<em>Please make sure that this is a bug. As per our [GitHub Policy](https://gith…ub.com/tensorflow/tensorflow/blob/master/ISSUES.md), we only address code/doc bugs, performance issues, feature requests and build/installation issues on GitHub. tag:bug_template</em>
**System information**
- Have I written custom code (as opposed to using a stock example script provided in TensorFlow): [No](https://www.tensorflow.org/tutorials/text/text_classification_rnn)
- OS Platform and Distribution (e.g., Linux Ubuntu 16.04): Windows 10
- Mobile device (e.g. iPhone 8, Pixel 2, Samsung Galaxy) if the issue happens on mobile device: n/a
- TensorFlow installed from (source or binary): binary
- TensorFlow version (use command below): v2.1.0-rc1-58-g9837eceb39
- Python version: 3.6.8
- Bazel version (if compiling from source): n/a
- GCC/Compiler version (if compiling from source): n/a
- CUDA/cuDNN version: 10.1.243 / 7.6.0.64
- GPU model and memory: NVIDIA GeForce GTX 1050, 4.00GiB
**Describe the current behavior**
I'm attempting to learn about Recurrent Neural Networks following [this](https://www.tensorflow.org/tutorials/text/text_classification_rnn) guide from Tensorflow. For some reason whenever I try to run the network it fails.
Interestingly network only ever seems to get past one epoch when verbose is set to 1, or excluded. In this case it will typically complete 1-3 epochs before failing.
**Other info / logs**
Potentially similar to [this issue](https://github.com/tensorflow/tensorflow/issues/35791)
2020-01-16 10:26:44.374373: E tensorflow/stream_executor/dnn.cc:596] CUDNN_STATUS_INTERNAL_ERROR
in tensorflow/stream_executor/cuda/cuda_dnn.cc(1802): 'cudnnRNNForwardTraining( cudnn.handle(), rnn_desc.handle(), model_dims.max_seq_length, input_desc.handles(), input_data.opaque(), input_h_desc.handle(), input_h_data.opaque(), input_c_desc.handle(), input_c_data.opaque(), rnn_desc.params_handle(), params.opaque(), output_desc.handles(), output_data->opaque(), output_h_desc.handle(), output_h_data->opaque(), output_c_desc.handle(), output_c_data->opaque(), workspace.opaque(), workspace.size(), reserve_space.opaque(), reserve_space.size())'
2020-01-16 10:26:44.375949: W tensorflow/core/framework/op_kernel.cc:1655] OP_REQUIRES failed at cudnn_rnn_ops.cc:1517 : Internal: Failed to call ThenRnnForward with model config: [rnn_mode, rnn_input_mode, rnn_direction_mode]: 2, 0, 0 , [num_layers, input_size, num_units, dir_count, max_seq_length, batch_size, cell_num_units]: [1, 64, 64, 1, 1850, 64, 64]
2020-01-16 10:26:44.376544: W tensorflow/core/common_runtime/base_collective_executor.cc:217] BaseCollectiveExecutor::StartAbort Internal: Failed to call ThenRnnForward with model config: [rnn_mode, rnn_input_mode, rnn_direction_mode]: 2, 0, 0 , [num_layers, input_size, num_units, dir_count, max_seq_length, batch_size, cell_num_units]: [1, 64, 64, 1, 1850, 64, 64]
[[{{node CudnnRNN}}]]
2020-01-16 10:26:44.377273: W tensorflow/core/common_runtime/base_collective_executor.cc:217] BaseCollectiveExecutor::StartAbort Internal: {{function_node __forward_cudnn_lstm_with_fallback_4560_specialized_for_sequential_bidirectional_backward_lstm_StatefulPartitionedCall_at___inference_distributed_function_5790}} {{function_node __forward_cudnn_lstm_with_fallback_4560_specialized_for_sequential_bidirectional_backward_lstm_StatefulPartitionedCall_at___inference_distributed_function_5790}} Failed to call ThenRnnForward with model config: [rnn_mode, rnn_input_mode, rnn_direction_mode]: 2, 0, 0 , [num_layers, input_size, num_units, dir_count, max_seq_length, batch_size, cell_num_units]: [1, 64, 64, 1, 1850, 64, 64]
[[sequential/bidirectional/backward_lstm/StatefulPartitionedCall]]
[[Reshape_11/_38]]
2020-01-16 10:26:44.379170: W tensorflow/core/common_runtime/base_collective_executor.cc:217] BaseCollectiveExecutor::StartAbort Internal: {{function_node __forward_cudnn_lstm_with_fallback_4560_specialized_for_sequential_bidirectional_backward_lstm_StatefulPartitionedCall_at___inference_distributed_function_5790}} {{function_node __forward_cudnn_lstm_with_fallback_4560_specialized_for_sequential_bidirectional_backward_lstm_StatefulPartitionedCall_at___inference_distributed_function_5790}} Failed to call ThenRnnForward with model config: [rnn_mode, rnn_input_mode, rnn_direction_mode]: 2, 0, 0 , [num_layers, input_size, num_units, dir_count, max_seq_length, batch_size, cell_num_units]: [1, 64, 64, 1, 1850, 64, 64]
