I recently met a problem: cusparseSpMV_bufferSize() returns a bufferSize of 0 byte, with a CUSPARSE_STATUS_SUCCESS return value. This happens with a Sliced-ELL format matA. I’ve checked all the inputs and they are all correctly initialized before passing to this function.
Then I just allocate a random size of buffer(e.g. 10000 bytes) on the device and pass it to do cusparseSpMV. The solve is successful.
Then, I notice in the documentation it states:
The routine requires extra storage for CSR/CSC format (all algorithms) and for COO format with CUSPARSE_SPMV_COO_ALG2 algorithm.
Does it mean that for Sliced-ELL format, it actually doesn’t need extra workspace, which leads to a 0 bufferSize returned? Thanks in advance.
Hi @malmasri , I do have another question about the SELL SpMV.
So in some cases, the matrixA is padded with some extra zero-rows at the end, which means we have to pad the right-hand-side vector as well with some extra zeros in the end. But apparently, padding rhs is not requested from cusparseSpMV routine. So I assume that it is done internally. Can you confirm it? Or do I misunderstand somehow. Thank you a lot.
