Hi everyone,
If somebody haas a source code about CUFFT 2D, please post it.
thanks.
Hi everyone,
thanks.
if you want 2-D in-place transform, you can use following code.
// For in-place FFTs, the input stride is assumed to be 2*(N/2+1) cufftReal elements or N/2+1 cufftComplex
// elements. For out-of-place transforms, the input and output strides match the logical transform size (N)
// and the non-redundant size (N/2+1), respectively.
#ifdef DO_DOUBLE
typedef cufftDoubleComplex Complex;
#else
typedef cufftComplex Complex;
#endif
// forward FFT (inplace)
// real data are put in contiguous data array, h_idata[1:Nx, 1:Ny]
// but size of h_idata is bigger, say Nx * 2*(Ny>>1 +1) doublereal
// output:
// h_idata is a complex array with size Nx*(Ny>>1 + 1)
void lsc_2DFFTF_R2C( const unsigned int Nx, const unsigned int Ny,
doublereal *h_idata )
cufftHandle plan;
doublereal *d_idata;
// size_t N = Nx * Ny;
size_t Ny_pad = ((Ny >> 1) + 1);
size_t N_pad = Nx * Ny_pad;
size_t stride = 2*Ny_pad; // stride on real data
cufftResult flag;
unsigned int i;
// step 1: transfer data to device, sequence by sequence
cutilSafeCall( cudaMalloc((void**)&d_idata, sizeof(Complex)*N_pad ) );
doublereal *d_idata_ptr = d_idata;
doublereal *h_idata_ptr = h_idata;
for ( i = 1; i <= Nx; i++){
CUDA_SAFE_CALL(cudaMemcpy(d_idata_ptr, h_idata_ptr, sizeof(doublereal)*Ny, cudaMemcpyHostToDevice) );
d_idata_ptr += stride;
h_idata_ptr += Ny;
// step 2: Create a 2D FFT plan.
#if defined (DO_DOUBLE)
cufftPlan2d(&plan, Nx, Ny, CUFFT_D2Z );
#else
cufftPlan2d(&plan, Nx, Ny, CUFFT_R2C );
#endif
// step 3: Use the CUFFT plan to transform the signal in-place.
flag = cufftExecD2Z( plan, d_idata, (cufftDoubleComplex *)d_idata );
#else
flag = cufftExecR2C( plan, d_idata, (cufftComplex *) d_idata );
#endif
if ( CUFFT_SUCCESS != flag ){
printf("2D: cufftExecR2C fails\n");
// make sure that all threads are done
cudaThreadSynchronize();
// step 4: copy data to host
CUDA_SAFE_CALL(cudaMemcpy(h_idata, d_idata, sizeof(Complex)*N_pad, cudaMemcpyDeviceToHost) );
// Destroy the CUFFT plan.
cufftDestroy(plan);
cudaFree(d_idata);
Thank you so much LSChien, but I have another question, if I have an image, how can i turn an image into a data matrix?
If you know, please tell me. Thanks again
what kind of image do you have? uint8, unit16 or double?
you can use some tools to convert image to double array, for example, MATLAB.
I’m using 8-bit grayscale images, but I need to load the image in the program, if I use Matlab, i have to copy the matrix (corresponding to the image) and put it in the program, but I need to load the image in the program from some location in the hard disk. Could you please tell me How to do that?
Thanks Again.
