As indicated by the title, while I was profiling a program I have found major time losses due to a memcpy call which did not make sense. The entire program is accelerated using OpenACC and cuBLAS and cuSPARSE are used. The following is the minimal program I have created for testing this behavior and the observed profiling result is the same:
PROGRAM TEST_MAIN
! test program for specific CUDA kernels
USE CUDAFOR
USE CUBLAS_V2
USE CUSPARSE
USE OPENACC
!$ USE OMP_LIB
IMPLICIT NONE
INTEGER :: N, NNZ
INTEGER, ALLOCATABLE, DIMENSION(:) :: ROWPTR, COLPTR
DOUBLE PRECISION, ALLOCATABLE, DIMENSION(:) :: VALPTR, VEC1, VEC2
DOUBLE PRECISION :: COEFF1, COEFF2, COEFF3
INTEGER :: I
! CUDA VARIABLES
TYPE(cublasHandle) :: cub_h
TYPE(cusparseHandle) :: cusp_h
TYPE(cusparseMatDescr) :: descrA
TYPE(c_devptr) :: buffer
TYPE(cusparseSpMatDescr) :: mat
TYPE(cusparseDnMatDescr) :: vecOne, vecTwo
TYPE(c_devptr) :: devptr
INTEGER(8) :: bsize
INTEGER :: cub_stat, cusp_stat
N = 52329; NNZ = 1375396
ALLOCATE(ROWPTR(NNZ), COLPTR(NNZ), VALPTR(NNZ))
CALL READ_COO('mat.mtx', ROWPTR, COLPTR, VALPTR, N, NNZ)
ALLOCATE(VEC1(N), VEC2(N))
CALL RAND_VEC(VEC1, 35647)
VEC2(:) = 0.0D0
!$ACC DATA COPYIN(ROWPTR, COLPTR, VALPTR, VEC1) COPY(VEC2)
! INITIALIZATION OF CUDA API
cub_stat = cublasInit()
cub_stat = cublasCreate(cub_h)
cub_stat = cublasSetStream(cub_h, acc_get_cuda_stream(acc_async_sync))
cub_stat = cublasSetPointerMode(cub_h, CUBLAS_POINTER_MODE_DEVICE)
cusp_stat = cusparseCreate(cusp_h)
if (cusp_stat .NE. CUSPARSE_STATUS_SUCCESS) &
write(*,*) 'cusparseCreate error for transformation: ', cusp_stat
cusp_stat = cusparseCreateMatDescr(descrA)
cusp_stat = cusparseSetMatType(descrA, CUSPARSE_MATRIX_TYPE_GENERAL)
cusp_stat = cusparseSetMatIndexBase(descrA, CUSPARSE_INDEX_BASE_ONE)
cusp_stat = cusparseSetStream(cusp_h, acc_get_cuda_stream(acc_async_sync))
!$ACC HOST_DATA USE_DEVICE(VEC1, VEC2, ROWPTR, COLPTR, VALPTR)
cusp_stat = cusparseCreateDnMat(vecOne, N, 1, N, VEC1, CUDA_R_64F, CUSPARSE_ORDER_COL)
IF (cusp_stat .NE. CUSPARSE_STATUS_SUCCESS) PRINT *,"cusparseCreateDnMat: ", cusp_stat
cusp_stat = cusparseCreateDnMat(vecTwo, N, 1, N, VEC2, CUDA_R_64F, CUSPARSE_ORDER_COL)
cusp_stat = cusparseCreateCoo(mat, N, N, NNZ, ROWPTR, COLPTR, VALPTR, &
CUSPARSE_INDEX_32I, CUSPARSE_INDEX_BASE_ONE, CUDA_R_64F)
IF (cusp_stat .NE. CUSPARSE_STATUS_SUCCESS) print *,"cusparseCreateCoo: ", cusp_stat
!$ACC END HOST_DATA
DO I = 1, 100000
!$ACC HOST_DATA USE_DEVICE(VEC1, VEC2)
cusp_stat = cusparseDnMatSetValues(vecOne, VEC1)
IF (cusp_stat .NE. CUSPARSE_STATUS_SUCCESS) PRINT *, "cusparseDnMatSetValues: ", cusp_stat
cusp_stat = cusparseDnMatSetValues(vecTwo, VEC2)
cusp_stat = cusparseSpMM_buffersize(cusp_h, CUSPARSE_OPERATION_NON_TRANSPOSE, CUSPARSE_OPERATION_NON_TRANSPOSE, &
