dear all:
I try to do in-place FFT (real to complex, complex to real),
It is O.K. for 1D, but fails on 2D and 3D.
moreover complex-to-complex in-place transform is also O.K.
The following code is in-place forward transform of 2D
[codebox]#ifdef DO_DOUBLE
typedef double doublereal;
typedef cufftDoubleComplex Complex;
typedef float doublereal;
typedef cufftComplex Complex;
void lsc_2DFFTF_R2C( const unsigned int Nx, const unsigned int Ny,
doublereal *h_idata )
cufftHandle plan ;
doublereal *d_idata ;
size_t N = Nx * Ny ;
size_t N_pad = Nx * ((Ny >> 1) + 1) ;
cufftResult flag ;
// step 1: transfer data to device
cutilSafeCall( cudaMalloc((void**)&d_idata, sizeof(Complex )*N_pad ) );
CUDA_SAFE_CALL(cudaMemcpy(d_idata, h_idata, sizeof(doublereal)*N, cudaMemcpyHostToDevice) );
// step 2: Create a 2D FFT plan.
#if defined (DO_DOUBLE)
cufftPlan2d(&plan, Nx, Ny, CUFFT_D2Z );
cufftPlan2d(&plan, Nx, Ny, CUFFT_R2C );
// step 3: Use the CUFFT plan to transform the signal in-place.
flag = cufftExecD2Z( plan, d_idata, (cufftDoubleComplex *)d_idata );
flag = cufftExecR2C( plan, d_idata, (cufftComplex *) d_idata ) ;
if ( CUFFT_SUCCESS != flag ){
printf("2D: cufftExecR2C fails\n");
// make sure that all threads are done
cudaThreadSynchronize();
// step 4: copy data to host
CUDA_SAFE_CALL(cudaMemcpy(h_idata, d_idata, sizeof(Complex)*N_pad, cudaMemcpyDeviceToHost) );
// Destroy the CUFFT plan.
cufftDestroy(plan);
cudaFree(d_idata);
[/codebox]
However if I use out-place, it is O.K.
The following code is out-place forward transform of 2D
[codebox]void lsc_2DFFTF_R2C( const unsigned int Nx, const unsigned int Ny,
cufftHandle plan ;
Complex *d_odata ;
cufftResult flag ;
cutilSafeCall( cudaMalloc((void**)&d_odata, sizeof(Complex)*N_pad ) );
flag = cufftExecD2Z( plan, d_idata, (cufftDoubleComplex *)d_odata );
flag = cufftExecR2C( plan, d_idata, (cufftComplex *) d_odata ) ;
CUDA_SAFE_CALL(cudaMemcpy(h_idata, d_odata, sizeof(Complex)*N_pad, cudaMemcpyDeviceToHost) );
cufftDestroy(plan);
cudaFree(d_idata);
[/codebox]
does someone use in-place real transform successfully?
ps: my platform is winxp pro64, vc2005, cuda 2.3, driver 190.38, GTX295
