we are designing custom carrier board with Xavier NX module.
Is it possible to generate basic custom board dts with help any existing tool/script and later i can edit as per the requirement? what are the best possible ways to ease the process of generating dts for custom board
Thanks,
Arun
Hi Arun,
Unfortunately, there is no such method. There are too many users with multiple kinds of designs, so there is no dts file that can 100% satisfies the need.
Please learn to modify the nvidia official dtb file to match your board.
@WayneWWW
Thank you for the reply.
you mean to say use “tegra194-p3668-all-p3509-0000.dtb” devkit kit dtb and convert this dtb to dts and make changes as per the custom board. Is my understanding correct
also one more query,
for MB1 Configuration Changes,
I have downloaded the Xavier NX pinumux table, updated as per my board and generated .dtsi from it. Now while converting dtsi to .cfg, do i need to follow any naming convention and how these updated configurations are picked
Thanks,
Arun
Hi Arun,
Yes, that’ right.
It depends on you. If you have a new BCT file name, you have to go to the board config under Linux_for_Tegra to modify the config name to your own file.
@WayneWWW
How to validate whether new configurations are applied or not
If this is pinmux config, you could use tool devmem or devmem2 to read the register value and see if it takes effect.
@WayneWWW
@kayccc
@JerryChang
I am planning to use R32.4.2 for my custom board (with Xavier NX production SoMs) but R32.4.2 seems developer preview release. Any issues with this version?can it be used for production releases
Thanks,
Arun
hello arun_dasari,
FYI,
according to NVIDIA JetPack SDK, JetPack-4.4 (l4t-r32.4.3) is the latest production release, supporting all Jetson modules.
you may work with JetPack-4.4 for your production release candidate.
thanks
seems both are Jetpack-4.4, Interested to know difference between (l4t-r32.4.2)Developer preview release and (l4t-r32.4.3)GA release
Thanks,
Arun
