I was using constant memory and started by copying memory this way
cudaMemcpyToSymbol(constant_device_data, host_data, data_size, cudaMemcpyHostToDevice);
This however, gave me corrupt data on the device. When I instead use these input paramters (removing the enum)
cudaMemcpyToSymbol(constant_device_data, host_data, data_size);
the issue is resolved.
Why is this? What was I doing wrong in the first case ?
Jim
According to cuda_runtime_api.h, the prototype for cudaMemcpyToSymbol is as follows:
[codebox]extern host cudaError_t CUDARTAPI cudaMemcpyToSymbol(const char *symbol, const void *src, size_t count, size_t offset __dv(0), enum cudaMemcpyKind kind __dv(cudaMemcpyHostToDevice));
[/codebox]
Your problem was that you were supplying the enum for cudaMemcpyHostToDevice (which is a 1) as the offset. You should be able to go back to your original code if you just pass a 0 offset (or whatever number you might need there).
Ah, ok of course…
I guess i should RTFM instead of google it. :)
thanks!
