cudaGetTextureReference sample code fails
Im developing a lib for some opengl interop stuffs. Currently i get stuck on this texture reference problem.
This is the sample code from “Cuda C Programming Guide” Pg43~44 (using low-level API)
texture<float, cudaTextureType2D,cudaReadModeElementType> texRef;
textureReference* texRefPtr;
cudaGetTextureReference(&texRefPtr, "texRef");
cudaChannelFormatDesc channelDesc;
cudaGetChannelDesc(&channelDesc, cuArray);
cudaBindTextureToArray(texRef, cuArray, &channelDesc);
The line “cudaGetTextureReference(&texRefPtr, “texRef”);” returns an error “invalid texture reference”.
I also tried the high level API:
cudaBindTextureToArray(texRef, cuArray);
Same problem.
My full test code:
texture<float, cudaTextureType2D, cudaReadModeElementType> texRef;
int main ()
	const textureReference *tref = NULL;
	checkSuccess( cudaGetTextureReference( &tref, "texRef" )  );
	pauseConsole();
	return 0;
Someone help? Im in the dire need for an answer :( thanks
PS. the sample code needs to be updated for the fact cudaGetTextureReference is expecting a const pointer. you can see ive changed my code accordingly.
