASS
NOTE: The CUDA Samples are not meant for performance measurements. Results may vary when GPU Boost is enabled.
DONE
Runtime around 0.091 msec
Multi-threaded, multi-GPU
This one runs one worker per GPU, running the kernel 10k iterations as fast as possible. Even though the GPUs should operate independently, there seems to be synchronization as the average runtime drops by about 4x:
./matrixMul
done
done
done
done
done
done
done
done
done
done
LAUNCH!
Performance= 413.12 GFlop/s, Time= 0.317 msec, Size= 131072000 Ops, WorkgroupSize= 1024 threads/block
Performance= 408.03 GFlop/s, Time= 0.321 msec, Size= 131072000 Ops, WorkgroupSize= 1024 threads/block
Performance= 398.93 GFlop/s, Time= 0.329 msec, Size= 131072000 Ops, WorkgroupSize= 1024 threads/block
Performance= 391.88 GFlop/s, Time= 0.334 msec, Size= 131072000 Ops, WorkgroupSize= 1024 threads/block
Performance= 393.24 GFlop/s, Time= 0.333 msec, Size= 131072000 Ops, WorkgroupSize= 1024 threads/block
Performance= 389.40 GFlop/s, Time= 0.337 msec, Size= 131072000 Ops, WorkgroupSize= 1024 threads/block
Checking computed result for correctness: Performance= 392.55 GFlop/s, Time= 0.334 msec, Size= 131072000 Ops, WorkgroupSize= 1024 threads/block
Result = PASS
Performance= 390.90 GFlop/s, Time= 0.335 msec, Size= 131072000 Ops, WorkgroupSize= 1024 threads/block
Result = PASS
Performance= 388.16 GFlop/s, Time= 0.338 msec, Size= 131072000 Ops, WorkgroupSize= 1024 threads/block
Performance= 386.39 GFlop/s, Time= 0.339 msec, Size= 131072000 Ops, WorkgroupSize= 1024 threads/block
DONE
Runtime around 0.33 msec (4x slower)
This is what the trace looks like:
Multi-process, multi-GPU
This sample does the same thing as above, except instead of running workers in threads, it starts one process per GPU and then runs the kernel 10k iterations (parallel over processes). This works:
CUDA_VISIBLE_DEVICES=0 CUDA_MODULE_LOADING=LAZY ./matrixMul & \
CUDA_VISIBLE_DEVICES=1 CUDA_MODULE_LOADING=LAZY ./matrixMul & \
CUDA_VISIBLE_DEVICES=2 CUDA_MODULE_LOADING=LAZY ./matrixMul & \
CUDA_VISIBLE_DEVICES=3 CUDA_MODULE_LOADING=LAZY ./matrixMul & \
CUDA_VISIBLE_DEVICES=4 CUDA_MODULE_LOADING=LAZY ./matrixMul & \
CUDA_VISIBLE_DEVICES=5 CUDA_MODULE_LOADING=LAZY ./matrixMul & \
CUDA_VISIBLE_DEVICES=6 CUDA_MODULE_LOADING=LAZY ./matrixMul & \
CUDA_VISIBLE_DEVICES=7 CUDA_MODULE_LOADING=LAZY ./matrixMul & \
CUDA_VISIBLE_DEVICES=8 CUDA_MODULE_LOADING=LAZY ./matrixMul & \
CUDA_VISIBLE_DEVICES=9 CUDA_MODULE_LOADING=LAZY ./matrixMul
done
done
done
done
done
done
done
done
done
done
LAUNCH!
LAUNCH!
LAUNCH!
LAUNCH!
LAUNCH!
LAUNCH!
LAUNCH!
LAUNCH!
LAUNCH!
LAUNCH!
Performance= 1447.73 GFlop/s, Time= 0.091 msec, Size= 131072000 Ops, WorkgroupSize= 1024 threads/block
DONE
Performance= 1432.36 GFlop/s, Time= 0.092 msec, Size= 131072000 Ops, WorkgroupSize= 1024 threads/block
DONE
Performance= 1450.05 GFlop/s, Time= 0.090 msec, Size= 131072000 Ops, WorkgroupSize= 1024 threads/block
DONE
Performance= 1469.87 GFlop/s, Time= 0.089 msec, Size= 131072000 Ops, WorkgroupSize= 1024 threads/block
DONE
Performance= 1456.77 GFlop/s, Time= 0.090 msec, Size= 131072000 Ops, WorkgroupSize= 1024 threads/block
DONE
Performance= 1462.62 GFlop/s, Time= 0.090 msec, Size= 131072000 Ops, WorkgroupSize= 1024 threads/block
DONE
Performance= 1426.73 GFlop/s, Time= 0.092 msec, Size= 131072000 Ops, WorkgroupSize= 1024 threads/block
DONE
Performance= 1436.94 GFlop/s, Time= 0.091 msec, Size= 131072000 Ops, WorkgroupSize= 1024 threads/block
Performance= 1427.04 GFlop/s, Time= 0.092 msec, Size= 131072000 Ops, WorkgroupSize= 1024 threads/block
DONE
DONE
Performance= 1443.78 GFlop/s, Time= 0.091 msec, Size= 131072000 Ops, WorkgroupSize= 1024 threads/block
DONE
Runtime around 0.09 msec (same as sequential, so fastest possible)
The trace:
Resources
- matrixMul.cu (modified version) (12.2 KB)
