cudaMallocPitch()
cudaMallocPitch does not work properly. This is the code segment.
 size_t pitch;
 A_BD.numBlock=156800;  //156800 is a multiple of 64.
 cudaMallocPitch((void**)&A, &pitch, A_BD.numBlock*sizeof(float), 9);
However, it does not work correctly. pitch=627200 after the cudaMallocPitch() and memory clashes.
But the following works properly
 pitch=A_BD.numBlock;
 cudaMalloc((void**)&A, pitch*9*sizeof(float));
It seems that I does not call cudaMallocPitch() correctly. But What’s wrong? Thank you.
I see nothing wrong at all.
Do you want to allocate A_BD.numBlock*sizeof(float) X 9 bytes on global memory?
After calling cudaMallocPitch();
pitch = 156800 * sizeof(float) = 627200 and 627200 is a multiple of 64 so 627200 is a correct number.
What is wrong?
