cuFFT - error in cufftComplex memory assignment
Hi there!
I am getting a memory error when assigning cufftComplex memory as follows (All variables are declared and set properly prior through function call).
[codebox]
    float *device_proj;
cufftComplex* kernel;
cufftComplex* twice_image_vect;
int size=2*u_ext;
cudaMalloc(reinterpret_cast<void **>(&device_proj), u_ext*v_ext*sizeof(float));
cudaMemcpy(device_proj, in,  u_ext*v_ext*sizeof(float), cudaMemcpyHostToDevice);
cudaMalloc(reinterpret_cast<void **>(&twice_image_vect), size*sizeof(cufftComplex));
cudaMalloc(reinterpret_cast<void **>(&kernel), size*sizeof(cufftComplex));[/codebox]
The error is displayed by VS9 as: First-chance exception at 0x7c812afb in 122209_cufft_test.exe: Microsoft C++ exception: cudaError_enum at memory location 0x0012fa18
Which is to my understanding wrong memory assessment. I am using VS9, Cuda 2.3. and a Quadro FX1700 (I think the card is the problem).
On the other hand, continuing with the program. Assigning values to kernel and doing the FFT returns “good” values, I just don’t like the error invocation.
Anyone ever had the same problem???
Thanks for your help,
Sebastian
  I have the same problem. Could you fix it?
