I try to convert my TF 2 OD model into tensorrt format using TrtGraphConverter and I have an error
I run nvcr.io/nvidia/tensorrt:20.08-py3 container on my GeForce GTX 1650 (4 GB)
tensorflow==2.4.1
tensorflow-gpu==2.4.1
My code:
import tensorflow as tf
from tensorflow.python.compiler.tensorrt import trt_convert as trt
import numpy as np
import cv2
input_saved_model_dir = ‘/ML/faster_export/saved_model/’
output_saved_model_dir = ‘/ML/tensorrt_faster’
num_runs = 100
conversion_params = trt.DEFAULT_TRT_CONVERSION_PARAMS
print(1 << 32)
conversion_params = conversion_params._replace(max_workspace_size_bytes=(1 << 32))
conversion_params = conversion_params._replace(precision_mode=“FP16”)
conversion_params = conversion_params._replace(maximum_cached_engiens=100)
converter = trt.TrtGraphConverterV2(input_saved_model_dir=input_saved_model_dir, conversion_params=conversion_params)
converter.convert()
def my_input_fn():
for _ in range(num_runs):
inp1 = np.random.normal(size=(1, 640, 640, 3)).astype(np.uint8)
# inp1 = np.expand_dims(np.random.normal(size=(1, 320, 320, 3)).astype(np.float32), axis=0)
yield inp1,
converter.build(input_fn=my_input_fn)
converter.save(output_saved_model_dir)
The error I have:
2021-03-23 09:14:26.821119: I tensorflow/compiler/mlir/mlir_graph_optimization_pass.cc:116] None of the MLIR optimization passes are enabled (registered 2) | ||
2021-03-23 09:14:28.836255: I tensorflow/compiler/tf2tensorrt/common/utils.cc:58] Linked TensorRT version: 7.1.3 | ||
2021-03-23 09:14:28.836434: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libnvinfer.so.7 | ||
2021-03-23 09:14:28.836452: I tensorflow/compiler/tf2tensorrt/common/utils.cc:60] Loaded TensorRT version: 7.1.3 | ||
2021-03-23 09:14:29.006500: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libnvinfer_plugin.so.7 | ||
2021-03-23 09:15:34.764469: E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:42] DefaultLogger …/rtSafe/safeContext.cpp (105) - Cudnn Error in initializeCommonContext: 4 (Could not initialize cudnn, please check cudnn installation.) | ||
2021-03-23 09:15:37.105490: E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:42] DefaultLogger …/rtSafe/safeContext.cpp (105) - Cudnn Error in initializeCommonContext: 4 (Could not initialize cudnn, please check cudnn installation.) | ||
2021-03-23 09:15:37.237905: W tensorflow/compiler/tf2tensorrt/kernels/trt_engine_op.cc:758] TF-TRT Warning: Engine creation for StatefulPartitionedCall/map/while/body/_410/map/while/Preprocessor/TRTEngineOp_0_4 failed. The native segment will be used instead. Reason: Internal: Failed to build TensorRT engine | ||
2021-03-23 09:15:37.246973: W tensorflow/compiler/tf2tensorrt/kernels/trt_engine_op.cc:628] TF-TRT Warning: Engine retrieval for input shapes: [[1,640,640,3]] failed. Running native segment for StatefulPartitionedCall/map/while/body/_410/map/while/Preprocessor/TRTEngineOp_0_4 | ||
2021-03-23 09:15:38.985931: E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:42] DefaultLogger …/rtSafe/safeContext.cpp (105) - Cudnn Error in initializeCommonContext: 4 (Could not initialize cudnn, please check cudnn installation.) | ||
2021-03-23 09:15:38.986137: E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:42] DefaultLogger …/rtSafe/safeContext.cpp (105) - Cudnn Error in initializeCommonContext: 4 (Could not initialize cudnn, please check cudnn installation.) | ||
