Custom Datasets for Digits
I was wondering what the best two get custom data sets to be used with Digits Object Detection. I currently have several data sets that has a .tsv file of labels for all the images. It appears that Digits requires two folders separated with one folder containing images, and the other folder containing labels with the same name.
Is there a proper way to convert data sets to be used with Digits?
The object detection task is designed to follow a commonly used format, like the one in KITTI dataset. There may be several open source tools to convert your datasets into KITTI format.
You can find more information on this official KITTI webpage [url]The KITTI Vision Benchmark Suite.
I used a tool called alps labelling tool. Pls try it.
