I’ve downloaded the callback_metrics sample of CUPTI and I’ve executed it. All works fine but when I change the runPass() function and run system(“./runPass”) insted (where “./runPass” is an external executable with the same code that the runPass() function included in the sample) the program doesn’t run. ¿Is there are any way to measure metrics in a CUPTI script from a CUDA binary?
The code below is callback_metrics sample with my modifications to run and profile other binaries. “./runPass” contains the same VecAdd kernel and all the code of runPass in its main.
CUDA version 8.0, drivers-384 and Ubuntu 14 are installed.
This is the terminal output:
* Copyright 2011-2015 NVIDIA Corporation. All rights reserved
* Sample app to demonstrate use of CUPTI library to obtain metric values
* using callbacks for CUDA runtime APIs
#include <stdio.h>
#include <cuda.h>
#include <cupti.h>
#include <unistd.h>
#include <sys/wait.h>
#include <sys/types.h>
#define METRIC_NAME_TESLA "branch_efficiency"
#define METRIC_NAME_FERMI "ipc"
#define DRIVER_API_CALL(apiFuncCall) \
do { \
CUresult _status = apiFuncCall; \
if (_status != CUDA_SUCCESS) { \
fprintf(stderr, "%s:%d: error: function %s failed with error %d.\n", \
__FILE__, __LINE__, #apiFuncCall, _status); \
exit(-1); \
} while (0)
#define RUNTIME_API_CALL(apiFuncCall) \
do { \
cudaError_t _status = apiFuncCall; \
if (_status != cudaSuccess) { \
fprintf(stderr, "%s:%d: error: function %s failed with error %s.\n", \
__FILE__, __LINE__, #apiFuncCall, cudaGetErrorString(_status));\
exit(-1); \
} while (0)
#define CUPTI_CALL(call) \
do { \
CUptiResult _status = call; \
if (_status != CUPTI_SUCCESS) { \
const char *errstr; \
cuptiGetResultString(_status, &errstr); \
__FILE__, __LINE__, #call, errstr); \
exit(-1); \
} while (0)
#define ALIGN_SIZE (8)
#define ALIGN_BUFFER(buffer, align) \
(((uintptr_t) (buffer) & ((align)-1)) ? ((buffer) + (align) - ((uintptr_t) (buffer) & ((align)-1))) : (buffer))
// User data for event collection callback
typedef struct MetricData_st {
// the device where metric is being collected
CUdevice device;
// the set of event groups to collect for a pass
CUpti_EventGroupSet *eventGroups;
// the current number of events collected in eventIdArray and
// eventValueArray
uint32_t eventIdx;
// the number of entries in eventIdArray and eventValueArray
uint32_t numEvents;
// array of event ids
CUpti_EventID *eventIdArray;
// array of event values
uint64_t *eventValueArray;
} MetricData_t;
static uint64_t kernelDuration;
// Device code
__global__ void VecAdd(const int* A, const int* B, int* C, int N)
int i = blockDim.x * blockIdx.x + threadIdx.x;
if (i < N)
C[i] = A[i] + B[i];
static void
initVec(int *vec, int n)
for (int i=0; i< n; i++)
vec[i] = i;
void CUPTIAPI
getMetricValueCallback(void *userdata, CUpti_CallbackDomain domain,
CUpti_CallbackId cbid, const CUpti_CallbackData *cbInfo)
MetricData_t *metricData = (MetricData_t*)userdata;
unsigned int i, j, k;
printf("Entro en el callback\n");
// This callback is enabled only for launch so we shouldn't see
// anything else.
