Hi;
I am trying to copy a struct array to device.I am working with one GPU atm, and i have a problem with cuPrintf function which i use to debug my code.
My struct definition is as below:
struct Node{
char Key[25];
char ConsAlterKey[25];
char MasterKey[3];
int VowelDeletion;
char Data[6];
char MasterData[6];
int Children[35];
int ChildCount;
and for test purpose i fill the struct array like this :
void FillArray(Node *NodeArray)
for(int i=0;i<TotalNodeCount;i++)
strcpy(NodeArray[i].Key,"Key");
strcpy(NodeArray[i].ConsAlterKey,"ConsAlterKey");
strcpy(NodeArray[i].MasterKey,"MasterKey");
NodeArray[i].VowelDeletion=0;
strcpy(NodeArray[i].Data,"Data");
strcpy(NodeArray[i].MasterData,"MasterData");
NodeArray[i].ChildCount=5;
for(int j =0;j<NodeArray[i].ChildCount;j++)
NodeArray[i].Children[j]=i+j;
my main function looks like this:
int main()
Node *NodeArray;
Node *GpuTree;
int tokenCount=0;
int *tokenCountGPU;
NodeArray =(Node *)malloc(sizeof(Node)*(TotalNodeCount));
FillArray(NodeArray);
printf("Filling test : %s\n", NodeArray[13].Key);
cudaMalloc( (void**)&GpuTree, sizeof(Node)*(TotalNodeCount));
cudaMemcpy(GpuTree, NodeArray,sizeof(Node)*(TotalNodeCount), cudaMemcpyHostToDevice);
//test value
tokenCount=35;
gpuAssert( cudaMalloc((void **)&tokenCountGPU, sizeof(int)) );
gpuAssert( cudaMemcpy(tokenCountGPU, &tokenCount, sizeof(int), cudaMemcpyHostToDevice) );
cudaPrintfInit();
Test <<< 1, tokenCount >>> (GpuTree,tokenCountGPU);
cudaPrintfDisplay(stdout, true);
cudaPrintfEnd();
gpuAssert( cudaGetLastError() );
//TODO:free pointers
return(0);
and if I write test function as below:
__global__ void Test(Node *Trie,int *tokenCount)
if (threadIdx.x < *tokenCount)
cuPrintf("%s\n",Trie[threadIdx.x].Key);
return;
i get output like this:
Filling test : Key
[0, 0]: <
[0, 1]: ¶☺!
[0, 2]: ì☺!
[0, 3]: Ä☻!
[0, 4]: o♥!
[0, 5]: t♦!
[0, 6]: L♣!
[0, 7]: $â™ !
[0, 8]: ü♠!
[0, 9]: Ô!
[0, 10]: !
[0, 11]: "
[0, 12]: \
[0, 13]: 4♂!
[0, 14]: ♀♀!
[0, 15]: ä♀!
!0, 16]: ¼
[0, 17]: "♫!
[0, 18]: l☼!
[0, 19]: Dâ–º!
[0, 20]: ∟◄!
[0, 21]: ô◄!
[0, 22]: Ì↕!
[0, 23]: ¤‼!
[0, 24]: |¶!
[0, 25]: T§!
[0, 26]: ,â–¬!
[0, 27]: ♦↨!
[0, 28]: Ü↨!
[0, 29]: ´↑!
[0, 30]: O↓!
[0, 31]: d→!
[0, 32]: <â†!
[0, 33]: ¶∟!
[0, 34]: ì∟!
but if i change my test method like this:
cuPrintf("%c%c%c\n",
Trie[threadIdx.x].Key[0],
Trie[threadIdx.x].Key[1],
Trie[threadIdx.x].Key[2]);
return;
i get the correct output:
Filling test : Key
[0, 0]: Key
[0, 1]: Key
[0, 2]: Key
[0, 3]: Key
[0, 4]: Key
[0, 5]: Key
[0, 6]: Key
[0, 7]: Key
[0, 8]: Key
[0, 9]: Key
[0, 10]: Key
[0, 11]: Key
[0, 12]: Key
[0, 13]: Key
[0, 14]: Key
[0, 15]: Key
[0, 16]: Key
[0, 17]: Key
[0, 18]: Key
[0, 19]: Key
[0, 20]: Key
[0, 21]: Key
[0, 22]: Key
[0, 23]: Key
[0, 24]: Key
[0, 25]: Key
[0, 26]: Key
[0, 27]: Key
[0, 28]: Key
[0, 29]: Key
[0, 30]: Key
[0, 31]: Key
[0, 32]: Key
[0, 33]: Key
[0, 34]: Key
So the question is why do i get corrupt output when I try to print strings through using “%s”?
Thank you.
