cuMemGetInfo undefined refenece ?????
this is the error i get
bibrak@biebo-laptop:~/NVIDIA_CUDA_SDK/projects/multiown$ make
obj/release/multiguide.cu.o: In function matmul(Matrix, Matrix, Matrix)': tmpxft_00002098_00000000-11_multiguide.ii:(.text+0x3b2): undefined reference to cuMemGetInfo’
collect2: ld returned 1 exit status
make: *** […/…/bin/linux/release/multi] Error 1
when i use cuMemGetInfo function
i have ubuntu 9.04 card is 9200M
please tell me the library or the solution to this problem
It would be helpful if you provided the content of your make file and the relevant calling code.
add -lcuda
but how to add
Could you post content of file “Makefile” which is located at :~/NVIDIA_CUDA_SDK/projects/multiown/
Copyright 1993-2006 NVIDIA Corporation. All rights reserved.
NOTICE TO USER:
This source code is subject to NVIDIA ownership rights under U.S. and
international Copyright laws.
NVIDIA MAKES NO REPRESENTATION ABOUT THE SUITABILITY OF THIS SOURCE
CODE FOR ANY PURPOSE. IT IS PROVIDED “AS IS” WITHOUT EXPRESS OR
IMPLIED WARRANTY OF ANY KIND. NVIDIA DISCLAIMS ALL WARRANTIES WITH
REGARD TO THIS SOURCE CODE, INCLUDING ALL IMPLIED WARRANTIES OF
MERCHANTABILITY, NONINFRINGEMENT, AND FITNESS FOR A PARTICULAR PURPOSE.
IN NO EVENT SHALL NVIDIA BE LIABLE FOR ANY SPECIAL, INDIRECT, INCIDENTAL,
OR CONSEQUENTIAL DAMAGES, OR ANY DAMAGES WHATSOEVER RESULTING FROM LOSS
OF USE, DATA OR PROFITS, WHETHER IN AN ACTION OF CONTRACT, NEGLIGENCE
OR OTHER TORTIOUS ACTION, ARISING OUT OF OR IN CONNECTION WITH THE USE
OR PERFORMANCE OF THIS SOURCE CODE.
U.S. Government End Users. This source code is a “commercial item” as
that term is defined at 48 C.F.R. 2.101 (OCT 1995), consisting of
“commercial computer software” and "commercial computer software
documentation" as such terms are used in 48 C.F.R. 12.212 (SEPT 1995)
and is provided to the U.S. Government only as a commercial end item.
Consistent with 48 C.F.R.12.212 and 48 C.F.R. 227.7202-1 through
227.7202-4 (JUNE 1995), all U.S. Government End Users acquire the
source code with only those rights set forth herein.
Build script for project
Add source files here
EXECUTABLE := multi
CUDA source files (compiled with cudacc)
CUFILES := multiguide.cu
CUDA dependency files
CU_DEPS :=
multiguidekernel.cu \
C/C++ source files (compiled with gcc / c++)
#CCFILES := \
template_gold.cpp \
Rules and targets
include …/…/common/common.mk
ok, in order to simplify Makefile,
I suggest that you can edit a Makefile as
[codebox]SDK_ROOT = /usr/local/NVIDIA_CUDA_SDK
CUDA_LIB_PATH = /usr/local/cuda/lib
INLCUDE = -I$(SDK_ROOT)/common/inc -I/usr/local/cuda/include
LIBS = -L$(SDK_ROOT)/lib -lcutil
LIBS += -L$(CUDA_LIB_PATH) -lcudart -lcuda
SRC_CU = test.cu
SRC_CXX =
all:
nvcc -run $(INLCUDE) $(LIBS) $(SRC_CU)  $(SRC_CXX)[/codebox]
(remember that you must insert a “tab” key before “nvcc -run …” )
and then type command “make”
Remark: I suppose that you use sdk 2.2, please check root directory of SDK, sometimes you may install SDK
under home directory , then you need to change definition of SDK_ROOT.
Just observe device memory usage.
thanks that worked … :)
but there is a strange output when I query the memory.
– before running kernel
total mem: 128.405 MB, free: 128.293 MB, used : 0.113 MB
– after running kernel
total mem: 255.312 MB, free: 133.688 MB, used : 121.625 MB
error is no error
Processing time: 7073.609863 (ms)
total mem: 255.312 MB, free: 145.688 MB, used : 109.625 MB
– end
why there is change in the total memory before and after the kernel launches.
by the way my device query --------
There is 1 device supporting CUDA
Device 0: “GeForce 9200M GE”
CUDA Capability Major revision number: 1
CUDA Capability Minor revision number: 1
Total amount of global memory: 267714560 bytes
Number of multiprocessors: 1
Number of cores: 8
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 8192
Warp size: 32
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 262144 bytes
Texture alignment: 256 bytes
Clock rate: 1.30 GHz
Concurrent copy and execution: No
Run time limit on kernels: Yes
Integrated: Yes
Support host page-locked memory mapping: Yes
Compute mode: Default (multiple host threads can use this device simultaneously)
Test PASSED
I don’t believe those mobile and integrated parts have dedicated video memory, they share host memory via their integrated memory controller. My guess is that you are seeing the gpu using “just in time” memory reservation, ie. it can use up to 256Mb, but it might use less if there isn’t a demand for it.
