I am new to CUDA and currently working on a project in which I need to copy large amount of constant 2D array data into device memory. I checked the Reference Manual and found the following functions:
cudaMemcpy2DArraytoArray
cudaMemcpy2DtoArray
My question is
1: what is the difference between these two functions?
2. Will they copy the 2D array from host to device without any change or they will reshape the 2D array to a 1D array in copying process?
3. What is the best way to copy a 2D array to device without changing or reshaping it?
remember that Array in cudaMemcpy2DArraytoArray() and cudaMemcpy2DtoArray() not has the normal structure. Z-curve structure.
cudaMemcpy2DArraytoArray(): In device memory, you already have allocated 2 Array (by using cudaMallocArray()), and copy data between these Array.
cudaMemcpy2DtoArray(). copy 2D array to cudaArray. 2D array is means that a matrix with 2 dimension with normal structure. In your case you can use this
functio to copy 2D array from host to device global memory.
I think that it copy 2D array from host to device without any change .
you have 2 functions to do it.
cudaMemcpy2D(): copy data from host to device memory (normal structure)
cudaMemcpy2DToArray(): copy data from host to cuda Array(not normal structure)
