cudaMallocManaged() not working
I’m running the latest version of the CUDA Toolkit (10.0.130), for Windows 8.1 (x64); the latest version of MS Visual Studio 2017 (15.9.1); the latest driver (416.94), but also tried with driver version 411.31. I have a GeForce GT640M LE (Kepler) video card, with Compute Capability 3.0.
When I try to run this example from https://devblogs.nvidia.com/even-easier-introduction-cuda/:
#include <iostream>
#include <math.h>
// Kernel function to add the elements of two arrays
__global__
void add(int n, float *x, float *y)
  for (int i = 0; i < n; i++)
    y[i] = x[i] + y[i];
int main(void)
  int N = 1<<20;
  float *x, *y;
  // Allocate Unified Memory – accessible from CPU or GPU
  cudaMallocManaged(&x, N*sizeof(float));
  cudaMallocManaged(&y, N*sizeof(float));
  // initialize x and y arrays on the host
  for (int i = 0; i < N; i++) {
    x[i] = 1.0f;
    y[i] = 2.0f;
  // Run kernel on 1M elements on the GPU
  add<<<1, 1>>>(N, x, y);
  // Wait for GPU to finish before accessing on host
  cudaDeviceSynchronize();
  // Check for errors (all values should be 3.0f)
  float maxError = 0.0f;
    maxError = fmax(maxError, fabs(y[i]-3.0f));
  std::cout << "Max error: " << maxError << std::endl;
  // Free memory
  cudaFree(x);
  cudaFree(y);
  return 0;
the program freezes at the first cudaMallocManaged() call (line 17) and I get 100% CPU usage on one of my CPU cores. After two minutes, the driver is automatically reset and I get an access violation at line 22. The cudaMallocManaged() call returns an unknown error.
I sometimes manage to run the program outside Visual Studio’s debug mode once (just running the executable from the command line). But when I run the program again, I get the same issues as described above.
The sample program created automatically when creating a new CUDA project runs with no problems:
#include "cuda_runtime.h"
#include "device_launch_parameters.h"
#include <stdio.h>
cudaError_t addWithCuda(int *c, const int *a, const int *b, unsigned int size);
__global__ void addKernel(int *c, const int *a, const int *b)
    int i = threadIdx.x;
    c[i] = a[i] + b[i];
int main()
    const int arraySize = 5;
    const int a[arraySize] = { 1, 2, 3, 4, 5 };
    const int b[arraySize] = { 10, 20, 30, 40, 50 };
    int c[arraySize] = { 0 };
    // Add vectors in parallel.
    cudaError_t cudaStatus = addWithCuda(c, a, b, arraySize);
    if (cudaStatus != cudaSuccess) {
        fprintf(stderr, "addWithCuda failed!");
        return 1;
    printf("{1,2,3,4,5} + {10,20,30,40,50} = {%d,%d,%d,%d,%d}\n",
        c[0], c[1], c[2], c[3], c[4]);
    // cudaDeviceReset must be called before exiting in order for profiling and
    // tracing tools such as Nsight and Visual Profiler to show complete traces.
    cudaStatus = cudaDeviceReset();
        fprintf(stderr, "cudaDeviceReset failed!");
        return 1;
    return 0;
// Helper function for using CUDA to add vectors in parallel.
    int *dev_a = 0;
    int *dev_b = 0;
    int *dev_c = 0;
    cudaError_t cudaStatus;
    // Choose which GPU to run on, change this on a multi-GPU system.
    cudaStatus = cudaSetDevice(0);
        fprintf(stderr, "cudaSetDevice failed!  Do you have a CUDA-capable GPU installed?");
        goto Error;
    // Allocate GPU buffers for three vectors (two input, one output)    .
    cudaStatus = cudaMalloc((void**)&dev_c, size * sizeof(int));
        fprintf(stderr, "cudaMalloc failed!");
        goto Error;
    cudaStatus = cudaMalloc((void**)&dev_a, size * sizeof(int));
        goto Error;
    cudaStatus = cudaMalloc((void**)&dev_b, size * sizeof(int));
        goto Error;
    // Copy input vectors from host memory to GPU buffers.
    cudaStatus = cudaMemcpy(dev_a, a, size * sizeof(int), cudaMemcpyHostToDevice);
        fprintf(stderr, "cudaMemcpy failed!");
        goto Error;
    cudaStatus = cudaMemcpy(dev_b, b, size * sizeof(int), cudaMemcpyHostToDevice);
        goto Error;
    // Launch a kernel on the GPU with one thread for each element.
    addKernel<<<1, size>>>(dev_c, dev_a, dev_b);
    // Check for any errors launching the kernel
    cudaStatus = cudaGetLastError();
        fprintf(stderr, "addKernel launch failed: %s\n", cudaGetErrorString(cudaStatus));
        goto Error;
    // cudaDeviceSynchronize waits for the kernel to finish, and returns
    // any errors encountered during the launch.
    cudaStatus = cudaDeviceSynchronize();
        fprintf(stderr, "cudaDeviceSynchronize returned error code %d after launching addKernel!\n", cudaStatus);
        goto Error;
    // Copy output vector from GPU buffer to host memory.
    cudaStatus = cudaMemcpy(c, dev_c, size * sizeof(int), cudaMemcpyDeviceToHost);
        goto Error;
Error:
    cudaFree(dev_c);
    cudaFree(dev_a);
    cudaFree(dev_b);
    return cudaStatus;
What is going wrong here?
I found the solution to my issue: After I downgraded to CUDA Toolkit 9.1 and included driver 388.19 (and MSVC Toolset 14.11), everything works fine. When I upgraded to driver 398.75 (the driver from CUDA Toolkit 9.2), I got the same issues as described above. So it seems my problem is a driver issue and I will stick to 388.19 (which unfortunately also implies that I cannot upgrade to CUDA 9.2 or 10.0).
