Cusparselt can't choose the best kernel(sometime)?
machine and environment
A100-PCIe-40GB
cusparselt-0.4.0.7
NVCC-11.8
My Questions
When I use Nsight Compute to test the sparse matrix multiplication (SpMM) using cusparselt, I find that cusparselt repeats multiple runs during execution to find the fastest kernel. However, when inspecting the ncu results, I notice that the duration of the ultimately selected kernel may not be the fastest one. Why is this happening? If I run the code directly(without ncu), how can I determine whether cusparselet has chosen the fastest kernel?
For example, the collected results from nsight compute are as follows(for simplicity, only copy the durations here)(it can be observed that during the kernel selection process, the final choice was a kernel with a duration of 26.05, but there are kernels with faster durations):
durations [10.59, 7.9, 41.09, 25.47, 25.44, 25.47, 25.6, 25.57, 25.47, 15.14, 15.26, 15.2, 15.2, 15.1, 19.97, 19.94, 20.16, 20.0, 20.06, 25.98, 26.02, 26.37, 26.08, 26.08, 26.05]
The earlier part of nsight compute profiling is as follows:
==PROF== Profiling "pruning_kernel" - 0: 0%....50%....100% - 10 passes
==PROF== Profiling "pruning_check_kernel" - 1: 0%....50%....100% - 10 passes
==PROF== Profiling "compressSparseTensor_4_2" - 2: 0%....50%....100% - 10 passes
==PROF== Profiling "sm80_xmma_sparse_gemm_f16f16_..." - 3: 0%....50%....100% - 10 passes
==PROF== Profiling "sm80_xmma_sparse_gemm_f16f16_..." - 4: 0%....50%....100% - 10 passes
==PROF== Profiling "sm80_xmma_sparse_gemm_f16f16_..." - 5: 0%....50%....100% - 10 passes
==PROF== Profiling "sm80_xmma_sparse_gemm_f16f16_..." - 6: 0%....50%....100% - 10 passes
==PROF== Profiling "sm80_xmma_sparse_gemm_f16f16_..." - 7: 0%....50%....100% - 10 passes
==PROF== Profiling "sm80_xmma_sparse_gemm_f16f16_..." - 8: 0%....50%....100% - 10 passes
==PROF== Profiling "sm80_xmma_sparse_gemm_f16f16_..." - 9: 0%....50%....100% - 10 passes
==PROF== Profiling "sm80_xmma_sparse_gemm_f16f16_..." - 10: 0%....50%....100% - 10 passes
==PROF== Profiling "sm80_xmma_sparse_gemm_f16f16_..." - 11: 0%....50%....100% - 10 passes
==PROF== Profiling "sm80_xmma_sparse_gemm_f16f16_..." - 12: 0%....50%....100% - 10 passes
==PROF== Profiling "sm80_xmma_sparse_gemm_f16f16_..." - 13: 0%....50%....100% - 10 passes
==PROF== Profiling "sm80_xmma_sparse_gemm_f16f16_..." - 14: 0%....50%....100% - 10 passes
==PROF== Profiling "sm80_xmma_sparse_gemm_f16f16_..." - 15: 0%....50%....100% - 10 passes
==PROF== Profiling "sm80_xmma_sparse_gemm_f16f16_..." - 16: 0%....50%....100% - 10 passes
==PROF== Profiling "sm80_xmma_sparse_gemm_f16f16_..." - 17: 0%....50%....100% - 10 passes
==PROF== Profiling "sm80_xmma_sparse_gemm_f16f16_..." - 18: 0%....50%....100% - 10 passes
==PROF== Profiling "sm80_xmma_sparse_gemm_f16f16_..." - 19: 0%....50%....100% - 10 passes
==PROF== Profiling "sm80_xmma_sparse_gemm_f16f16_..." - 20: 0%....50%....100% - 10 passes
==PROF== Profiling "sm80_xmma_sparse_gemm_f16f16_..." - 21: 0%....50%....100% - 10 passes
==PROF== Profiling "sm80_xmma_sparse_gemm_f16f16_..." - 22: 0%....50%....100% - 10 passes
==PROF== Profiling "sm80_xmma_sparse_gemm_f16f16_..." - 23: 0%....50%....100% - 10 passes
==PROF== Profiling "sm80_xmma_sparse_gemm_f16f16_..." - 24: 0%....50%....100% - 10 passes
#include "cublas_utils.h"
#include <cstdio>  // printf
#include <cstdlib> // std::rand
#include <cublas_v2.h>
#include <cuda_runtime_api.h> // cudaMalloc, cudaMemcpy, etc.
