Hey guys i was trying to profile my cuda application and use cupti as profiling tool
so basically im trying to make the cupti profiling application silent error without interrupting the main thread
so i created cleanup function that detach the cupti profiling if any small error happens in cupti profiling app
void cleanup(char *function){
fprintf(stderr, “started the sync\n”);
cudaDeviceSynchronize(); fprintf(stderr, “completed the sync\n”); cuptiActivityFlushAll(CUPTI_ACTIVITY_FLAG_FLUSH_FORCED);
fprintf(stderr, “completed the flushing\n”);
cuptiFinalize();
if(arena){
arena_destroy(arena);
arena = NULL;
if(k_arena){
arena_destroy(k_arena);
k_arena = NULL;
static void CUPTIAPI bufferCompleted(CUcontext context, uint32_t streamId, uint8_t *buffer, size_t size, size_t validSize){
int ret;
//struct timespec start, end;
//int kernel_count = 0;
int is_kernel_recorded = 0;
CUpti_Activity *record = NULL;
CUptiResult res = CUPTI_SUCCESS;
//clock_gettime(CLOCK_MONOTONIC, &start);
if(validSize > 0){
while((res = cuptiActivityGetNextRecord(buffer,validSize,&record)) == CUPTI_SUCCESS){
if(record->kind == CUPTI_ACTIVITY_KIND_CONCURRENT_KERNEL){
CUpti_ActivityKernel9 *kernel = (CUpti_ActivityKernel9 *)record;
record_kernel_fn(&tasks,kernel);
is_kernel_recorded = 1;
here the synchronization is happening correctly but flushing is not happening, its looking like main thread cuda process stuck at the time
Example usage of cleanup
*buffer = (uint8_t *)malloc(BUF_REQ_SZE);
//fprintf(stdout, "req address %p", (void *)buffer);
if(!buffer){
perror("malloc");
cleanup("malloc");
int InitializeInjection(void){
atexit(cleanup); CUPTI_CHECK(cuptiActivityRegisterCallbacks(bufferRequest,bufferCompleted));
CUPTI_CHECK(cuptiActivityEnable(CUPTI_ACTIVITY_KIND_DEVICE));
CUPTI_CHECK(cuptiActivityEnable(CUPTI_ACTIVITY_KIND_CONCURRENT_KERNEL));
CUPTI_CHECK(cuptiActivityEnable(CUPTI_ACTIVITY_KIND_MEMORY2));
return 1;
do you guys know why its not cleaning up but at_exit() it is completing i think
is there any thing i missed to include or is there any other approach to detach cupti from running process ?
here i tried without using cuptiFinalizer() instead used cuptiDisableActivity(), even though its not working
also tried removing cudaSynchronize(), not working
basically how to do on fly cupti detach without synchronizing or affecting the current running cuda process?