1.0D0, mat, vecOne, 0.0D0, vecTwo, CUDA_R_64F, CUSPARSE_COOMM_ALG1, bsize)
IF (cusp_stat .NE. CUSPARSE_STATUS_SUCCESS) print *,"cusparseSpMM_buffersize: ", cusp_stat
IF (bsize .GT. 0) buffer = acc_malloc(bsize)
cusp_stat = cusparseSpMM(cusp_h, CUSPARSE_OPERATION_NON_TRANSPOSE, CUSPARSE_OPERATION_NON_TRANSPOSE, &
1.0D0, mat, vecOne, 0.0D0, vecTwo, CUDA_R_64F, CUSPARSE_COOMM_ALG1, buffer)
IF (cusp_stat .NE. CUSPARSE_STATUS_SUCCESS) PRINT *,"cusparseSpMM: ", cusp_stat
cusp_stat = cusparseDnMatGetValues(vecTwo, devptr)
IF (cusp_stat .NE. CUSPARSE_STATUS_SUCCESS) PRINT *, "cusparseDnMatGetValues: ", cusp_stat
IF (bsize .GT. 0) CALL acc_free(buffer)
!$ACC END HOST_DATA
cub_stat = cublasDdot(cub_h, N, VEC1, 1, VEC2, 1, COEFF1)
!$ACC END HOST_DATA
COEFF1 = 1.0D0 / COEFF1
cub_stat = cublasDdot(cub_h, N, VEC2, 1, VEC1, 1, COEFF2)
!$ACC END HOST_DATA
COEFF2 = COEFF1 + COEFF2
!$ACC HOST_DATA USE_DEVICE(VEC2)
cub_stat = cublasDnrm2(cub_h, N, VEC2, 1, COEFF3)
!$ACC END HOST_DATA
END DO
!$ACC END DATA
DEALLOCATE(ROWPTR, COLPTR, VALPTR, VEC1)
DO I = 1, 10
PRINT '(1X, A,I7,A,E18.12)', "VEC2(", I, ")=", VEC2(I)
END DO
PRINT *, ""
PRINT *, "COEFF3 =", COEFF3
CONTAINS
SUBROUTINE READ_COO(FILENAME, ROWPTR, COLPTR, VALUEPTR, N, NNZ)
IMPLICIT NONE
CHARACTER(LEN=*), INTENT(IN) :: FILENAME
INTEGER, INTENT(OUT) :: ROWPTR(NNZ), COLPTR(NNZ)
DOUBLE PRECISION, INTENT(OUT) :: VALUEPTR(NNZ)
INTEGER, INTENT(INOUT) :: N, NNZ
INTEGER :: NROWS, NCOLS, NNZDUM
INTEGER :: I, STATUS
CHARACTER(LEN=100) :: LINE
! OPEN THE FILE
OPEN(UNIT=57, FILE=FILENAME, STATUS='OLD', ACTION='READ')
! READ THE HEADER
READ(57, '(A)') LINE
PRINT*, "COO FILE DESCRIPTION: ", LINE
! READ ARRAY INFORMATION
READ(57, *) NROWS, NCOLS, NNZDUM
IF (NNZ .NE. NNZDUM) THEN
PRINT*, "NNZ IS INITIALIZED INCORRECTLY, CORRECT IT WITH THE FOLLOWING VALUE: ", NNZDUM
STOP
END IF
IF (NROWS .EQ. NCOLS .AND. N .NE. NROWS) THEN
PRINT*, "N IS INITIALIZED INCORRECTLY, CORRECT IT WITH THE FOLLOWING VALUE: ", NROWS
STOP
ELSE IF (NROWS .NE. NCOLS) THEN
PRINT*, "THE MATRIX IS NOT SYMMETRIC. USE A DIFFERENT FILE"
STOP
END IF
! READ THE NON-ZERO ENTRIES
DO I = 1, NNZ
READ(57, *) ROWPTR(I), COLPTR(I), VALUEPTR(I)
END DO
CLOSE(57)
END SUBROUTINE READ_COO
SUBROUTINE RAND_VEC(VEC, SEED)
IMPLICIT NONE
INTEGER, INTENT(IN) :: SEED
DOUBLE PRECISION, INTENT(OUT) :: VEC(:)
INTEGER, ALLOCATABLE, DIMENSION(:) :: SEED_temp
INTEGER :: NSEED
CALL RANDOM_SEED(SIZE = NSEED)
ALLOCATE(SEED_temp(NSEED))
SEED_temp = SEED
CALL RANDOM_SEED(PUT=SEED_temp)
DEALLOCATE(SEED_temp)
CALL RANDOM_NUMBER(VEC)
END SUBROUTINE RAND_VEC
END PROGRAM TEST_MAIN
The Makefile:
Makefile.zip (586 Bytes)
The referenced sparse matrix I’ve used:
mat.zip (12.7 MB)
The profiling results came out as follows:
CUDA API Statistics:
Time(%) Total Time (ns) Num Calls Average (ns) Minimum (ns) Maximum (ns) StdDev (ns) Name
