Cudnn convolution performance by precision
Software Version
[V] DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
[V] Linux
QNX
other
Hardware Platform
[V] NVIDIA DRIVE™ AGX Xavier DevKit (E3550)
other
SDK Manager Version
[V] 1.8.0.10363
other
Host Machine Version
[V] native Ubuntu 18.04
other
When convolution operation is performed using cudnn, FP32 is the fastest and INT8 is the slowest.
Please check if my setting value is wrong.
FP32 - 2.621643
FP16 - 2.938600 (with tensorcore)
INT8 - 7.822851
int main(int argc, char **argv)
    cudnnHandle_t cudnnHandle;
    cudnnTensorDescriptor_t inTensorDesc, outTensorDesc, biasTensorDesc;
    cudnnFilterDescriptor_t filterDesc;
    cudnnConvolutionDescriptor_t convDesc;
    cudnnActivationDescriptor_t actDesc;
    cudaEvent_t start, stop;
    clock_t cpu_start, cpu_end;
    int in_channel = 8;
    int in_height = 1024;
    int in_width = 2048;
    int batch_count = 1;
    int filter_width = 3;
    int filter_height = 3;
    int out_channel = 16;
    int padding_w = 1;
    int padding_h = 1;
    int stride_horizontal = 2;
    int stride_vertical = 2;
    float alpha = 1.0f;
    float beta = 0.0f;
    checkCudaErrors(cudaEventCreate(&start));
    checkCudaErrors(cudaEventCreate(&stop));
    checkCUDNN(cudnnCreate(&cudnnHandle));
    checkCUDNN(cudnnCreateTensorDescriptor(&inTensorDesc));
    checkCUDNN(cudnnCreateTensorDescriptor(&outTensorDesc));
    checkCUDNN(cudnnCreateTensorDescriptor(&biasTensorDesc));
    checkCUDNN(cudnnCreateFilterDescriptor(&filterDesc));
    checkCUDNN(cudnnCreateConvolutionDescriptor(&convDesc));
    checkCUDNN(cudnnCreateActivationDescriptor(&actDesc));
    checkCUDNN(cudnnSetTensor4dDescriptor(inTensorDesc, CUDNN_TENSOR_NCHW, CUDNN_DATA_FLOAT, batch_count, in_channel, in_height, in_width));
    checkCUDNN(cudnnSetFilter4dDescriptor(filterDesc, CUDNN_DATA_FLOAT, CUDNN_TENSOR_NCHW, out_channel, in_channel, filter_height, filter_width));
    checkCUDNN(cudnnSetConvolution2dDescriptor(convDesc, padding_h, padding_w, stride_vertical, stride_horizontal, 1, 1, CUDNN_CROSS_CORRELATION, CUDNN_DATA_FLOAT));
    checkCUDNN(cudnnSetTensor4dDescriptor(biasTensorDesc, CUDNN_TENSOR_NCHW, CUDNN_DATA_FLOAT, 1, out_channel, 1, 1));
    checkCUDNN(cudnnSetActivationDescriptor(actDesc, CUDNN_ACTIVATION_RELU, CUDNN_PROPAGATE_NAN, 0));
    float *inData_d;
    float *outData_d;
    float *filterData_d;
    void* workSpace;
    checkCudaErrors(cudaMalloc((void**)&inData_d, sizeof(float)*in_channel*in_width*in_height*out_channel));
    checkCudaErrors(cudaMalloc((void**)&filterData_d, sizeof(float)*in_channel*filter_width*filter_height*out_channel));
    cudaMemset(inData_d,0x00,sizeof(float)*in_channel*in_width*in_height*out_channel  );
    cudaMemset(filterData_d,0x00,sizeof(float)*in_channel*filter_width*filter_height*out_channel);
    int out_n, out_c, out_h, out_w;
    checkCUDNN(cudnnGetConvolution2dForwardOutputDim(convDesc, inTensorDesc, filterDesc, &out_n, &out_c, &out_h, &out_w));
    printf("conv out shape (n x c x h x w) = (%d x %d x %d x %d)\n", out_n, out_c, out_h, out_w);
    checkCUDNN(cudnnSetTensor4dDescriptor(outTensorDesc, CUDNN_TENSOR_NCHW, CUDNN_DATA_FLOAT, out_n, out_c, out_h, out_w));
    checkCudaErrors(cudaMalloc((void**)&outData_d, sizeof(float)*out_c*out_w*out_h));
    checkCUDNN(cudnnSetConvolutionMathType(convDesc, CUDNN_TENSOR_OP_MATH));
    int RetCnt;
    cudnnConvolutionFwdAlgoPerf_t     fwd_algo_pref_[8];
   /* cudnnFindConvolutionForwardAlgorithm(cudnnHandle,
                                            inTensorDesc,
                                            filterDesc,
                                            convDesc,
                                            outTensorDesc,
                                            8,
                                            &RetCnt,
                                            fwd_algo_pref_);*/
    checkCUDNN(cudnnGetConvolutionForwardAlgorithm_v7(cudnnHandle,
                                            inTensorDesc,
                                            filterDesc,
                                            convDesc,
                                            outTensorDesc,
                                            4,
                                            &RetCnt,
                                            fwd_algo_pref_));
    cout << "Fastest algorithm for conv = " << fwd_algo_pref_[0].algo << endl;
    size_t sizeInBytes = 0;
    checkCUDNN(cudnnGetConvolutionForwardWorkspaceSize(cudnnHandle,
                                            inTensorDesc,
