I am trying to use the cutil timer function using
[codebox]unsigned int timer;
cutilCheckError(cutCreateTimer(&timer));[/codebox]
However, when I compile, I get the following error:
[codebox]tmpxft_00004cee_00000000-1_ao76_fft1.cudafe1.cpp:(.text+0x23df): undefined reference to `cutCreateTimer’
collect2: ld returned 1 exit status
[/codebox]
I have included the following:
[codebox]#include <cutil.h>
#include <cutil_inline.h>
#include <cuda_runtime_api.h>[/codebox]
and my script also has
[codebox]
nvcc -G -D_DEBUG -pg -o …/obj/ao76_fft1 …/src/ao76_fft1.cu \
–host-compilation C -arch sm_13 \
-I/home/vivekv/cuda_exercise/src/ \
-I/usr/local/cuda/include \
-L/usr/local/cuda/lib64 -lcufft \
-I/home/vivekv/NVIDIA_GPU_Computing_SDK/C/common/inc/ \
-L/home/vivekv/NVIDIA_GPU_Computing_SDK/C/lib[/codebox]
Same Problem…Have you found the solution of that?
erike
#6
erike
#7