if (cbid != CUPTI_RUNTIME_TRACE_CBID_cudaLaunch_v3020) {
printf("%s:%d: unexpected cbid %d\n", __FILE__, __LINE__, cbid);
exit(-1);
// on entry, enable all the event groups being collected this pass,
// for metrics we collect for all instances of the event
if (cbInfo->callbackSite == CUPTI_API_ENTER) {
cudaDeviceSynchronize();
CUPTI_CALL(cuptiSetEventCollectionMode(cbInfo->context,
CUPTI_EVENT_COLLECTION_MODE_KERNEL));
for (i = 0; i < metricData->eventGroups->numEventGroups; i++) {
uint32_t all = 1;
CUPTI_CALL(cuptiEventGroupSetAttribute(metricData->eventGroups->eventGroups[i],
CUPTI_EVENT_GROUP_ATTR_PROFILE_ALL_DOMAIN_INSTANCES,
sizeof(all), &all));
CUPTI_CALL(cuptiEventGroupEnable(metricData->eventGroups->eventGroups[i]));
// on exit, read and record event values
if (cbInfo->callbackSite == CUPTI_API_EXIT) {
// for each group, read the event values from the group and record
// in metricData
CUpti_EventGroup group = metricData->eventGroups->eventGroups[i];
CUpti_EventDomainID groupDomain;
uint32_t numEvents, numInstances, numTotalInstances;
CUpti_EventID *eventIds;
size_t groupDomainSize = sizeof(groupDomain);
size_t numEventsSize = sizeof(numEvents);
size_t numInstancesSize = sizeof(numInstances);
size_t numTotalInstancesSize = sizeof(numTotalInstances);
uint64_t *values, normalized, sum;
size_t valuesSize, eventIdsSize;
CUPTI_CALL(cuptiEventGroupGetAttribute(group,
CUPTI_EVENT_GROUP_ATTR_EVENT_DOMAIN_ID,
&groupDomainSize, &groupDomain));
CUPTI_CALL(cuptiDeviceGetEventDomainAttribute(metricData->device, groupDomain,
CUPTI_EVENT_DOMAIN_ATTR_TOTAL_INSTANCE_COUNT,
&numTotalInstancesSize, &numTotalInstances));
CUPTI_EVENT_GROUP_ATTR_INSTANCE_COUNT,
&numInstancesSize, &numInstances));
CUPTI_EVENT_GROUP_ATTR_NUM_EVENTS,
&numEventsSize, &numEvents));
eventIdsSize = numEvents * sizeof(CUpti_EventID);
eventIds = (CUpti_EventID *)malloc(eventIdsSize);
CUPTI_EVENT_GROUP_ATTR_EVENTS,
&eventIdsSize, eventIds));
valuesSize = sizeof(uint64_t) * numInstances;
values = (uint64_t *)malloc(valuesSize);
for (j = 0; j < numEvents; j++) {
CUPTI_CALL(cuptiEventGroupReadEvent(group, CUPTI_EVENT_READ_FLAG_NONE,
eventIds[j], &valuesSize, values));
if (metricData->eventIdx >= metricData->numEvents) {
fprintf(stderr, "error: too many events collected, metric expects only %d\n",
(int)metricData->numEvents);
exit(-1);
// sum collect event values from all instances
sum = 0;
for (k = 0; k < numInstances; k++)
sum += values[k];
// normalize the event value to represent the total number of
// domain instances on the device
normalized = (sum * numTotalInstances) / numInstances;
metricData->eventIdArray[metricData->eventIdx] = eventIds[j];
metricData->eventValueArray[metricData->eventIdx] = normalized;
metricData->eventIdx++;
// print collected value
char eventName[128];
size_t eventNameSize = sizeof(eventName) - 1;
CUPTI_CALL(cuptiEventGetAttribute(eventIds[j], CUPTI_EVENT_ATTR_NAME,
&eventNameSize, eventName));
eventName[127] = '\0';
printf("\t%s = %llu (", eventName, (unsigned long long)sum);
if (numInstances > 1) {
for (k = 0; k < numInstances; k++) {
if (k != 0)
printf(", ");
printf("%llu", (unsigned long long)values[k]);
printf(")\n");
printf("\t%s (normalized) (%llu * %u) / %u = %llu\n",
eventName, (unsigned long long)sum,
numTotalInstances, numInstances,
(unsigned long long)normalized);
free(values);
CUPTI_CALL(cuptiEventGroupDisable(metricData->eventGroups->eventGroups[i]));
static void
cleanUp(int *h_A, int *h_B, int *h_C, int *d_A, int *d_B, int *d_C)
if (d_A)
cudaFree(d_A);
if (d_B)
cudaFree(d_B);
if (d_C)
cudaFree(d_C);
// Free host memory
if (h_A)
free(h_A);
if (h_B)
free(h_B);
if (h_C)
free(h_C);
/*static void
