Greetings everyone,
So, I’ve managed to get the bug down to a simple include statement
#include "cuda_fp16.h"
As soon as I add this one line under the other cuda includes in the default VS 2015 Cuda 8 project (the one that simply performs array addition), and make NO OTHER CHANGES to the code, then building the project breaks.
Specifically, it breaks on the line that calls the cuda kernel
addKernel<<<1, size>>>(dev_c, dev_a, dev_b);
VS gives red underline at the first ‘<’ and says it’s expecting an expression. The error is gives it this:
Severity Code Description Project File Line Suppression State
Error MSB3721 The command ""C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v8.0\bin\nvcc.exe" -gencode=arch=sm_61,code=\" compute_61,sm_61\" --use-local-env --cl-version 2015 -ccbin "C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\bin\x86_amd64" -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v8.0\include" -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v8.0\include" -G --keep-dir x64\Debug -maxrregcount=0 --machine 64 --compile -cudart static -g -DWIN32 -DWIN64 -D_DEBUG -D_CONSOLE -D_MBCS -Xcompiler "/EHsc /W3 /nologo /Od /FS /Zi /RTC1 /MDd " -o x64\Debug\kernel.cu.obj "I:\Tools\DEV\UltraSet\CUDA_Greenscreen\PROJECT\CUDA_GreenScreen\CUDA_GreenScreen\kernel.cu"" exited with code 1. CUDA_GreenScreen C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\BuildCustomizations\CUDA 8.0.targets 689
Here’s the information about my GPU…
C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.0_Utilities\deviceQuery\../../bin/win64/Debug/deviceQuery.exe Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 1 CUDA Capable device(s)
Device 0: "GeForce GTX 1060 3GB"
CUDA Driver Version / Runtime Version 9.0 / 9.0
CUDA Capability Major/Minor version number: 6.1
Total amount of global memory: 3072 MBytes (3221225472 bytes)
( 9) Multiprocessors, (128) CUDA Cores/MP: 1152 CUDA Cores
GPU Max Clock rate: 1860 MHz (1.86 GHz)
Memory Clock rate: 4004 Mhz
Memory Bus Width: 192-bit
L2 Cache Size: 1572864 bytes
Maximum Texture Dimension Size (x,y,z) 1D=(131072), 2D=(131072, 65536), 3D=(16384, 16384, 16384)
Maximum Layered 1D Texture Size, (num) layers 1D=(32768), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(32768, 32768), 2048 layers
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 2048
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (2147483647, 65535, 65535)
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and kernel execution: Yes with 2 copy engine(s)
Run time limit on kernels: Yes
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
CUDA Device Driver Mode (TCC or WDDM): WDDM (Windows Display Driver Model)
Device supports Unified Addressing (UVA): Yes
Supports Cooperative Kernel Launch: No
Supports MultiDevice Co-op Kernel Launch: No
Device PCI Domain ID / Bus ID / location ID: 0 / 3 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 9.0, CUDA Runtime Version = 9.0, NumDevs = 1, Device0 = GeForce GTX 1060 3GB
Result = PASS
The only other thing I changed is inside the VS project is the CODA C/C++ --> Device --> Code Generation tab, and set it to both of the following at different times, neither with any success.
compute_30,sm_30
compute_35,sm_35
compute_37,sm_37
compute_50,sm_50
compute_52,sm_52
compute_60,sm_60
compute_70,sm_70
and
compute_61,sm_61
At this point, I don’t know how to proceed with working with __half values and __half2float() & __float2half_ru() functions, as these also error out when attempting to include them.
Any help or guidance you cam offer would be greatly appreciated.
Thank you
