cudaError documentation?
I’ve been looking throught the programming guide and around the forums, and I haven’t found any sort of list that goes through the where and why of cudaErrors. Is there such a list, official or unofficial?
Specifically, I am wondering about “unspecified launch failures.” I’m guessing it’s a bit of a catch-all error, but I understand that it tends to indicate certain common problems (e.g. getting caught by the Windows watchdog or trying to read/write outside of the allocated memory). Are there any other common (or not so common) mistakes known to fall under this blanket error?
Thanks,
Andrew
AFAIK the watchdog will give you a timeout error. The only thing I have seen causing “unspecified launch failures” have been segmentation faults in the kernel.
Whoops. Yes, you’re right. Actually, I’ve had a very interesting problem with my code where I was getting an unspecified launch failure without apparently causing a segmentation fault. On closer inspection, I found that my pointers are getting garbled, which explains that (and is easily fixed). However, that isn’t the real problem, it seems; I might post more about it in a different place, as it doesn’t seem to be related.
I’m still interested in a compendium of errors, though, if anyone has it.
