I am working on my deep learning using cuDNN.
When I call an in-place cudnnActivationBackward() in a separate program it works, but calling it in my framework gives me status bad param error; it’s clear that I’m doing something wrong but I can’t tell what it is.
cudnnStatus_t status = cudnnActivationBackward(
cudnn_handle,
activation_desc,
alpha_conv_,
output_tensor_desc,
layer_output_block->getData(),
output_tensor_desc,
delta_block->getData(),
output_tensor_desc,
beta,
output_tensor_desc,
delta_block->getData());
operation is in-place so
x == y == layer_output_block->getData()
dx == dy == delta_block->getData()
tensor descriptor is NCHW=5x5x9x9
activation_desc is created with RELU activation, non propating NAN.
output_tensor_desc is the same all over the parameters, so NCHW matches for all x,y,dx,dy.
But I get CUDNN_STATUS_BAD_PARAM.
I’ve read the cuDNN guide which says that CUDNN_STATUS_BAD_PARAM is returned when : The strides nStride, cStride, hStride, wStride of the input differential tensor and output differential tensors differ and in-place operation is used.
Since I pass the parameters dx == dy, x == y and the same tensor descriptor, I don’t think I break the rules (and since in my separate program it works, I guess the way I pass params is correct).
So, there are other cases for which I could get CUDNN_STATUS_BAD_PARAM and are not mentioned in the cuDNN guide ? It is very annoying to get a single return code for a lot of reasons; it would be much easier to debug if I receive CUDNN_STATUS_BAD_PARAM_reason_bla or CUDNN_STATUS_BAD_PARAM_reason_blabla or CUDNN_STATUS_BAD_PARAM_reason_other_bla.
I use CUDA 7.5, cuDNN 5.1.3, on Titan X Maxwell.
Thanks,
Viorel