File "C:\Users\Cal\Desktop\python\NN\RNN\RNN.py", line 50, in <module>
validation_steps=30)
File "C:\Users\Cal\AppData\Local\Programs\Python\Python36\lib\site-packages\tensorflow_core\python\keras\engine\training.py", line 819, in fit
use_multiprocessing=use_multiprocessing)
File "C:\Users\Cal\AppData\Local\Programs\Python\Python36\lib\site-packages\tensorflow_core\python\keras\engine\training_v2.py", line 342, in fit
total_epochs=epochs)
File "C:\Users\Cal\AppData\Local\Programs\Python\Python36\lib\site-packages\tensorflow_core\python\keras\engine\training_v2.py", line 128, in run_one_epoch
batch_outs = execution_function(iterator)
File "C:\Users\Cal\AppData\Local\Programs\Python\Python36\lib\site-packages\tensorflow_core\python\keras\engine\training_v2_utils.py", line 98, in execution_function
distributed_function(input_fn))
File "C:\Users\Cal\AppData\Local\Programs\Python\Python36\lib\site-packages\tensorflow_core\python\eager\def_function.py", line 568, in __call__
result = self._call(*args, **kwds)
File "C:\Users\Cal\AppData\Local\Programs\Python\Python36\lib\site-packages\tensorflow_core\python\eager\def_function.py", line 599, in _call
return self._stateless_fn(*args, **kwds) # pylint: disable=not-callable
File "C:\Users\Cal\AppData\Local\Programs\Python\Python36\lib\site-packages\tensorflow_core\python\eager\function.py", line 2363, in __call__
return graph_function._filtered_call(args, kwargs) # pylint: disable=protected-access
File "C:\Users\Cal\AppData\Local\Programs\Python\Python36\lib\site-packages\tensorflow_core\python\eager\function.py", line 1611, in _filtered_call
self.captured_inputs)
File "C:\Users\Cal\AppData\Local\Programs\Python\Python36\lib\site-packages\tensorflow_core\python\eager\function.py", line 1692, in _call_flat
ctx, args, cancellation_manager=cancellation_manager))
File "C:\Users\Cal\AppData\Local\Programs\Python\Python36\lib\site-packages\tensorflow_core\python\eager\function.py", line 545, in call
ctx=ctx)
File "C:\Users\Cal\AppData\Local\Programs\Python\Python36\lib\site-packages\tensorflow_core\python\eager\execute.py", line 67, in quick_execute
six.raise_from(core._status_to_exception(e.code, message), None)
File "<string>", line 3, in raise_from
tensorflow.python.framework.errors_impl.InternalError: [_Derived_] Failed to call ThenRnnForward with model config: [rnn_mode, rnn_input_mode, rnn_direction_mode]: 2, 0, 0 , [num_layers, input_size, num_units, dir_count, max_seq_length, batch_size, cell_num_units]: [1, 64, 64, 1, 1850, 64, 64]
[[Reshape_11/_38]] [Op:__inference_distributed_function_5790]
Function call stack:
distributed_function -> distributed_function -> distributed_function
**Describe the expected behavior**
The network trains without error.
**Code to reproduce the issue**
from __future__ import absolute_import, division, print_function, unicode_literals
import tensorflow_datasets as tfds
import tensorflow as tf
import matplotlib.pyplot as plt
def plot_graphs(history, string):
plt.plot(history.history[string])
plt.plot(history.history['val_'+string], '')
plt.xlabel("Epochs")
plt.ylabel(string)
plt.legend([string, 'val_'+string])
plt.show()
dataset, info = tfds.load('imdb_reviews/subwords8k', with_info=True,
as_supervised=True)
train_dataset, test_dataset = dataset['train'], dataset['test']
encoder = info.features['text'].encoder
BUFFER_SIZE = 10000
BATCH_SIZE = 64
train_dataset = train_dataset.shuffle(BUFFER_SIZE)
train_dataset = train_dataset.padded_batch(BATCH_SIZE, tf.compat.v1.data.get_output_shapes(train_dataset))
test_dataset = test_dataset.padded_batch(BATCH_SIZE, tf.compat.v1.data.get_output_shapes(test_dataset))
model = tf.keras.Sequential([
tf.keras.layers.Embedding(encoder.vocab_size, 64),
tf.keras.layers.Bidirectional(tf.keras.layers.LSTM(64)),
tf.keras.layers.Dense(64, activation='relu'),
tf.keras.layers.Dense(1, activation='sigmoid')
model.compile(loss='binary_crossentropy',
optimizer=tf.keras.optimizers.Adam(1e-4),
metrics=['accuracy'])
history = model.fit(train_dataset, epochs=10, verbose=0,
validation_data=test_dataset,
test_loss, test_acc = model.evaluate(test_dataset)
print('Test Loss: {}'.format(test_loss))
print('Test Accuracy: {}'.format(test_acc))
**Already Tried:**
-Updating tensorflow to 2.1, then to 2.1rc1.
-Updating CUDA
-Updating cudNN to 7.6.5.32
-Allowing GPU memory growth.
