• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 6.3
• TensorRT Version
To overcome accuracy issues I’m trying to run a segmenter (peopleSegNet) on the output of a detector (resnet10.caffemodel), I used a detector and segmenter from the python-apps deepstream-segmask and deepstream-test2.
In my pgie I defined process-mode=1 and gie-unique-id = 1 while in the segmenter I set process-mode= 2 and gie-unique-id = 2, also in the segmenter I set operate-on-gie-id=1, it doesn’t work, all I see is bounding boxes around cars and an occasional error message:
[nvds_mask_utils_resize_to_binary_argb32:109]failure: status=-23
libnvosd (63):(ERROR) : ERROR: [nvll_osd_resize_segment_masks_bg]
Attached the code and config files.
thanks
dstest_segmask_config.txt (2.3 KB)
dstest2_pgie_config.txt (3.0 KB)
deepstream_segmask.py.txt (16.6 KB)
