The code of the problem function is listed below.
void CUPTIAPI
getMetricValueCallback(void *userdata, CUpti_CallbackDomain domain,
CUpti_CallbackId cbid, const CUpti_CallbackData *cbInfo)
MetricData_t *metricData = (MetricData_t*)userdata;
unsigned int i, j, k;
// This callback is enabled only for launch so we shouldn't see
// anything else.
if (cbid != CUPTI_RUNTIME_TRACE_CBID_cudaLaunch_v3020) {
printf("%s:%d: unexpected cbid %d\n", __FILE__, __LINE__, cbid);
exit(-1);
// on entry, enable all the event groups being collected this pass,
// for metrics we collect for all instances of the event
if (cbInfo->callbackSite == CUPTI_API_ENTER) {
cudaDeviceSynchronize();
CUPTI_CALL(cuptiSetEventCollectionMode(cbInfo->context,
CUPTI_EVENT_COLLECTION_MODE_KERNEL));
for (i = 0; i < metricData->eventGroups->numEventGroups; i++) {
uint32_t all = 1;
CUPTI_CALL(cuptiEventGroupSetAttribute(metricData->eventGroups->eventGroups[i],
CUPTI_EVENT_GROUP_ATTR_PROFILE_ALL_DOMAIN_INSTANCES,
sizeof(all), &all));
CUPTI_CALL(cuptiEventGroupEnable(metricData->eventGroups->eventGroups[i]));
// on exit, read and record event values
if (cbInfo->callbackSite == CUPTI_API_EXIT) {
// for each group, read the event values from the group and record
// in metricData
printf("numEventGroups: %d\n", metricData->eventGroups->numEventGroups);
CUpti_EventGroup group = metricData->eventGroups->eventGroups[i];
CUpti_EventDomainID groupDomain;
uint32_t numEvents, numInstances, numTotalInstances;
CUpti_EventID *eventIds;
size_t groupDomainSize = sizeof(groupDomain);
size_t numEventsSize = sizeof(numEvents);
size_t numInstancesSize = sizeof(numInstances);
size_t numTotalInstancesSize = sizeof(numTotalInstances);
uint64_t *values, normalized, sum;
size_t valuesSize, eventIdsSize;
CUPTI_CALL(cuptiEventGroupGetAttribute(group,
CUPTI_EVENT_GROUP_ATTR_EVENT_DOMAIN_ID,
&groupDomainSize, &groupDomain));
CUPTI_CALL(cuptiDeviceGetEventDomainAttribute(metricData->device, groupDomain,
CUPTI_EVENT_DOMAIN_ATTR_TOTAL_INSTANCE_COUNT,
&numTotalInstancesSize, &numTotalInstances));
CUPTI_EVENT_GROUP_ATTR_INSTANCE_COUNT,
&numInstancesSize, &numInstances));
CUPTI_EVENT_GROUP_ATTR_NUM_EVENTS,
&numEventsSize, &numEvents));
eventIdsSize = numEvents * sizeof(CUpti_EventID);
eventIds = (CUpti_EventID *)malloc(eventIdsSize);
CUPTI_EVENT_GROUP_ATTR_EVENTS,
&eventIdsSize, eventIds));
valuesSize = sizeof(uint64_t) * numInstances;
values = (uint64_t *)malloc(valuesSize);
for (j = 0; j < numEvents; j++) {
CUPTI_CALL(cuptiEventGroupReadEvent(group, CUPTI_EVENT_READ_FLAG_NONE,
eventIds[j], &valuesSize, values));
// sum collect event values from all instances
sum = 0;
for (k = 0; k < numInstances; k++)
sum += values[k];
// normalize the event value to represent the total number of
// domain instances on the device
normalized = (sum * numTotalInstances) / numInstances;
metricData->eventIdArray[metricData->eventIdx] = eventIds[j];
metricData->eventValueArray[metricData->eventIdx] = normalized;
metricData->eventIdx++;
// print collected value
char eventName[128];
size_t eventNameSize = sizeof(eventName) - 1;
CUPTI_CALL(cuptiEventGetAttribute(eventIds[j], CUPTI_EVENT_ATTR_NAME,
&eventNameSize, eventName));
eventName[127] = '\0';
free(values);
CUPTI_CALL(cuptiEventGroupDisable(metricData->eventGroups->eventGroups[i]));
int main(int argc, char **argv)
CUpti_SubscriberHandle subscriber;
CUcontext context = 0;
CUdevice device = 0;
int computeCapabilityMajor=0;
int computeCapabilityMinor=0;
int deviceNum;
char deviceName[32];
const char *metricName;
CUpti_MetricID metricId;
CUpti_EventGroupSets *passData;
MetricData_t metricData;
