Hi, i want to ask something, im currently working on a project to run yolov4-tiny using darknet on Nvidia Jetson Nano using Intel RealSense D435i, im have successfully run the darknet using Intel RealSense D435i, but the problem is the video resolution is 1920 x 1080, which is really high and makes the fps really low, im wondering if there is a way to run darknet but lower the resolution, for example to 480p maybe.
The command i use to run darknet is :
./darknet detector demo cfg/coco.data cfg/yolov4-tiny.cfg yolov4-tiny.weights -c 0
Any suggestion would be really appreciated,
Thank You