69,0 11.026.705.921 400.000 27.566,0 4.093 8.489.368 28.086,0 cudaMemcpyAsync
17,0 2.754.990.543 700.001 3.935,0 3.151 117.025.046 139.912,0 cudaLaunchKernel
5,0 797.426.465 4 199.356.616,0 669 329.861.696 144.931.998,0 cudaFree
2,0 421.809.473 100.000 4.218,0 3.858 342.241 1.206,0 cudaMemsetAsync
1,0 265.545.335 900.000 295,0 237 341.989 966,0 cudaStreamGetCaptureInfo_v10010
1,0 221.953.285 300.001 739,0 649 344.767 1.873,0 cudaStreamSynchronize
1,0 196.496.407 300.000 655,0 588 346.016 1.480,0 cudaEventRecord
1,0 158.580.843 300.000 528,0 441 347.150 1.904,0 cudaEventQuery
0,0 20.469.157 1 20.469.157,0 20.469.157 20.469.157 0,0 cuMemAllocManaged
0,0 323.526 1.492 216,0 100 6.072 254,0 cuGetProcAddress
0,0 245.891 6 40.981,0 2.393 109.781 44.916,0 cudaMalloc
0,0 22.300 36 619,0 338 6.019 1.008,0 cudaEventCreateWithFlags
0,0 7.557 4 1.889,0 1.058 2.410 609,0 cuInit
CUDA Kernel Statistics:
Time(%) Total Time (ns) Instances Average (ns) Minimum (ns) Maximum (ns) StdDev (ns) Name
58,0 5.652.060.757 100.000 56.520,0 53.248 8.171.019 25.693,0 void cusparse::cusparseCooMMSmallKernel<(unsigned int)128, (cusparseOperation_t)0, (cusparseOperati…
23,0 2.290.980.528 200.000 11.454,0 11.040 22.591 406,0 void nrm2_kernel<double, double, double, (int)0, (int)0, (int)128>(cublasNrm2Params<T1, T3>)
9,0 910.286.258 200.000 4.551,0 3.775 14.592 748,0 void dot_kernel<double, (int)128, (int)0, cublasDotParams<cublasGemvTensor<const double>, cublasGem…
8,0 799.740.337 200.000 3.998,0 3.583 14.272 406,0 void reduce_1Block_kernel<double, (int)128, (int)7, cublasGemvTensorStridedBatched<double>, cublasG…
0,0 242.525 1 242.525,0 242.525 242.525 0,0 __pgi_dev_cumemset_8n
CUDA Memory Operation Statistics (by time):
Time(%) Total Time (ns) Count Average (ns) Minimum (ns) Maximum (ns) StdDev (ns) Operation
43,0 375.483.435 300.000 1.251,0 864 13.600 131,0 [CUDA memcpy DtoH]
31,0 268.208.025 100.000 2.682,0 2.272 477.116 1.503,0 [CUDA memset]
24,0 208.413.987 100.000 2.084,0 1.856 2.848 68,0 [CUDA memcpy HtoD]
0,0 2.994.783 443 6.760,0 2.270 86.719 12.915,0 [CUDA Unified Memory memcpy HtoD]
0,0 17.307 6 2.884,0 1.568 4.799 1.405,0 [CUDA Unified Memory memcpy DtoH]
CUDA Memory Operation Statistics (by size):
Total (MB) Count Average (MB) Minimum (MB) Maximum (MB) StdDev (MB) Operation
41863,200 100.000 0,419 0,419 0,419 0,000 [CUDA memset]
1024,800 100.000 0,010 0,010 0,010 0,000 [CUDA memcpy HtoD]
24,183 443 0,055 0,004 1,036 0,158 [CUDA Unified Memory memcpy HtoD]
2,400 300.000 0,000 0,000 0,000 0,000 [CUDA memcpy DtoH]
0,131 6 0,022 0,004 0,049 0,020 [CUDA Unified Memory memcpy DtoH]
I’ve tried for a while to fix this but I could not find a well-documented case similar to mine; I’m not quite sure what is the appropriate OpenACC directives are either. Thanks in advance.