runPass()
int N = 50000;
size_t size = N * sizeof(int);
int threadsPerBlock = 0;
int blocksPerGrid = 0;
int *h_A, *h_B, *h_C;
int *d_A, *d_B, *d_C;
int i, sum;
// Allocate input vectors h_A and h_B in host memory
h_A = (int*)malloc(size);
h_B = (int*)malloc(size);
h_C = (int*)malloc(size);
// Initialize input vectors
initVec(h_A, N);
initVec(h_B, N);
memset(h_C, 0, size);
// Allocate vectors in device memory
cudaMalloc((void**)&d_A, size);
cudaMalloc((void**)&d_B, size);
cudaMalloc((void**)&d_C, size);
// Copy vectors from host memory to device memory
cudaMemcpy(d_A, h_A, size, cudaMemcpyHostToDevice);
cudaMemcpy(d_B, h_B, size, cudaMemcpyHostToDevice);
// Invoke kernel
threadsPerBlock = 256;
blocksPerGrid = (N + threadsPerBlock - 1) / threadsPerBlock;
printf("Launching kernel: blocks %d, thread/block %d\n",
blocksPerGrid, threadsPerBlock);
VecAdd<<<blocksPerGrid, threadsPerBlock>>>(d_A, d_B, d_C, N);
// Copy result from device memory to host memory
// h_C contains the result in host memory
cudaMemcpy(h_C, d_C, size, cudaMemcpyDeviceToHost);
// Verify result
for (i = 0; i < N; ++i) {
sum = h_A[i] + h_B[i];
if (h_C[i] != sum) {
fprintf(stderr, "error: result verification failed\n");
exit(-1);
cleanUp(h_A, h_B, h_C, d_A, d_B, d_C);
static void CUPTIAPI
bufferRequested(uint8_t **buffer, size_t *size, size_t *maxNumRecords)
uint8_t *rawBuffer;
*size = 16 * 1024;
rawBuffer = (uint8_t *)malloc(*size + ALIGN_SIZE);
*buffer = ALIGN_BUFFER(rawBuffer, ALIGN_SIZE);
*maxNumRecords = 0;
if (*buffer == NULL) {
printf("Error: out of memory\n");
exit(-1);
bufferCompleted(CUcontext ctx, uint32_t streamId, uint8_t *buffer, size_t size, size_t validSize)
CUpti_Activity *record = NULL;
CUpti_ActivityKernel3 *kernel;
//since we launched only 1 kernel, we should have only 1 kernel record
CUPTI_CALL(cuptiActivityGetNextRecord(buffer, validSize, &record));
kernel = (CUpti_ActivityKernel3 *)record;
if (kernel->kind != CUPTI_ACTIVITY_KIND_KERNEL) {
fprintf(stderr, "Error: expected kernel activity record, got %d\n", (int)kernel->kind);
exit(-1);
kernelDuration = kernel->end - kernel->start;
free(buffer);
int
main(int argc, char *argv[])
CUpti_SubscriberHandle subscriber;
CUcontext context = 0;
CUdevice device = 0;
int computeCapabilityMajor=0;
int computeCapabilityMinor=0;
int deviceNum;
int deviceCount;
char deviceName[32];
const char *metricName;
CUpti_MetricID metricId;
CUpti_EventGroupSets *passData;
MetricData_t metricData;
unsigned int pass;
CUpti_MetricValue metricValue;
printf("Usage: %s [device_num] [metric_name]\n", argv[0]);
// make sure activity is enabled before any CUDA API
CUPTI_CALL(cuptiActivityEnable(CUPTI_ACTIVITY_KIND_KERNEL));
DRIVER_API_CALL(cuInit(0));
DRIVER_API_CALL(cuDeviceGetCount(&deviceCount));
if (deviceCount == 0) {
printf("There is no device supporting CUDA.\n");
return -2;
if (argc > 1)
deviceNum = atoi(argv[1]);
else
deviceNum = 0;
printf("CUDA Device Number: %d\n", deviceNum);
DRIVER_API_CALL(cuDeviceGet(&device, deviceNum));
DRIVER_API_CALL(cuDeviceGetName(deviceName, 32, device));
printf("CUDA Device Name: %s\n", deviceName);
DRIVER_API_CALL(cuDeviceComputeCapability(&computeCapabilityMajor,
&computeCapabilityMinor,
device));
DRIVER_API_CALL(cuCtxCreate(&context, 0, device));
// Get the name of the metric to collect
if (argc > 2)
metricName = argv[2];
else {
if (computeCapabilityMajor > 1) {
metricName = METRIC_NAME_FERMI;
else {
metricName = METRIC_NAME_TESLA;
// need to collect duration of kernel execution without any event
// collection enabled (some metrics need kernel duration as part of
// calculation). The only accurate way to do this is by using the
// activity API.