2021-03-23 09:15:38.986684: W tensorflow/compiler/tf2tensorrt/kernels/trt_engine_op.cc:758] TF-TRT Warning: Engine creation for StatefulPartitionedCall/TRTEngineOp_0_3 failed. The native segment will be used instead. Reason: Internal: Failed to build TensorRT engine | ||
2021-03-23 09:15:38.986714: W tensorflow/compiler/tf2tensorrt/kernels/trt_engine_op.cc:628] TF-TRT Warning: Engine retrieval for input shapes: [[1,320,320,3]] failed. Running native segment for StatefulPartitionedCall/TRTEngineOp_0_3 | ||
2021-03-23 09:15:40.287327: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudnn.so.8 | ||
2021-03-23 09:15:40.288272: E tensorflow/stream_executor/cuda/cuda_dnn.cc:336] Could not create cudnn handle: CUDNN_STATUS_INTERNAL_ERROR | ||
2021-03-23 09:15:40.289028: E tensorflow/stream_executor/cuda/cuda_dnn.cc:336] Could not create cudnn handle: CUDNN_STATUS_INTERNAL_ERROR | ||
2021-03-23 09:15:40.425242: W tensorflow/core/framework/op_kernel.cc:1763] OP_REQUIRES failed at trt_engine_op.cc:400 : Unknown: Failed to get convolution algorithm. This is probably because cuDNN failed to initialize, so try looking to see if a warning log message was printed above. | ||
[[{{node StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/Conv1/Conv2D}}]] | ||
Traceback (most recent call last): | ||
File model_to_tensor_rt.py, line 40, in | ||
converter.build(input_fn=my_input_fn) | ||
File /usr/local/lib/python3.6/dist-packages/tensorflow/python/compiler/tensorrt/trt_convert.py, line 1187, in build | ||
func(*map(ops.convert_to_tensor, inp)) | ||
File /usr/local/lib/python3.6/dist-packages/tensorflow/python/eager/function.py, line 1669, in call | ||
return self._call_impl(args, kwargs) | ||
File /usr/local/lib/python3.6/dist-packages/tensorflow/python/eager/wrap_function.py, line 247, in _call_impl | ||
args, kwargs, cancellation_manager) | ||
File /usr/local/lib/python3.6/dist-packages/tensorflow/python/eager/function.py, line 1687, in _call_impl | ||
return self._call_with_flat_signature(args, kwargs, cancellation_manager) | ||
File /usr/local/lib/python3.6/dist-packages/tensorflow/python/eager/function.py, line 1736, in _call_with_flat_signature | ||
return self._call_flat(args, self.captured_inputs, cancellation_manager) | ||
File /usr/local/lib/python3.6/dist-packages/tensorflow/python/eager/function.py, line 1919, in _call_flat | ||
ctx, args, cancellation_manager=cancellation_manager)) | ||
File /usr/local/lib/python3.6/dist-packages/tensorflow/python/eager/function.py, line 560, in call | ||
ctx=ctx) | ||
File /usr/local/lib/python3.6/dist-packages/tensorflow/python/eager/execute.py, line 60, in quick_execute | ||
inputs, attrs, num_outputs) | ||
tensorflow.python.framework.errors_impl.UnknownError: 2 root error(s) found. | ||
(0) Unknown: Failed to get convolution algorithm. This is probably because cuDNN failed to initialize, so try looking to see if a warning log message was printed above. | ||
[[StatefulPartitionedCall/Postprocessor/BatchMultiClassNonMaxSuppression/MultiClassNonMaxSuppression/unstack/_60]] | ||
(1) Unknown: Failed to get convolution algorithm. This is probably because cuDNN failed to initialize, so try looking to see if a warning log message was printed above. | ||
[[StatefulPartitionedCall/Postprocessor/BatchMultiClassNonMaxSuppression/MultiClassNonMaxSuppression/non_max_suppression_with_scores_5/NonMaxSuppressionV5/_224]] | ||
0 successful operations. | ||
0 derived errors ignored. [Op:__inference_pruned_63910] | ||
Function call stack: | ||
pruned → pruned |