#include <cusparseLt.h>       // cusparseLt header
#define CHECK_CUDA(func)                                                       \
        cudaError_t status = (func);                                           \
        if (status != cudaSuccess) {                                           \
            printf("CUDA API failed at line %d with error: %s (%d)\n",         \
                   __LINE__, cudaGetErrorString(status), status);              \
            return EXIT_FAILURE;                                               \
#define CHECK_CUSPARSE(func)                                                   \
        cusparseStatus_t status = (func);                                      \
        if (status != CUSPARSE_STATUS_SUCCESS) {                               \
            printf("CUSPARSE API failed at line %d with error: %s (%d)\n",     \
                   __LINE__, cusparseGetErrorString(status), status);          \
constexpr int EXIT_UNSUPPORTED = 2;
int main(int argc, char **argv) {
    int major_cc, minor_cc;
    CHECK_CUDA(
        cudaDeviceGetAttribute(&major_cc, cudaDevAttrComputeCapabilityMajor, 0))
    CHECK_CUDA(
        cudaDeviceGetAttribute(&minor_cc, cudaDevAttrComputeCapabilityMinor, 0))
    if (!(major_cc == 8 && minor_cc == 0) &&
        !(major_cc == 8 && minor_cc == 6) &&
        !(major_cc == 8 && minor_cc == 9)) {
        std::printf("\ncusparseLt is supported only on GPU devices with"
                    " compute capability == 8.0, 8.6, 8.9 current: %d.%d\n\n",
                    major_cc, minor_cc);
        return EXIT_UNSUPPORTED;
    // Host problem definition, row-major order
    // bigger sizes may require dynamic allocations
    int m = atoi(argv[1]);
    int n = atoi(argv[3]);
    int k = atoi(argv[2]);
    auto order = CUSPARSE_ORDER_ROW;
    auto opA = CUSPARSE_OPERATION_NON_TRANSPOSE;
    auto opB = CUSPARSE_OPERATION_NON_TRANSPOSE;
    auto type = CUDA_R_16F;
    auto compute_type = CUSPARSE_COMPUTE_16F;
    bool is_rowmajor = (order == CUSPARSE_ORDER_ROW);
    bool isA_transposed = (opA != CUSPARSE_OPERATION_NON_TRANSPOSE);
    bool isB_transposed = (opB != CUSPARSE_OPERATION_NON_TRANSPOSE);
    auto num_A_rows = (isA_transposed) ? k : m;
    auto num_A_cols = (isA_transposed) ? m : k;
    auto num_B_rows = (isB_transposed) ? n : k;
    auto num_B_cols = (isB_transposed) ? k : n;
    auto num_C_rows = m;
    auto num_C_cols = n;
    unsigned alignment = 16;
    auto lda = (is_rowmajor) ? num_A_cols : num_A_rows;
    auto ldb = (is_rowmajor) ? num_B_cols : num_B_rows;
    auto ldc = (is_rowmajor) ? num_C_cols : num_C_rows;
    auto A_height = (is_rowmajor) ? num_A_rows : num_A_cols;
    auto B_height = (is_rowmajor) ? num_B_rows : num_B_cols;
    auto C_height = (is_rowmajor) ? num_C_rows : num_C_cols;
    auto A_size = A_height * lda * sizeof(__half);
    auto B_size = B_height * ldb * sizeof(__half);
    auto C_size = C_height * ldc * sizeof(__half);
    // __half hA[m * k];
    __half *hA = (__half *)malloc(sizeof(__half) * m * k);
    // __half hB[k * n];
    __half *hB = (__half *)malloc(sizeof(__half) * k * n);
