I have developed an application which has this problem (the topic title).
At first I thought it was a problem of my application but then I tried creating a standard CUDA
project with Parallel NSight 2.1 (the one which adds 5 integers in parallel) and added a loop
of 100000000 times to repeat c[i] = a[i] + b[i]; and it gives me the same problem.
If I repeat the loop only 10000 times (for example) it works perfectly.
Here is what happens:
Everything works fine, even the kernel function call, but as soon as cudaDeviceSynchronize is called,
a black screen appears for some seconds, then the video comes back and windows notifies me with
“Display driver stopped responding and has recovered!”.
The cudaDeviceSynchronize function returns with the “cudaErrorLaunchTimeout” error;
I tried this Parallel NSight app both on my laptop and on my computer and they both have this behavior.
Here is the code (it’s the same as the standard Parallel NSight project) plus one line of code:
#include “cuda_runtime.h”
#include “device_launch_parameters.h”
#include <stdio.h>
cudaError_t addWithCuda(int *c, const int *a, const int *b, size_t size);
global void addKernel(int *c, const int *a, const int *b)
int i = threadIdx.x;
for(int k = 0; k < 100000000; k++) /* the only new line of code */
c[i] = a[i] + b[i];
int main()
const int arraySize = 5;
const int a[arraySize] = { 1, 2, 3, 4, 5 };
const int b[arraySize] = { 10, 20, 30, 40, 50 };
int c[arraySize] = { 0 };
// Add vectors in parallel.
cudaError_t cudaStatus = addWithCuda(c, a, b, arraySize);
if (cudaStatus != cudaSuccess) {
fprintf(stderr, "addWithCuda failed!");
return 1;
printf("{1,2,3,4,5} + {10,20,30,40,50} = {%d,%d,%d,%d,%d}\n",
c[0], c[1], c[2], c[3], c[4]);
// cudaDeviceReset must be called before exiting in order for profiling and
// tracing tools such as Parallel Nsight and Visual Profiler to show complete traces.
cudaStatus = cudaDeviceReset();
fprintf(stderr, "cudaDeviceReset failed!");
return 1;
return 0;
// Helper function for using CUDA to add vectors in parallel.
int *dev_a = 0;
int *dev_b = 0;
int *dev_c = 0;
cudaError_t cudaStatus;
// Choose which GPU to run on, change this on a multi-GPU system.
cudaStatus = cudaSetDevice(0);
fprintf(stderr, "cudaSetDevice failed! Do you have a CUDA-capable GPU installed?");
goto Error;
// Allocate GPU buffers for three vectors (two input, one output) .
cudaStatus = cudaMalloc((void**)&dev_c, size * sizeof(int));
fprintf(stderr, "cudaMalloc failed!");
goto Error;
cudaStatus = cudaMalloc((void**)&dev_a, size * sizeof(int));
goto Error;
cudaStatus = cudaMalloc((void**)&dev_b, size * sizeof(int));
goto Error;
// Copy input vectors from host memory to GPU buffers.
cudaStatus = cudaMemcpy(dev_a, a, size * sizeof(int), cudaMemcpyHostToDevice);
fprintf(stderr, "cudaMemcpy failed!");
goto Error;
cudaStatus = cudaMemcpy(dev_b, b, size * sizeof(int), cudaMemcpyHostToDevice);
goto Error;
// Launch a kernel on the GPU with one thread for each element.
addKernel<<<1, size>>>(dev_c, dev_a, dev_b);
// cudaDeviceSynchronize waits for the kernel to finish, and returns
// any errors encountered during the launch.
cudaStatus = cudaDeviceSynchronize();
fprintf(stderr, "cudaDeviceSynchronize returned error code %d after launching addKernel!\n", cudaStatus);
goto Error;
// Copy output vector from GPU buffer to host memory.
cudaStatus = cudaMemcpy(c, dev_c, size * sizeof(int), cudaMemcpyDeviceToHost);
goto Error;
Error:
cudaFree(dev_c);
cudaFree(dev_a);
cudaFree(dev_b);
return cudaStatus;
