HI anyone
I transplanted the code to version R32.4.2 of NX module, the driver was loaded successfully, I could see the device /dev/video0, when I played it with nvgstcaption-1.0, the following error occurred.
Can anyone guide me :How should I analyze what went wrong。
[ 159.043486] imx390 0-001a: probing v4l2 sensor.
[ 159.049045] imx390 0-001a: tegracam sensor driver:imx390_v2.0.6
[ 159.049094] tegra194-vi5 15c10000.vi: subdev imx390 0-001a bound
[ 159.050387] imx390 0-001a: Detected IMX390 sensor
[ 161.575432] tegra-i2c 3160000.i2c: no acknowledge from address 0x1a
[ 178.803973] [RCE] WARNING: t194/isp5.c:901 [config_channel] “All error notifications not enabled: correctable=0x00 uncorrectable=0x00”
[ 179.139800] [RCE] vi5_hwinit: firmware CL2018101701 protocol version 2.2
[ 182.837933] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 182.838007] fence timeout on [ffffffc1761276c0] after 1500ms
[ 182.838056] name=[nvhost_sync:41], current value=0 waiting value=1
[ 182.838061] ---- mlocks ----
[ 182.838247] tegra194-vi5 15c10000.vi: vi capture get status failed
[ 182.839947] ---- syncpts ----
[ 182.839962] id 2 (disp_a) min 644 max 644 refs 1 (previous client : )
[ 182.839968] id 3 (disp_b) min 2 max 2 refs 1 (previous client : )
[ 182.839975] id 4 (disp_c) min 2 max 2 refs 1 (previous client : )
[ 182.839999] id 8 (vblank0) min 10321 max -4 refs 1 (previous client : )
[ 182.840016] id 18 (gv11b_511) min 10871 max 10871 refs 1 (previous client : )
[ 182.840021] id 19 (gv11b_510) min 8 max 8 refs 1 (previous client : )
[ 182.840028] id 20 (gv11b_509) min 1726 max 1726 refs 1 (previous client : gv11b_509)
[ 182.840048] id 34 (gv11b_507_user) min 29 max 0 refs 1 (previous client : )
[ 182.840063] id 44 (gv11b_503) min 4 max 4 refs 1 (previous client : )
[ 182.840068] id 45 (gv11b_502) min 3 max 3 refs 1 (previous client : )
[ 182.840074] id 46 (gv11b_501) min 3 max 3 refs 1 (previous client : )
[ 182.840079] id 47 (gv11b_500) min 3 max 3 refs 1 (previous client : )
[ 182.840085] id 48 (gv11b_499) min 3 max 3 refs 1 (previous client : )
[ 182.850537] ---- channels ----
[ 182.850570]
channel 2 - 15820000.se
[ 182.850575] NvHost basic channel registers:
[ 182.850582] CMDFIFO_STAT_0: 00002040
[ 182.850588] CMDFIFO_RDATA_0: 0819400c
[ 182.850597] CMDP_OFFSET_0: 00000000
[ 182.850602] CMDP_CLASS_0: 00000000
[ 182.850607] CHANNELSTAT_0: 00000000
[ 182.850611] The CDMA sync queue is empty.
[ 182.850621]
channel 3 - 15830000.se
[ 182.850624] NvHost basic channel registers:
[ 182.850629] CMDFIFO_STAT_0: 00002040
[ 182.850634] CMDFIFO_RDATA_0: 22109200
[ 182.850641] CMDP_OFFSET_0: 00000000
[ 182.850646] CMDP_CLASS_0: 00000000
[ 182.850651] CHANNELSTAT_0: 00000000
[ 182.850654] The CDMA sync queue is empty.
[ 182.850663]
channel 4 - 15840000.se
[ 182.850667] NvHost basic channel registers:
[ 182.850672] CMDFIFO_STAT_0: 00002040
[ 182.850677] CMDFIFO_RDATA_0: 01018593
[ 182.850683] CMDP_OFFSET_0: 00000000
[ 182.850688] CMDP_CLASS_0: 00000000
[ 182.850692] CHANNELSTAT_0: 00000000
[ 182.850696] The CDMA sync queue is empty.
