CUdeviceptr Problem
I just include “generated_cuda_meta.h” in my AutoProfiler.cc code,and this fault happen to me:
[ERROR] fail to compile baidu/adu-lab/inference-engine/infer/CUPTI_Profiling/xxx_adu-lab_inference-engine_inference-engine_so_AutoProfiler.cc.o ip:10.144.206.23
 err:In file included from xxx/adu-lab/inference-engine/infer/CUPTI_Profiling/AutoProfiler.h:33,
                 from baidu/adu-lab/inference-engine/infer/CUPTI_Profiling/AutoProfiler.cc:1:
bc_out/xxx/adu-3rd/cuda/output/include/generated_cuda_meta.h:2370:5: error: 'CUdeviceptr_v1' does not name a type; did you mean 'CUdeviceptr_v2'?
 2370 |     CUdeviceptr_v1 *dptr;
      |     CUdeviceptr_v2
bc_out/xxx/adu-3rd/cuda/output/include/generated_cuda_meta.h:2382:5: error: 'CUdeviceptr_v1' does not name a type; did you mean 'CUdeviceptr_v2'?
 2382 |     CUdeviceptr_v1 *dptr;
      |     CUdeviceptr_v2
Whats the problem here?And the header inclusion part in my AutoProfiler.h is as below:
#include <iostream>
using ::std::cerr;
using ::std::cout;
using ::std::endl;
using ::std::left;
#include <iomanip>
using ::std::setw;
#include <string>
using ::std::string;
using ::std::to_string;
#include <vector>
using ::std::vector;
#include <unordered_map>
using ::std::unordered_map;
#include <mutex>
using ::std::mutex;
#include <unordered_set>
using ::std::unordered_set;
#include <map>
using ::std::map;
#include <stdlib.h>
#include <cuda.h>
#include <cuda_runtime_api.h>
#include <cuda_runtime.h>
// CUPTI headers
#include <cupti_activity.h>
#include <cupti_callbacks.h>
#include <cupti_profiler_target.h>
#include <cupti_driver_cbid.h>
#include <cupti_runtime_cbid.h>
#include "generated_cuda_runtime_api_meta.h"
#include "generated_cuda_meta.h"
#include <cupti_target.h>
#include "infer/CUPTI_Profiling/CUpti_Header/CUpti_tool.h"
//#include "helper_cupti_activity.h"
// NVPW headers
#include <nvperf_host.h>
#include <nvperf_cuda_host.h>
#include <nvperf_target.h> // CUDA 相关的 NVPW 接口
#include "infer/CUPTI_Profiling/CUpti_Header/Eval.h"
using ::NV::Metric::Eval::PrintMetricValues;
// NVTX headers
#include "nvtx3/nvToolsExt.h"
#include "nvtx3/nvToolsExtCuda.h"
#include "nvtx3/nvToolsExtCudaRt.h"
#include "generated_nvtx_meta.h"
#include "infer/CUPTI_Profiling/CUpti_Header/Metric.h"
using ::NV::Metric::Config::GetConfigImage;
using ::NV::Metric::Config::GetCounterDataPrefixImage;
#include "infer/CUPTI_Profiling/CUpti_Header/Utils.h"
using ::NV::Metric::Utils::GetNVPWResultString;
#include "infer/CUPTI_Profiling/CUpti_Header/Parser.h"
really looking forward to any possible answer or solution
Hi, @fwd20001101
Is it possible to provide us a mini-repro for investigation ?
This topic was automatically closed 30 days after the last reply. New replies are no longer allowed.