unsigned int pass;
CUpti_MetricValue metricValue;
// make sure activity is enabled before any CUDA API
CUPTI_CALL(cuptiActivityEnable(CUPTI_ACTIVITY_KIND_KERNEL));
DRIVER_API_CALL(cuInit(0)); //must be called before any driver API
DRIVER_API_CALL(cuCtxCreate(&context, 0, device));
DRIVER_API_CALL(cuDeviceGet(&device, deviceNum));
DRIVER_API_CALL(cuDeviceGetName(deviceName, 32, device));
DRIVER_API_CALL(cuDeviceComputeCapability(&computeCapabilityMajor,
&computeCapabilityMinor,
device));
// Get the name of the metric to collect
if (argc > 2)
metricName = argv[2];
else {
if (computeCapabilityMajor > 1) {
metricName = METRIC_NAME_FERMI;
else {
metricName = METRIC_NAME_TESLA;
int block_size = 32;
dim3 dimsA(32*block_size, 32*block_size, 1);
dim3 dimsB(128*block_size, 32*block_size, 1);
CUPTI_CALL(cuptiActivityRegisterCallbacks(bufferRequested, bufferCompleted));
int matrix_result = matrixMultiply(/*argc, argv, */block_size, dimsA, dimsB);
CUPTI_CALL(cuptiActivityFlushAll(0));
// setup launch callback for event collection
CUPTI_CALL(cuptiSubscribe(&subscriber, (CUpti_CallbackFunc)getMetricValueCallback, &metricData));
CUPTI_CALL(cuptiEnableCallback(1, subscriber, CUPTI_CB_DOMAIN_RUNTIME_API,
CUPTI_RUNTIME_TRACE_CBID_cudaLaunch_v3020));
// allocate space to hold all the events needed for the metric
CUPTI_CALL(cuptiMetricGetIdFromName(device, metricName, &metricId));
CUPTI_CALL(cuptiMetricGetNumEvents(metricId, &metricData.numEvents));
metricData.device = device;
metricData.eventIdArray = (CUpti_EventID *)malloc(metricData.numEvents * sizeof(CUpti_EventID));
metricData.eventValueArray = (uint64_t *)malloc(metricData.numEvents * sizeof(uint64_t));
metricData.eventIdx = 0;
// get the number of passes required to collect all the events
// needed for the metric and the event groups for each pass
CUPTI_CALL(cuptiMetricCreateEventGroupSets(context, sizeof(metricId), &metricId, &passData));
for (pass = 0; pass < passData->numSets; pass++) {
printf("Pass %u\n", pass);
metricData.eventGroups = passData->sets + pass;
//int matrix_result =
matrixMultiply(/*argc, argv,*/ block_size, dimsA, dimsB);
// use all the collected events to calculate the metric value
CUPTI_CALL(cuptiMetricGetValue(device, metricId,
metricData.numEvents * sizeof(CUpti_EventID),
metricData.eventIdArray,
metricData.numEvents * sizeof(uint64_t),
metricData.eventValueArray,
kernelDuration, &metricValue));
// print metric value, we format based on the value kind
CUpti_MetricValueKind valueKind;
size_t valueKindSize = sizeof(valueKind);
CUPTI_CALL(cuptiMetricGetAttribute(metricId, CUPTI_METRIC_ATTR_VALUE_KIND,
&valueKindSize, &valueKind));
switch (valueKind) {
case CUPTI_METRIC_VALUE_KIND_DOUBLE:
printf("Metric %s = %f\n", metricName, metricValue.metricValueDouble);
break;
case CUPTI_METRIC_VALUE_KIND_UINT64:
printf("Metric %s = %llu\n", metricName,
(unsigned long long)metricValue.metricValueUint64);
break;
case CUPTI_METRIC_VALUE_KIND_INT64:
printf("Metric %s = %lld\n", metricName,
(long long)metricValue.metricValueInt64);
break;
case CUPTI_METRIC_VALUE_KIND_PERCENT:
printf("Metric %s = %f%%\n", metricName, metricValue.metricValuePercent);
break;
case CUPTI_METRIC_VALUE_KIND_THROUGHPUT:
printf("Metric %s = %llu bytes/sec\n", metricName,
(unsigned long long)metricValue.metricValueThroughput);
break;
case CUPTI_METRIC_VALUE_KIND_UTILIZATION_LEVEL:
printf("Metric %s = utilization level %u\n", metricName,
(unsigned int)metricValue.metricValueUtilizationLevel);
break;
default:
fprintf(stderr, "error: unknown value kind\n");
exit(-1);
CUPTI_CALL(cuptiUnsubscribe(subscriber));
exit(matrix_result);
