• Hardware Platform (Jetson / GPU) Jetson-AGX Xavier
• DeepStream Version 6.2
• JetPack Version (valid for Jetson only) 5.1
• TensorRT Version 5.1
• Issue Type( questions, new requirements, bugs) bugs
Install Deepstream SDK v6.2 as in the Quickstart Guide - Method #2 .
Then go to cd /opt/nvidia/deepstream/deepstream/sources/libs/nvmsgconv.
Install pre-requisites as in the README file:
sudo apt-get install libglib2.0-dev libjson-glib-dev uuid-dev libyaml-cpp-dev protobuf-compiler
See the README file to learn that
For payload generation using protobuf, proto.schema is provided within deepstream_schema directory.
Run sudo make and see the error:
protoc -I./deepstream_schema --cpp_out=./deepstream_schema/ Makefile
Makefile: File does not reside within any path specified using --proto_path (or -I). You must specify a --proto_path which encompasses this file. Note that the proto_path must be an exact prefix of the .proto file names -- protoc is too dumb to figure out when two paths (e.g. absolute and relative) are equivalent (it's harder than you think).
make: *** [Makefile:53: deepstream_schema/schema.pb.cc] Error 1
Then go to cd deepsteam_schema/ to see there’s no schema.pb.cc file inside, only deepstream_schema.cpp, deepstream_schema.h, dsmeta_payload.cpp, eventmsg_payload.cpp.
• Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description) Not applicable.
I wanted to create a custom payload generation library (as described here in the Message Converter Group parameter msg-conv-msg2p-lib).
I edited the eventmsg_payload.cpp but was unable to compile using make as the file is missing. See the details above.
What should I do? Is there something I’m not seeing?
