Custom Kernel does't boot
Sorry for my question.
I’m trying to build a kernel for Orin NX.
head -n1 /etc/nv_tegra_release
R36 (release), REVISION: 3.0, GCID: 36191598, BOARD: generic, EABI: aarch64, DATE: Mon May 6 17:34:21 UTC 2024
My steps are like this:
  1. Download sources: https://developer.nvidia.com/downloads/embedded/l4t/r36_release_v3.0/sources/public_sources.tbz2
  2. Unpack archive.
  3. cd Linux_for_Tegra/source/
  4. Unpack
tar xf kernel_src.tbz2
tar xf kernel_oot_modules_src.tbz2
tar xf nvidia_kernel_display_driver_source.tbz2
  1. Create dirs
mkdir -p “${HOME}/build/kernel”
mkdir -p “${HOME}/build/modules”
mkdir -p “${HOME}/build/firmware”
  1. Add config
zcat /proc/config.gz > “${HOME}/build/kernel/.config”
  1. Edit config
    CONFIG_LOCALVERSION=“-custom”
    CONFIG_USB_MON=m
  2. Set environments
export TOP=“$(pwd)/kernel/kernel-jammy-src/”
export TEGRA_KERNEL_OUT=“${HOME}/build/kernel”
export TEGRA_MODULES_OUT=“${HOME}/build/modules”
export TEGRA_FIRMWARE_OUT=“${HOME}/build/firmware”
export TEGRA_BUILD=“${HOME}/build”
  1. Steps for building
cd $TOP
make -j $(nproc) O=$TEGRA_KERNEL_OUT Image
make -j $(nproc) O=$TEGRA_KERNEL_OUT modules_prepare
make -j $(nproc) O=$TEGRA_KERNEL_OUT dtbs
make -j $(nproc) O=$TEGRA_KERNEL_OUT INSTALL_MOD_PATH=$TEGRA_MODULES_OUT
make -j $(nproc) O=$TEGRA_KERNEL_OUT INSTALL_FW_PATH=$TEGRA_FIRMWARE_OUT
make -j $(nproc) O=$TEGRA_KERNEL_OUT INSTALL_MOD_PATH=$TEGRA_MODULES_OUT modules_install
  1. Copy files
sudo cp ~/build/kernel/arch/arm64/boot/Image /boot/Image-custom
sudo rsync -al /home/user/build/modules/lib/modules/5.15.136-custom /lib/modules/.
  1. Edit initrd. Unpack, edit and repack.
    Rename usr/lib/modules/5.15.136-tegra to usr/lib/modules/5.15.136-custom
  2. Add new custom record in extlinux.conf
TIMEOUT 30
DEFAULT primary
MENU TITLE L4T boot options
LABEL primary
      MENU LABEL primary kernel
      LINUX /boot/Image
      INITRD /boot/initrd
      APPEND ${cbootargs} root=PARTUUID=5b56fa72-e434-49a9-805a-a9256fcbdcbd rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb video=efifb:off console=tty0 nv-auto-config
LABEL custom
      MENU LABEL custom kernel
      LINUX /boot/Image-custom
      INITRD /boot/initrd-custom
  1. When Jetson boot i select custom kernel but Jetson freezing and does’t boot.
What am I doing wrong??
custom_kernle.log (25.6 KB)
I don’t know if this has any dependencies. Did you edit this directly, or did you use a dependency-aware editor like menuconfig or nconfig?
CONFIG_USB_MON=m
(this quite possibly does not matter, but I also don’t know if this has dependencies)
I do like your build steps, the details are correct. Keep in mind that some kernels though will need a particular compiler release to function correctly. Official docs normally talk about this for a cross compiler release. I do not know for this code what the required compiler release is, but you might check on the system it was compiled on (it seems to be native compile directly on the Jetson) with “gcc --version”. Then compare with the L4T release docs about anything that mentions a compiler version. Find the L4T release with “head -n 1 /etc/nv_tegra_release”. Then go here for docs specific to that release:
https://developer.nvidia.com/linux-tegra
The initrd might be the issue, or it might not. Note that when you install a full kernel that you need to also install the newly built modules (there might be exceptions, but it is not safe to assume the modules will work when the CONFIG_LOCALVERSION has changed). So instead of just renaming the 5.15.136-tegra to 5.15.136-custom and adding the one new module there I would recommend completely installing the entire new set of modules into the initrd at the new location. Overall I think what you have is correct.
Your UEFI is not set to provide debug information, which might help, but it seems that the kernel starts normally so that probably does not matter. The log stops when the mouse loads, but it succeeded with the keyboard, so at least part of the USB HID is working.
I have not looked at the module you are using so I can’t say what the requirements are. However, do check to see if it has dependencies. Also I would try to boot without that module being available; this would cause it to fail to load, which is ok because boot does not depend on that feature (in fact you might not have needed the module in the initrd unless you wanted its use to become available immediately). Once booted, if it “fails to fail”, then you’re one step closer. Then attempt to insmod the module manually and see what happens (you might want to monitor “dmesg --follow” as you insmod).
Incidentally, is this all on eMMC? Or perhaps it is an SD card model? There are differences in cases where you have optional boot devices.
Continuing the discussion from Custom Kernel does't boot:
I edit .config file in text editor vim.
I build kernel on Jetson. Native compilation without cross compilling.
I using nvme drive. I using not devkit
gcc --version
gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0
Thanks for the tips. I looked at my steps and saw some mistakes.
Repack initrd without root user.
Try nconfig for add module.
Try replacing the modules directory in the initrd and the kernel started.
Now there are other problems:
The network does not work and the graphics do not work correctly.
In the original modules (-tegra) there is an updates directory and there are modules there that are not in the modules I built. Such as nvgpu.ko and others.
When I load a module (usbmon) via insmod. Dmesg does not show anything but when loading the module via depmod, an error is displayed:
Bad version passed usbmon.
lsmod show load module.
Why not build additional modules (nvgpu) I copied the .config file?
How to build kernel with all current modules?
This latter part is a question perhaps @KevinFFF or @WayneWWW can answer:
I’m not certain if nvgpu.ko is in mainline now, or if it is still external.
If depmod fails in this manner, then it could be a configuration (during compile) issue. On your original source I will recommend you start with “make mrproper” (and if root owns anything, then perform this as root). Then start over using that as your $TOP (and only then setting up your environment variables). It seems like perhaps there is still something built based on a previous config. If the modules were built against the kernel that you also just built, then I would not expect there to be a depmod issue.
Do you run these steps on host PC or Jetson device?
To build custom kernel, please refer to Kernel Customization — NVIDIA Jetson Linux Developer Guide 1 documentation for details.