    // __half hC[m * n] = {};
    __half *hC = (__half *)malloc(sizeof(__half) * m * n);
    memset(hC, 0, sizeof(__half) * m * n);
    for (int i = 0; i < m * k; i++)
        hA[i] = static_cast<__half>(static_cast<float>(std::rand() % 10));
    for (int i = 0; i < k * n; i++)
        hB[i] = static_cast<__half>(static_cast<float>(std::rand() % 10));
    float alpha = 1.0f;
    float beta = 0.0f;
    // Device memory management
    __half *dA, *dB, *dC, *dD, *dA_compressed;
    int *d_valid;
    CHECK_CUDA(cudaMalloc((void **)&dA, A_size))
    CHECK_CUDA(cudaMalloc((void **)&dB, B_size))
    CHECK_CUDA(cudaMalloc((void **)&dC, C_size))
    CHECK_CUDA(cudaMalloc((void **)&d_valid, sizeof(int)))
    dD = dC;
    CHECK_CUDA(cudaMemcpy(dA, hA, A_size, cudaMemcpyHostToDevice))
    CHECK_CUDA(cudaMemcpy(dB, hB, B_size, cudaMemcpyHostToDevice))
    CHECK_CUDA(cudaMemcpy(dC, hC, C_size, cudaMemcpyHostToDevice))
    cusparseLtHandle_t handle;
    cusparseLtMatDescriptor_t matA, matB, matC;
    cusparseLtMatmulDescriptor_t matmul;
    cusparseLtMatmulAlgSelection_t alg_sel;
    cusparseLtMatmulPlan_t plan;
    cudaStream_t stream = nullptr;
    CHECK_CUSPARSE(cusparseLtInit(&handle))
    // matrix descriptor initialization
    CHECK_CUSPARSE(cusparseLtStructuredDescriptorInit(
        &handle, &matA, num_A_rows, num_A_cols, lda, alignment, type, order,
        CUSPARSELT_SPARSITY_50_PERCENT))
    CHECK_CUSPARSE(cusparseLtDenseDescriptorInit(
        &handle, &matB, num_B_rows, num_B_cols, ldb, alignment, type, order))
        &handle, &matC, num_C_rows, num_C_cols, ldc, alignment, type, order))
    // matmul, algorithm selection, and plan initialization
    CHECK_CUSPARSE(cusparseLtMatmulDescriptorInit(
        &handle, &matmul, opA, opB, &matA, &matB, &matC, &matC, compute_type))
    CHECK_CUSPARSE(cusparseLtMatmulAlgSelectionInit(
        &handle, &alg_sel, &matmul, CUSPARSELT_MATMUL_ALG_DEFAULT))
    CHECK_CUSPARSE(cusparseLtMatmulPlanInit(&handle, &plan, &matmul, &alg_sel))
    // Prune the A matrix (in-place) and check the correctness
    CHECK_CUSPARSE(cusparseLtSpMMAPrune(&handle, &matmul, dA, dA,
                                        CUSPARSELT_PRUNE_SPMMA_TILE, stream))
    CHECK_CUSPARSE(
        cusparseLtSpMMAPruneCheck(&handle, &matmul, dA, d_valid, stream))
    int is_valid;
    CHECK_CUDA(cudaMemcpyAsync(&is_valid, d_valid, sizeof(int),
                               cudaMemcpyDeviceToHost, stream))
    CHECK_CUDA(cudaStreamSynchronize(stream))
    if (is_valid != 0) {
        std::printf("!!!! The matrix has been pruned in a wrong way. "
                    "cusparseLtMatmul will not provide correct results\n");
    // Compress the A matrix
    size_t compressed_size, compressed_buffer_size;
    void *dA_compressedBuffer;
    CHECK_CUSPARSE(cusparseLtSpMMACompressedSize(
        &handle, &plan, &compressed_size, &compressed_buffer_size))
    CHECK_CUDA(cudaMalloc((void **)&dA_compressed, compressed_size))
    CHECK_CUDA(
        cudaMalloc((void **)&dA_compressedBuffer, compressed_buffer_size))