[ 182.850707]
---- host general irq ----
[ 182.850713] sync_intc0mask = 0x00000001
[ 182.850718] sync_intmask = 0x50000003
[ 182.850722]
---- host syncpt irq mask ----
[ 182.850725]
---- host syncpt irq status ----
[ 182.850731] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ 182.850736] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 182.850741] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 182.850746] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 182.850751] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 182.850757] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 182.850762] syncpt_thresh_cpu0_int_status(6) = 0x00000000
[ 182.850767] syncpt_thresh_cpu0_int_status(7) = 0x00000000
[ 182.850772] syncpt_thresh_cpu0_int_status(8) = 0x00000000
[ 182.850777] syncpt_thresh_cpu0_int_status(9) = 0x00000000
[ 182.850783] syncpt_thresh_cpu0_int_status(10) = 0x00000000
[ 182.850788] syncpt_thresh_cpu0_int_status(11) = 0x00000000
[ 182.850793] syncpt_thresh_cpu0_int_status(12) = 0x00000000
[ 182.850798] syncpt_thresh_cpu0_int_status(13) = 0x00000000
[ 182.850803] syncpt_thresh_cpu0_int_status(14) = 0x00000000
[ 182.850808] syncpt_thresh_cpu0_int_status(15) = 0x00000000
[ 182.850813] syncpt_thresh_cpu0_int_status(16) = 0x00000000
[ 182.850818] syncpt_thresh_cpu0_int_status(17) = 0x00000000
[ 182.850823] syncpt_thresh_cpu0_int_status(18) = 0x00000000
[ 182.850828] syncpt_thresh_cpu0_int_status(19) = 0x00000000
[ 182.850833] syncpt_thresh_cpu0_int_status(20) = 0x00000000
[ 182.850838] syncpt_thresh_cpu0_int_status(21) = 0x00000000
[ 184.373128] fence timeout on [ffffffc1d0e8c480] after 1500ms
[ 184.373141] name=[nvhost_sync:41], current value=0 waiting value=9
[ 184.373149] ---- mlocks ----
[ 184.373192] ---- syncpts ----
[ 184.373206] id 2 (disp_a) min 661 max 661 refs 1 (previous client : )
[ 184.373212] id 3 (disp_b) min 2 max 2 refs 1 (previous client : )
[ 184.373218] id 4 (disp_c) min 2 max 2 refs 1 (previous client : )
[ 184.373242] id 8 (vblank0) min 10413 max -4 refs 1 (previous client : )
[ 184.373260] id 18 (gv11b_511) min 11217 max 11217 refs 1 (previous client : )
[ 184.373266] id 19 (gv11b_510) min 8 max 8 refs 1 (previous client : )
[ 184.373272] id 20 (gv11b_509) min 1771 max 1771 refs 1 (previous client : gv11b_509)
[ 184.373292] id 34 (gv11b_507_user) min 29 max 0 refs 1 (previous client : )
[ 184.373307] id 44 (gv11b_503) min 4 max 4 refs 1 (previous client : )
[ 184.373313] id 45 (gv11b_502) min 3 max 3 refs 1 (previous client : )
[ 184.373318] id 46 (gv11b_501) min 3 max 3 refs 1 (previous client : )
[ 184.373324] id 47 (gv11b_500) min 3 max 3 refs 1 (previous client : )
[ 184.373330] id 48 (gv11b_499) min 3 max 3 refs 1 (previous client : )
[ 184.374074] ---- channels ----
[ 184.374113]
[ 184.374117] NvHost basic channel registers:
[ 184.374124] CMDFIFO_STAT_0: 00002040
[ 184.374129] CMDFIFO_RDATA_0: 0819400c
[ 184.374137] CMDP_OFFSET_0: 00000000
[ 184.374142] CMDP_CLASS_0: 00000000
[ 184.374146] CHANNELSTAT_0: 00000000
[ 184.374150] The CDMA sync queue is empty.
[ 184.374160]
[ 184.374164] NvHost basic channel registers:
[ 184.374169] CMDFIFO_STAT_0: 00002040
[ 184.374174] CMDFIFO_RDATA_0: 22109200
[ 184.374180] CMDP_OFFSET_0: 00000000
[ 184.374185] CMDP_CLASS_0: 00000000
[ 184.374189] CHANNELSTAT_0: 00000000
[ 184.374193] The CDMA sync queue is empty.
[ 184.374202]
[ 184.374206] NvHost basic channel registers:
[ 184.374210] CMDFIFO_STAT_0: 00002040
[ 184.374215] CMDFIFO_RDATA_0: 01018593
[ 184.374222] CMDP_OFFSET_0: 00000000
[ 184.374226] CMDP_CLASS_0: 00000000
[ 184.374231] CHANNELSTAT_0: 00000000
[ 184.374235] The CDMA sync queue is empty.
[ 184.374246]
[ 184.374251] sync_intc0mask = 0x00000001
[ 184.374256] sync_intmask = 0x50000003
[ 184.374260]
[ 184.374263]
[ 184.374269] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ 184.374274] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 184.374280] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 184.374285] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 184.374290] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 184.374295] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 184.374300] syncpt_thresh_cpu0_int_status(6) = 0x00000000
[ 184.374306] syncpt_thresh_cpu0_int_status(7) = 0x00000000
[ 184.374311] syncpt_thresh_cpu0_int_status(8) = 0x00000000
[ 184.374316] syncpt_thresh_cpu0_int_status(9) = 0x00000000
[ 184.374321] syncpt_thresh_cpu0_int_status(10) = 0x00000000
[ 184.374326] syncpt_thresh_cpu0_int_status(11) = 0x00000000
[ 184.374331] syncpt_thresh_cpu0_int_status(12) = 0x00000000
[ 184.374336] syncpt_thresh_cpu0_int_status(13) = 0x00000000
[ 184.374342] syncpt_thresh_cpu0_int_status(14) = 0x00000000
[ 184.374347] syncpt_thresh_cpu0_int_status(15) = 0x00000000
[ 184.374352] syncpt_thresh_cpu0_int_status(16) = 0x00000000
[ 184.374357] syncpt_thresh_cpu0_int_status(17) = 0x00000000
[ 184.374362] syncpt_thresh_cpu0_int_status(18) = 0x00000000
[ 184.374367] syncpt_thresh_cpu0_int_status(19) = 0x00000000
[ 184.374372] syncpt_thresh_cpu0_int_status(20) = 0x00000000
[ 184.374377] syncpt_thresh_cpu0_int_status(21) = 0x00000000
