geekus
February 26, 2007, 10:52pm
1
Has anyone else noticed that in the 0.8b package that cudaMemset() does nothing? For me it appears to leave the specified memory buffer on the device unchanged.
For example:
CUDA_SAFE_CALL( cudaMalloc( (void**) &DevOutBuf, 1024));
CUDA_SAFE_CALL( cudaMemset( (void *) DevOutBuf, 0, 1024));
does not set every byte to 0 as it should. If I fill the buffer with a pattern and then try to cudaMemset() it, the original bytes are not overwritten.
JohnH
February 27, 2007, 3:44pm
2
I have noticed this as well. I’m currently doing a Memcpy with a large buffer of zeroes as the input.
geekus
February 27, 2007, 5:15pm
3
For the record I am using the recommended driver that came with the CUDA package (97.73).
I also noticed that cudaMemset() is OK in the emulator but fails on the device.
lavid
May 7, 2007, 5:26pm
4
[snapback]164751[/snapback]
Yeah, I’m having this problem as well, so are others I know writing for CUDA :( Has anyone gotten this to work?
I just double checked; cudaMemset(…) and cudaMemset2D(…) both work fine on Linux, using the recommended 97.51 driver.
Is everyone who is having problems using Windows?
feip
July 5, 2011, 6:23pm
6
Same problem! cudamemset not doing anything. The weird part is it doesn’t always happen, but rather randomly… 4 years and nothing solved?
akavo
July 5, 2011, 8:28pm
7
Works without a flaw for me. It’s either your code or your driver installation.
Try the following code
int* hbuff1, *hbuff2, *dbuff;
hbuff1=(int*) malloc(1024);
hbuff2=(int*) malloc(1024);
memset(hbuff1, 5, 1025);
cudaMalloc((void**) &dbuff, 1024);
cudaMemcpy((void *)dbuff, (void *)hbuff1,1024,cudaMemcpyHostToDevice);
cudaMemset((void *) dbuff, 0, 1024);
cudaMemcpy((void *)hbuff2, (void *)dbuff ,1024,cudaMemcpyDeviceToHost);
assert(memcmp(hbuff1,hbuff2,1024)!=0);
CRF
August 14, 2011, 3:20pm
8
I think this is a bug in cudaMemset, but feel free to point out my error.
The following code yields a string of 16843009s instead of 1s on both Ubuntu 11.04 amd64 and Windows 7x64, latest dev drivers.
[font=“Courier New”]#include <stdio.h>
#include <stdlib.h>
#include <cuda.h>
#define GRID_SIZE 128
int main (int argc , char* argv )
int* gridOccupancy = 0;
cudaMalloc((void**)&gridOccupancy,GRID_SIZE*GRID_SIZE*sizeof(int));
cudaMemset(gridOccupancy,1,GRID_SIZE*GRID_SIZE*sizeof(int));
int* hgridOccupancy = (int*) calloc(GRID_SIZE*GRID_SIZE,sizeof(int));
cudaMemcpy(hgridOccupancy,gridOccupancy,GRID_SIZE*GRID_SIZE*sizeof(int),cudaMemcpyDeviceToHost);
for (int m = 0; m < GRID_SIZE*GRID_SIZE; m++) {
printf ("%d %d\n",m,hgridOccupancy[m]);
free(hgridOccupancy);
/* Cleanup */
cudaFree(gridOccupancy);
return EXIT_SUCCESS ;
}[/font]
Ok. There is no error. cudaMemset works likes memset - it sets bytes, not words. In your code sample, you are effectively setting each byte of memory to a value of 1, not each word. The results you are seeing are expected.