    CHECK_CUSPARSE(cusparseLtSpMMACompress(&handle, &plan, dA, dA_compressed,
                                           dA_compressedBuffer, stream))
    // Search the best kernel
    int num_streams = 0;
    cudaStream_t *streams = nullptr;
    CHECK_CUSPARSE(cusparseLtMatmulSearch(&handle, &plan, &alpha, dA_compressed,
                                          dB, &beta, dC, dD, nullptr, streams,
                                          num_streams))
    // otherwise, it is possible to set it directly:
    // int alg = 0;
    // CHECK_CUSPARSE( cusparseLtMatmulAlgSetAttribute(
    //                                        &handle, &alg_sel,
    //                                        CUSPARSELT_MATMUL_ALG_CONFIG_ID,
    //                                        &alg, sizeof(alg)))
    size_t workspace_size;
    CHECK_CUSPARSE(
        cusparseLtMatmulGetWorkspace(&handle, &plan, &workspace_size))
    void *d_workspace;
    CHECK_CUDA(cudaMalloc((void **)&d_workspace, workspace_size))
    // Perform the matrix multiplication
    CHECK_CUSPARSE(cusparseLtMatmul(&handle, &plan, &alpha, dA_compressed, dB,
                                    &beta, dC, dD, d_workspace, streams,
                                    num_streams))
    // destroy plan and handle
    CHECK_CUSPARSE(cusparseLtMatDescriptorDestroy(&matA))
    CHECK_CUSPARSE(cusparseLtMatDescriptorDestroy(&matB))
    CHECK_CUSPARSE(cusparseLtMatDescriptorDestroy(&matC))
    CHECK_CUSPARSE(cusparseLtMatmulPlanDestroy(&plan))
    CHECK_CUSPARSE(cusparseLtDestroy(&handle))
    // device result check
    // matrix A has been pruned
    CHECK_CUDA(cudaMemcpy(hA, dA, A_size, cudaMemcpyDeviceToHost))
    CHECK_CUDA(cudaMemcpy(hC, dC, C_size, cudaMemcpyDeviceToHost))
    bool A_std_layout = (is_rowmajor != isA_transposed);
    bool B_std_layout = (is_rowmajor != isB_transposed);
    int correct = 1;
    if (correct)
        std::printf("matmul_example test PASSED\n");
    else
        std::printf("matmul_example test FAILED: wrong result\n");
    // device memory deallocation
    CHECK_CUDA(cudaFree(dA_compressed))
    CHECK_CUDA(cudaFree(dA))
    CHECK_CUDA(cudaFree(dB))
    CHECK_CUDA(cudaFree(dC))
    CHECK_CUDA(cudaFree(d_valid))
    CHECK_CUDA(cudaFree(d_workspace))
    CHECK_CUDA(cudaFree(dA_compressedBuffer))
    return EXIT_SUCCESS;
My first suggestion is to switch to the latest version https://developer.nvidia.com/cusparselt-downloads. Second, regarding kernel execution times, please note that in some cases the tuning routine may evaluate the two kernel mode, while Nsight Compute reports a single kernel evaluation. This can lead to misleading results.
Thanks! I will try the latest cuSPARSELt.
But I am wondering about this! Could you please provide more details or clarification on what is meant by “two kernel mode”?
The two-kernel mode is more of an implementation detail, but I can briefly explain the idea. Suppose you have a small matrix, instead of assigning a group of threads to the output tile, you can divide a row (or a set of rows) between different groups of threads. Then you need a second kernel to accumulate the result.
