I am working on a project where I will need to run a bunch of small kernels concurrently. I realize that cudaStreamSynchronize
has become the bottleneck. So, I tried to avoid cudaStreamSynchronize
and use a flag-based approach: the kernel will set a flag in pinned memory as it completes, and the CPU code will busy poll on the flag until the flag is set. Below is an example code that compares the performance between cudaStreamSynchronize
and the flag-based approach:
#include <cuda_runtime.h>
#include <cstdio>
#include <cstdlib>
#include <chrono>
#include <thread>
#include <vector>
__global__ void dummy_cuda_sync() {
__global__ void dummy_flag(volatile int* flag) {
*flag = 1;
void run_cuda_sync(int num_iter, cudaStream_t stream) {
for (int i = 0; i < num_iter; ++i) {
dummy_cuda_sync<<<1, 1, 0, stream>>>();
cudaStreamSynchronize(stream);
void run_flag(int num_iter, cudaStream_t stream, volatile int* flag) {
*flag = 0;
dummy_flag<<<1, 1, 0, stream>>>(flag);
while (*flag == 0);
int main(int argc, char** argv) {
int num_iter = atoi(argv[1]);
int num_thrs = atoi(argv[2]);
std::vector<cudaStream_t> streams;
streams.resize(num_thrs);
for (int i = 0; i < num_thrs; ++i) {
cudaStreamCreate(&streams[i]);
volatile int* flags;
cudaMallocHost(&flags, sizeof(int) * num_thrs);
double time_cuda_sync;
double time_flag;
std::vector<std::thread> thrs;
auto start_time = std::chrono::steady_clock::now();
thrs.emplace_back(run_cuda_sync, num_iter, streams[i]);
for (auto& thr : thrs) {
thr.join();
auto end_time = std::chrono::steady_clock::now();
time_cuda_sync = std::chrono::duration<double, std::micro>(end_time - start_time).count();
thrs.emplace_back(run_flag, num_iter, streams[i], flags + i);
thr.join();
time_flag = std::chrono::duration<double, std::micro>(end_time - start_time).count();
printf("%f,%f\n", time_cuda_sync, time_flag);
Here are the results:
I have two questions regarding the results:
Why are the time linear to the number of threads? My kernel is so small that even when I run 20 at a time, the GPU should be able to run them concurrently and so the time it takes should not increase.
Why is cudaStreamSynchronize so much slower than the flag-based apporach?
Thank you.
I tried adding __threadfence_system();
before *flag = 1;
in dummy_flag()
. Here are the results:
So even with __threadfence_system()
, flag-based approach is still much faster than cudaStreamSynchronize()
especially when there is a high concurrency.
It’s not the best design for CUDA work.
The CUDA runtime has known locking behavior when multiple threads use the CUDA runtime simultaneously. This could impact both kernel launches (which use the runtime under the hood) as well as explicit calls such as cudaDeviceSynchronize()
It’s possible they are not measuring the same thing. A kernel which has posted something in pinned memory is still running and has not released its resources back to the block scheduler/CWD. A kernel launched into a stream that has definitely reach a cuda stream sync point has definitely done those things.
More generally, back to the original idea, kernels whose duration is long compared to the launch overhead are going to make more efficient use of the GPU than kernels that are short relative to the launch overhead. So you are definitely operating in a region here that is known to be non-optimal.
Also, launch overhead, launch efficiency, and even multi-stream behavior are things that get worked on by the CUDA dev team from time to time. Therefore, if by chance you happen to be working on an old CUDA version (9.x would be “old” for example) you may discover better behavior with the latest CUDA releases.
Finally, you can affect the CUDA behavior at a sync point. You might wish to experiment with spin vs. yield.
Thank you for your reply. In an effort to understand how the lock of the CUDA runtime affects the performance of cudaStreamSynchronize
, I tried to use cudaLaunchHostFunc
to register a callback after each kernel, so that there will be only one CPU thread monitoring all streams.
#include <cstdio>
#include <cstdlib>
#include <chrono>
#include <mutex>
#include <thread>
#include <vector>
#include <queue>
#include <atomic>
std::queue<unsigned> noti_queue;
std::atomic_uint noti_queue_num;
std::mutex mtx;
__global__ void dummy() {
void callback(void* stream_id_) {
unsigned stream_id = (unsigned long)stream_id_;
std::unique_lock<std::mutex> lock(mtx);
noti_queue.push(stream_id);
lock.unlock();
noti_queue_num.fetch_add(1, std::memory_order_release);
unsigned num_iter = atoi(argv[1]);
unsigned num_streams = atoi(argv[2]);
streams.resize(num_streams);
for (unsigned i = 0; i < num_streams; ++i) {
std::vector<unsigned> streams_finished;
streams_finished.resize(num_streams);
unsigned total_finished = 0;
const unsigned total_num = num_iter * num_streams;
noti_queue_num.store(0);
dummy<<<1, 1, 0, streams[i]>>>();
cudaLaunchHostFunc(streams[i], callback, (void*)i);
while (total_finished < total_num) {
while (noti_queue_num.load(std::memory_order_acquire) == 0);
noti_queue_num.fetch_sub(1, std::memory_order_release);
unsigned stream_id = noti_queue.front();
noti_queue.pop();
lock.unlock();
++streams_finished[stream_id];
++total_finished;
if (streams_finished[stream_id] < num_iter) {
dummy<<<1, 1, 0, streams[stream_id]>>>();
cudaLaunchHostFunc(streams[stream_id], callback, (void*)stream_id);
double time_elasped = std::chrono::duration<double, std::micro>(end_time - start_time).count();
printf("%f\n", time_elasped);
And below are the results:
It is actually even slower than cudaStreamSynchronize
. Any insight into this?
Also, regarding the sync method, I tried using cudaSetDeviceFlags
to set it to spin, but the results for cudaStreamSynchronize
are similar.
