Custom sgie model is not working in graph-composer
I am tryng to use custom model as sgie in graph-composer
• Hardware Platform (Jetson / GPU) - GPU
• DeepStream Version - 6.2
• TensorRT Version : 8.5
• NVIDIA GPU Driver Version (valid for GPU only) :2.5
• Issue Type( questions, new requirements, bugs) bug
I can use pgie as a Peoplenet model, but I’m having trouble adding sgie as a custom model on a person label. I added config and engine files to composer, but it is still functioning normally and not producing any sgie output. just the PeopleNet model with bounding boxes is displayed.
What is your SGIE? What do you want to display with your SGIE’s output?
I have an apparel identification model used as sgie that uses a person label from peoplenet to recognise different types of clothing.
You may prefer my blog related sgie here-
Can you provide your gst-nvinfer configuration files?
yes, Here it is.
config_infer_apparel.txt (3.5 KB)
What are the output layers’ dimensions of your model?
you mean number of classes or categories to predict ?
No. The layers’ names and dimensions.
When we created app we provided dimensions like this
" -d 3,256,256 "
Is this the output layer’s dimension?
yes this is mentioned while training model
Is the output softmax values? If not, you need to customized the classifier’s “parse-classifier-func-name” function.
