Hello.
I am wondering about cudaMalloc issue…
There is a structure and structure consists of 24 bytes (int, float, int, float, pointer).
Actually, I already asked cudaMalloc question but I didn’t understand myself… so I need some help.
This structure is used in PageRank algorithm.
Now, the structure is called vertex.
Firstly, structure is allocated number of nodes (vertices).
Secondly, succesors is allocated number of adjacency nodes (this is just pointer for approaching to adjacency nodes).
So, I understand about C language Malloc. But I don’t know how to allocate in CUDA…
I was troubled for three days… Please help me. It’s really hard…
-------------------------------- structure
struct vertex {
unsigned int vertex_id;
float pagerank;
float pagerank_next;
unsigned int n_successors;
vertex ** successors;
-------------------------------- allocation in C
vertices = (vertex *)malloc(n_vertices*sizeof(vertex));
for (i = 0; i<n_vertices; i++) {
if (vertices[i].n_successors > 0) {
vertices[i].successors = (vertex **)malloc(vertices[i].n_successors*sizeof(vertex *));
if (!vertices[i].successors) {
fprintf(stderr, "Malloc failed for successors of vertex %d.\n", i);
exit(-1);
memset((void *)vertices[i].successors, 0, (size_t)(vertices[i].n_successors * sizeof(vertex *)));
else
vertices[i].successors = NULL;
-------------------------------- befor allocation in CUDA, data memcpy
while (fscanf(fp, "%d %d", &vertex_from, &vertex_to) != EOF) {
for (i = 0; i < vertices[vertex_from].n_successors; i++) {
if (vertices[vertex_from].successors[i] == NULL) {
vertices[vertex_from].successors[i] = &vertices[vertex_to];
break;
else if (i == vertices[vertex_from].n_successors - 1) {
printf("Setting up the successor pointers of virtex %u failed", vertex_from);
return -1;
-------------------------------- allocation in CUDA
vertex ** d_testVar;
cudaMalloc(&d_testVar, vertices[i].n_successors * sizeof(vertex*));
exit(-1);
cudaMemcpy(&d_testVar, &vertices[i].successors, vertices[i].n_successors * sizeof(vertex*), cudaMemcpyHostToDevice);
cudaMemcpy(&(d_vertices[i].successors), &d_testVar, sizeof(vertex**), cudaMemcpyDeviceToDevice);
else
cudaMemcpy(&(d_vertices[i].successors), &(vertices[i].successors), sizeof(vertex**), cudaMemcpyHostToDevice);