                                            filterDesc,
                                            convDesc,
                                            outTensorDesc,
                                            fwd_algo_pref_[0].algo,
                                            &sizeInBytes));
    cout << "sizeInBytes " << sizeInBytes << endl;
    if (sizeInBytes != 0)
        checkCudaErrors(cudaMalloc(&workSpace, sizeInBytes));
    for(int i=0;i<300;i++)
        checkCUDNN(cudnnConvolutionForward(cudnnHandle,
                                            &alpha,
                                            inTensorDesc,
                                            inData_d,
                                            filterDesc,
                                            filterData_d,
                                            convDesc,
                                            workSpace,
                                            sizeInBytes,
                                            &beta,
                                            outTensorDesc,
                                            outData_d));
    cudaEventRecord(start);
    cpu_start = clock();
    for(int i=0;i<1000;i++)
                                            &alpha,
                                            inTensorDesc,
                                            inData_d,
                                            filterDesc,
                                            filterData_d,
                                            convDesc,
                                            workSpace,
                                            sizeInBytes,
                                            &beta,
                                            outTensorDesc,
                                            outData_d));
    cpu_end = clock();
    double result = (double)(cpu_end - cpu_start);
    result = result / 1000 /1000;
    printf("cpu - %f \n", result);
    cudaEventRecord(stop);
    cudaEventSynchronize(stop);
    float milliseconds = 0;
    cudaEventElapsedTime(&milliseconds, start, stop);
    printf("gpu - %f \n", milliseconds / 1000);
    checkCudaErrors(cudaFree(inData_d));
    checkCudaErrors(cudaFree(outData_d));
    checkCudaErrors(cudaFree(workSpace));
    cudaEventDestroy(start);
    cudaEventDestroy(stop);
    checkCUDNN(cudnnDestroyTensorDescriptor(inTensorDesc));
    checkCUDNN(cudnnDestroyTensorDescriptor(outTensorDesc));
    checkCUDNN(cudnnDestroyTensorDescriptor(biasTensorDesc));
    checkCUDNN(cudnnDestroyConvolutionDescriptor(convDesc));
    checkCUDNN(cudnnDestroyFilterDescriptor(filterDesc));
    checkCUDNN(cudnnDestroyActivationDescriptor(actDesc));
    checkCUDNN(cudnnDestroy(cudnnHandle));
    return EXIT_SUCCESS;
-Full source code for FP32-
    checkCUDNN(cudnnSetTensor4dDescriptor(inTensorDesc, CUDNN_TENSOR_NHWC, CUDNN_DATA_HALF, batch_count, in_channel, in_height, in_width));
    checkCUDNN(cudnnSetFilter4dDescriptor(filterDesc, CUDNN_DATA_HALF, CUDNN_TENSOR_NHWC, out_channel, in_channel, filter_height, filter_width));
    checkCUDNN(cudnnSetConvolution2dDescriptor(convDesc, padding_h, padding_w, stride_vertical, stride_horizontal, 1, 1, CUDNN_CROSS_CORRELATION, CUDNN_DATA_HALF));
    checkCUDNN(cudnnSetTensor4dDescriptor(biasTensorDesc, CUDNN_TENSOR_NHWC, CUDNN_DATA_HALF, 1, out_channel, 1, 1));
-Setting FP16-
    checkCUDNN(cudnnSetTensor4dDescriptor(inTensorDesc, CUDNN_TENSOR_NHWC, CUDNN_DATA_INT8, batch_count, in_channel, in_height, in_width));
    checkCUDNN(cudnnSetFilter4dDescriptor(filterDesc, CUDNN_DATA_INT8, CUDNN_TENSOR_NHWC, out_channel, in_channel, filter_height, filter_width));
    checkCUDNN(cudnnSetConvolution2dDescriptor(convDesc, padding_h, padding_w, stride_vertical, stride_horizontal, 1, 1, CUDNN_CONVOLUTION, CUDNN_DATA_INT32));
    checkCUDNN(cudnnSetTensor4dDescriptor(biasTensorDesc, CUDNN_TENSOR_NHWC, CUDNN_DATA_INT8, 1, out_channel, 1, 1));
-Setting INT8-
Dear @soohyung.zhang,
I am assuming you are using DRIVE OS 5.2.6 on DRIVE AGX platform. Please confirm.
Also, please share the compilation command/steps as well.
Yes, I am using Drive OS 5.2.6 on DRIVE AGX platform.
Also, I am compiling upper sources using attached make file.
Makefile (13.1 KB)
This file is original source code.
fp32_conv.cu (7.7 KB)
BTW, I notice there is a convolution sample in cudnn at /usr/src/cudnn_samples_v7/along with parameter used in bench-marking. Have you checked it already?
The reference code(/usr/src/cudnn_samples_v7/) has never been seen. Reviewing that code today has been a big help. Thank you!!
Does the above sample helped for your use case?
