I’ve had some problems running the new cuFFT LTO callbacks. What I found out is that the callback function cannot be defined as extern "C" otherwise an internal error is returned when creating the plan.
I don’t know if this is an expected behaviour or not, but I think it should be mentioned in the documentation. The reason I put the extern "C" before the function name was because I expected that either a C or C++ (mangled) name must be passed as the callbackSymbolName parameter and I did not want to deal with mangling.
Thank you.
Best regards
David