CUPTI_CALL(cuptiActivityRegisterCallbacks(bufferRequested, bufferCompleted));
// runPass();
pid_t child_pid, wpid;
int status = 0;
if((child_pid =fork()) == 0){
system("./runpass");
exit(0);
while((wpid = wait (&status)) > 0);
CUPTI_CALL(cuptiActivityFlushAll(0));
// setup launch callback for event collection
CUPTI_CALL(cuptiSubscribe(&subscriber, (CUpti_CallbackFunc)getMetricValueCallback, &metricData));
CUPTI_CALL(cuptiEnableCallback(1, subscriber, CUPTI_CB_DOMAIN_RUNTIME_API,
CUPTI_RUNTIME_TRACE_CBID_cudaLaunch_v3020));
// allocate space to hold all the events needed for the metric
CUPTI_CALL(cuptiMetricGetIdFromName(device, metricName, &metricId));
CUPTI_CALL(cuptiMetricGetNumEvents(metricId, &metricData.numEvents));
metricData.device = device;
metricData.eventIdArray = (CUpti_EventID *)malloc(metricData.numEvents * sizeof(CUpti_EventID));
metricData.eventValueArray = (uint64_t *)malloc(metricData.numEvents * sizeof(uint64_t));
metricData.eventIdx = 0;
// get the number of passes required to collect all the events
// needed for the metric and the event groups for each pass
CUPTI_CALL(cuptiMetricCreateEventGroupSets(context, sizeof(metricId), &metricId, &passData));
for (pass = 0; pass < passData->numSets; pass++) {
printf("Pass %u\n", pass);
metricData.eventGroups = passData->sets + pass;
// runPass();
int status = 0;
exit(0);
if (metricData.eventIdx != metricData.numEvents) {
fprintf(stderr, "error: expected %u metric events, got %u\n",
metricData.numEvents, metricData.eventIdx);
exit(-1);
// use all the collected events to calculate the metric value
CUPTI_CALL(cuptiMetricGetValue(device, metricId,
metricData.numEvents * sizeof(CUpti_EventID),
metricData.eventIdArray,
metricData.numEvents * sizeof(uint64_t),
metricData.eventValueArray,
kernelDuration, &metricValue));
// print metric value, we format based on the value kind
CUpti_MetricValueKind valueKind;
size_t valueKindSize = sizeof(valueKind);
CUPTI_CALL(cuptiMetricGetAttribute(metricId, CUPTI_METRIC_ATTR_VALUE_KIND,
&valueKindSize, &valueKind));
switch (valueKind) {
case CUPTI_METRIC_VALUE_KIND_DOUBLE:
printf("Metric %s = %f\n", metricName, metricValue.metricValueDouble);
break;
case CUPTI_METRIC_VALUE_KIND_UINT64:
printf("Metric %s = %llu\n", metricName,
(unsigned long long)metricValue.metricValueUint64);
break;
case CUPTI_METRIC_VALUE_KIND_INT64:
printf("Metric %s = %lld\n", metricName,
(long long)metricValue.metricValueInt64);
break;
case CUPTI_METRIC_VALUE_KIND_PERCENT:
printf("Metric %s = %f%%\n", metricName, metricValue.metricValuePercent);
break;
case CUPTI_METRIC_VALUE_KIND_THROUGHPUT:
printf("Metric %s = %llu bytes/sec\n", metricName,
(unsigned long long)metricValue.metricValueThroughput);
break;
case CUPTI_METRIC_VALUE_KIND_UTILIZATION_LEVEL:
printf("Metric %s = utilization level %u\n", metricName,
(unsigned int)metricValue.metricValueUtilizationLevel);
break;
default:
fprintf(stderr, "error: unknown value kind\n");
exit(-1);
CUPTI_CALL(cuptiUnsubscribe(subscriber));
return 0;
