Cuda 9.1 code update issue with VS2015
Hello Nvidia Team,
I tried to upgrade cuda 4.2 project with cuda 9.1 VS 2015, i updated CUSP file in toolkit folder.
while compiling the project i am getting some errors–
Severity Code Description Project File Line Suppression State
Error invalid redeclaration of type name “thrust::system::cpp::detail::tag” ClothsimLib C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\include\thrust\system\cpp\detail\tag.h 31
Error “tag” has already been declared in the current scope ClothsimLib C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\include\thrust\system\cuda\detail\tag.h 72
Error MSB3721 The command ““C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\bin\nvcc.exe” -gencode=arch=compute_30,code="sm_30,compute_30" -gencode=arch=compute_35,code="sm_35,compute_35" -gencode=arch=compute_37,code="sm_37,compute_37" -gencode=arch=compute_50,code="sm_50,compute_50" -gencode=arch=compute_52,code="sm_52,compute_52" -gencode=arch=compute_60,code="sm_60,compute_60" -gencode=arch=compute_61,code="sm_61,compute_61" -gencode=arch=compute_70,code="sm_70,compute_70" --use-local-env --cl-version 2015 -ccbin “C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\bin\x86_amd64” -x cu -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\include” -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\include" -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\include" -G --keep-dir x64\Debug -maxrregcount=0 --machine 64 --compile -cudart static -g -DWIN32 -DNDEBUG -D_LIB -D_MBCS -Xcompiler “/EHsc /W3 /nologo /Od /FS /Zi /RTC1 /MDd " -o x64\Debug\core_func.cu.obj “C:\Users\ivasa\Desktop\2015\Clothsim\solvers\gpu_solver\core_func.cu”” exited with code 1. ClothsimLib C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\BuildCustomizations\CUDA 9.1.targets 707
Please help me to resolve this issue.
The project may need to be re-written to use the newer thrust and/or cusp versions.
Thanks txbob.
Hello txbox,
as you suggested me to update the newer cusp and thrust for the above errors to compile the code.
Now i successfully compiled and upgraded with 9.1 toolkit.
while i am using the exe to load obj file, i am getting an error with cmd window and project gone exit,
please check the error and help me to solve the problem–
Status: Using GLEW 2.1.0
CUDA error 9 [C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\include\thrust/system/cuda/detail/parallel_for.h, 143]: invalid configuration argument
Thurst Runtime Error: parallel_for failed: invalid configuration argument
Press any key to continue . . .
Please guide me to solve the above issue.
thanks
Hello txbox,
Please help me which driver needed for Quadro P4000 with cuda 8 toolkit.
go to
and use the wizard
Thanks txbob,
I am using the driver 390.65 and getting the run time error and project gone exit.
Please clear about “and use the wizard”.
Please help me with above run time error.
thanks
Hello txbob,
using the cuda-memcheck i am getting this, please check
[b]Microsoft Windows [Version 10.0.16299.309]
(c) 2017 Microsoft Corporation. All rights reserved.
C:\Windows\system32>cuda-memcheck C:\Users\ivasa\Desktop\2015\bin\Clothsim.exe
========= CUDA-MEMCHECK
---- General Information for device 0----
Compute capability: 5.0
Clock rate: 1148000
Device copy overlap: Enabled
Kernel execition timeout : Enabled
---- Memory Information for device 0----
Total global mem: 4294967296
Total constant mem: 65536
Max mem pitch: 2147483647
Texture Alignment: 512
---- MP Information for device 0----
Multiprocessor count: 5
Shared mem per mp: 49152
Registers per mp: 65536
Threads in warp: 32
Max threads per block: 1024
Max thread dimensions: (1024 1024 64)
Max grid dimensions: (2147483647 65535 65535)
CUDA error 33 [C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\include\thrust/system/cuda/detail/parallel_for.h, 143]: invalid resource handle
Thurst Runtime Error: parallel_for failed: invalid resource handle
========= Internal Memcheck Error: Memcheck failed initialization as some other tools is currently attached. Please make sure that nvprof and Nsight Visual Studio Edition are not being run simultaneously
========= Saved host backtrace up to driver entry point at error
========= Host Frame:C:\Windows\system32\nvcuda.dll (cuGraphicsResourceGetMappedPointer + 0x1a9d38) [0x1b7407]
========= Host Frame:C:\Users\ivasa\Desktop\2015\bin\cudart64_91.dll (_cudaInitManagedRuntime + 0x3485) [0x10945]
========= Host Frame:C:\Users\ivasa\Desktop\2015\bin\cudart64_91.dll (_cudaInitManagedRuntime + 0x51b1) [0x12671]
========= Host Frame:C:\Users\ivasa\Desktop\2015\bin\cudart64_91.dll (cudaD3D11SetDirect3DDevice + 0x4c6) [0x332e6]
========= Host Frame:C:\Users\ivasa\Desktop\2015\bin\cudart64_91.dll (_cudaInitManagedRuntime + 0x51eb) [0x126ab]
========= Host Frame:C:\Users\ivasa\Desktop\2015\bin\cudart64_91.dll (_cudaInitManagedRuntime + 0x53b7) [0x12877]
========= Host Frame:C:\Users\ivasa\Desktop\2015\bin\cudart64_91.dll (cudaSetDevice + 0x35) [0x1dac5]
========= Host Frame:C:\Users\ivasa\Desktop\2015\bin\Clothsim.exe (main + 0x47) [0x7ef57]
========= Host Frame:C:\Users\ivasa\Desktop\2015\bin\Clothsim.exe (invoke_main + 0x34) [0x228394]
========= Host Frame:C:\Users\ivasa\Desktop\2015\bin\Clothsim.exe (__scrt_common_main_seh + 0x127) [0x2282c7]
========= Host Frame:C:\Users\ivasa\Desktop\2015\bin\Clothsim.exe (__scrt_common_main + 0xe) [0x22818e]
========= Host Frame:C:\Users\ivasa\Desktop\2015\bin\Clothsim.exe (mainCRTStartup + 0x9) [0x2283a9]
========= Host Frame:C:\Windows\System32\KERNEL32.DLL (BaseThreadInitThunk + 0x14) [0x11fe4]
========= Host Frame:C:\Windows\SYSTEM32\ntdll.dll (RtlUserThreadStart + 0x21) [0x6efc1]
========= ERROR SUMMARY: 1 error
C:\Windows\system32>[/b]
thanks
