•Hardware Platform (Jetson / GPU) : T4
•DeepStream Version : 5.0
•TensorRT Version : 7
•Cuda Version: 10.2
•Cudnn Version: 7.6.5
•Ubuntu Version: 18.04
•NVIDIA GPU Driver Version: 440.33.01
Hi, I am currently working on a segmentation problem using Deepstream and wants to build the pipeline using python.
So I modified the Deepstream-test1-rtsp-out sample application pipeline, and the current pipeline looks like this:
file-source -> h264-parser -> nvh264-decoder -> nvinfer -> nvsegvisual -> nvvidconv -> nvosd -> nvvidconv_postosd -> caps -> encoder -> rtppay -> udpsink
Basically, I have added nvsegvisual plugin in the pipeline. But I do not get a proper output (pixel size reduced significantly).
I used the Industrial and Semantic models and configuration files. I have attached a screenshot of the output that I get.
Would like to know what extra changes need to be done. Also if there are any guides to build a segmentation pipeline in python in Deepstream.
Thank You!
