Besides class, top, left, width, height, and conf, my model output 5 landmarks. I want to make a custom NvDsInferObjectDetectionInfo to take these landmarks in. Is this possible? Is there another way to have that output inside frame meta without using NvDsInferObjectDetectionInfo?
• DeepStream Version
• TensorRT Version
Does this require deepstream 6.0? What thing is not compatible with deepstream 5.1?
If yes, do you know when version 6.0 will be released?
No, also you can do it on DS5.1.
BTW, you can access 6.0 here https://developer.nvidia.com/deepstream-sdk-6.0-members-page#
I can’t find the following path: “cv/faciallandmarks/FacialLandmarks.h”. I’m using deepstream-triton docker image and deepstream 5.1. Can you please tell me where that file located?
You should use DS6.0
