Deepstream automatically crops the input frame using bbox from pgie and run sgie on this cropped frame. I don’t want it to behave like that. After pgie, I have landmarks output and I will use them to do warpaffine on full frame, this will output a cropped frame without touching the bbox, And I want sgie to run on this cropped frame instead the one cropped using bbox.
Please tell me if this is possible or not. If possible, can I have some suggestions on how to do it properly? Thank you.
Sorry, I don’t see my case there. I want to discuss a little about SGIE.
In official document : Secondary mode: Operates on objects added in the meta by upstream components
Normally deepstream automatically uses the bbox from PGIE’s output to crop the full frame into a region and SGIE will run on this region. Do I understand it correctly?
Correct, so the sgie will perform on the modified bbox if you change the bbox on a probe which installed on the sink pad of sgie, that’s the reason why I give you above sample for your reference
My current approach is trying to do affine transform on full frame so that the sgie can crop it correctly. But I also want to keep the original frame for display purpose.
Hope you can understand it and give me some help. Thank you.
