Custom model on Jetson Nano
Hi!
I’m currently working on an object detection problem to detect garbage bags using a Jetson nano and a webcam. I previously trained a custom model using MobileNet-V2 320x320. I exported it as both saved model and tflite format. However I haven’t been able to import it to DetectNet even though I converted it to ONNX format using tf2onnx repository.
When I pass the path to the model to DetectNet I get this error:
[TRT] ModelImporter.cpp:773: While parsing node number 265 [TopK → “TopK__875:0”]:
[TRT] ModelImporter.cpp:774: — Begin node —
[TRT] ModelImporter.cpp:775: input: “GatherND__867:0”
input: “Cast__873:0”
output: “TopK__875:0”
output: “TopK__875:1”
op_type: “TopK”
domain: “”
[TRT] ModelImporter.cpp:776: — End node —
[TRT] ModelImporter.cpp:779: ERROR: builtin_op_importers.cpp:4519 In function importTopK:
[8] Assertion failed: (inputs.at(1).is_weights()) && “This version of TensorRT only supports input K as an initializer.”
[TRT] failed to parse ONNX model ‘/home/colbits/model/onnx_model/model.onnx’
[TRT] device GPU, failed to load /home/colbits/model/onnx_model/model.onnx
[TRT] detectNet – failed to initialize.
I tried this solution but then I get this error by running the create_onnx.py:
AttributeError: ‘NoneType’ object has no attribute ‘op’
Can you help with this?
Which JetPack version do you use?
If you are not using our latest JetPack 4.6.3, could you upgrade and try it again?
