Tovi
December 14, 2008, 3:28pm
#1
This is probably a stupid question, but I don’t know how to use the cudaMemCpyToSymbol correctly. I’m trying to copy local host memory to constant device memory.
So let’s say I have the following simplified example:
__device__ __constant__ float symbol;
void initSymbol(){
float symbolCPU = 3.0f;
cudaMemCpyToSymbol ( symbol, symbolCPU, sizeof(float), 0, cudaCpyHostToDevice);
What is wrong with this?
void initSymbol(){
Well, you supply 5 inputs to the function, where I can only see 3 in the programming guide. You need to at least remove the last 2 inputs. And I also think you need to supply the address of the host float.
Tovi
December 14, 2008, 5:00pm
#3
Actually, The reference manual also gives 5 inputs.
Anyway, I deleted the last two inputs and made the second argument a reference.
But my main mistake was something else. It was that I tried to calculate symbolCPU with other GPU variables. I’ve fixed the problem and now it works.
Thanks anyway!
Thanks anyway!
Okay, good to know about the fact the reference manual has 2 more. That might mean that you can do a cudaMemCopyToSymbol(…, cudaMemCopyDeviceToDevice)
