I have checked “msg-broker-proto-lib” in configuration file, path of which is the same as the customized libiary compile instruction specified. Am I compile the libiary in a wrong way or missed something to include?
Compile customized libiary using
sudo g++ nvds_mqtt_proto.cpp -I/opt/nvidia/deepstream/deepstream/sources/includes /opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_logger.so /home/nvidia/Downloads/cowtransfer/paho.mqtt.c-master/build/output/libpaho-mqtt3c.so -std=c++11 -fPIC -shared -o /opt/nvidia/deepstream/deepstream-5.0/lib/mqtt.so
And below is what in nvds_mqtt_proto.cpp, which has not been finished.
#include <string.h>
#include <iostream>
#include "nvds_logger.h"
#include "nvds_msgapi.h"
#include "MQTTClient.h"
using namespace std;
#define NVDS_MQTT_LOG_CAT "DSLOG:NVDS_MQTT_PROTO"
#define NVDS_MSGAPI_VERSION "5.0"
#define NVDS_MSGAPI_PROTOCOL "MQTT"
#define QOS 1
#define TIMEOUT 10000L
bool is_valid_mqtt_connection_str(char* connection_str, string& burl, string& bport);
bool is_valid_mqtt_connection_str(char* connection_str, string& burl, string& bport) {
if (connection_str == NULL) {
nvds_log(NVDS_MQTT_LOG_CAT, LOG_ERR, "mqtt connection string cant be NULL");
return false;
string str(connection_str);
size_t n=0;
for(int i=0;i<str.length();i++)
if (str[i]==';')
n++;
if (n < 1) {
nvds_log(NVDS_MQTT_LOG_CAT, LOG_ERR, "MQTT connection string format is invalid.");
return false;
char cp[25];
strcpy(cp,connection_str);
const char sep[2] = ";";
burl = strtok(cp, sep);
bport = strtok(NULL,sep);
if (burl == "" || bport == "") {
nvds_log(NVDS_MQTT_LOG_CAT, LOG_ERR, "Kafka connection string is invalid. hostname or port is empty\n");
return false;
return true;
NvDsMsgApiHandle nvds_msgapi_connect(char* connection_str, nvds_msgapi_connect_cb_t connect_cb, char* config_path) {
nvds_log_open();
string burl = "", bport = "";
if (!is_valid_mqtt_connection_str(connection_str, burl, bport))
return NULL;
MQTTClient client;
MQTTClient_connectOptions conn_opts = MQTTClient_connectOptions_initializer;
int rc;
string address = "tcp://" + burl + ":" + bport;
if ((rc = MQTTClient_create(&client, address.data(), "qwertyuiop1234567890", MQTTCLIENT_PERSISTENCE_NONE, NULL)) != MQTTCLIENT_SUCCESS) {
nvds_log(NVDS_MQTT_LOG_CAT, LOG_ERR, ("Failed to create client, return code " + to_string(rc) + "\n").data());
return NULL;
conn_opts.keepAliveInterval = 20;
conn_opts.cleansession = 1;
if ((rc = MQTTClient_connect(client, &conn_opts)) != MQTTCLIENT_SUCCESS) {
nvds_log(NVDS_MQTT_LOG_CAT, LOG_ERR, ("Failed to connect, return code " + to_string(rc) + "\n").data());
return NULL;
nvds_log(NVDS_MQTT_LOG_CAT, LOG_INFO, "MQTT connection successful\n");
return (NvDsMsgApiHandle)(client);
NvDsMsgApiErrorType nvds_msgapi_subscribe(NvDsMsgApiHandle h_ptr, char** topics, int num_topics, nvds_msgapi_subscribe_request_cb_t cb, void* user_ctx) {
return NVDS_MSGAPI_OK;
NvDsMsgApiErrorType nvds_msgapi_send(NvDsMsgApiHandle h_ptr, char* topic, const uint8_t* payload, size_t nbuf) {
MQTTClient* client = (MQTTClient*)h_ptr;
int rc;
if (h_ptr == NULL) {
nvds_log(NVDS_MQTT_LOG_CAT, LOG_ERR, "MQTT connection handle passed for send() = NULL. Send failed\n");
return NVDS_MSGAPI_ERR;
if (topic == NULL || !strcmp(topic, "")) {
nvds_log(NVDS_MQTT_LOG_CAT, LOG_ERR, "MQTT topic not specified.Send failed\n");
if (payload == NULL || nbuf <= 0) {
nvds_log(NVDS_MQTT_LOG_CAT, LOG_ERR, "MQTT: Either send payload is NULL or payload length <=0. Send failed\n");
MQTTClient_message pubmsg = MQTTClient_message_initializer;
pubmsg.payload = (void*)payload;
pubmsg.payloadlen = nbuf;
pubmsg.qos = QOS;
pubmsg.retained = 0;
MQTTClient_deliveryToken token;
if ((rc = MQTTClient_publishMessage(client, topic, &pubmsg, &token)) != MQTTCLIENT_SUCCESS) {
nvds_log(NVDS_MQTT_LOG_CAT, LOG_DEBUG, "Failed to publish message, return code %d\n", rc);
rc = MQTTClient_waitForCompletion(client, token, TIMEOUT);
NvDsMsgApiErrorType nvds_msgapi_send_async(NvDsMsgApiHandle h_ptr, char* topic, const uint8_t* payload, size_t nbuf, nvds_msgapi_send_cb_t send_callback, void* user_ptr) {
void nvds_msgapi_do_work(NvDsMsgApiHandle h_ptr) {
nvds_log(NVDS_MQTT_LOG_CAT, LOG_ERR, "MQTT connection handle passed for dowork() = NULL. No actions taken\n");
return;
nvds_log(NVDS_MQTT_LOG_CAT, LOG_DEBUG, "nvds_msgapi_do_work\n");
//****nvds_mqtt_client_poll((NvDsKafkaClientHandle*)h_ptr);
NvDsMsgApiErrorType nvds_msgapi_disconnect(NvDsMsgApiHandle h_ptr) {
if (!h_ptr) {
nvds_log(NVDS_MQTT_LOG_CAT, LOG_DEBUG, "nvds_msgapi_disconnect called with null handle\n");
int rc;
if ((rc = MQTTClient_disconnect(client, 10000)) != MQTTCLIENT_SUCCESS)
nvds_log(NVDS_MQTT_LOG_CAT, LOG_DEBUG, "Failed to disconnect, return code %d\n", rc);
MQTTClient_destroy(client);
nvds_log_close();
char* nvds_msgapi_getversion() {
return (char*)NVDS_MSGAPI_VERSION;
char* nvds_msgapi_get_protocol_name() {
return (char*)NVDS_MSGAPI_PROTOCOL;
NvDsMsgApiErrorType nvds_msgapi_connection_signature(char* broker_str, char* cfg, char* output_str, int max_len) {
