I am using bacula to get backups of our head node, and the nightly incremental backups are quite large, over 30 GB, so I was looking into what comprises so much changed data everyday.
I found mysql-bin
files in /var/lib/mysql
going back to the beginning about 2.5 years ago… actually that directory only comprises 1.5 GB so it’s not that significant but I didn’t even realize the system was using MySQL. Either way, I just wanted some feedback on proper maintenance and backup of the databases… I don’t know much in that area, but I do know that taking a straight backup of /var/lib/mysql
is improper.
In fact, bacula comes with a mysqldump
script that is supposed to be run before the backup starts, then the dumped data files are backed up and I believe the binary data gets pruned or flushed as well. I’ve included it below.
There looks to be additional databases in various formats in /var/lib/mysql/cmdaemon/
, /var/lib/mysql/mysql/
, /var/lib/mysql/performance_schema/
, and /var/lib/mysql/slurm_acct_db/
as well.
Would using this script still be recommended? I think some of the options may need to be adjusted and maybe add a few dump commands for the differing databases. I checked the admin manual and the database setup seems rather complex but it didn’t really mention anything about maintenance/pruning and backups, except for the daily cmd
backups that are put in /var/spool/cmd/backup/
which I’m of course already backing up.
# cat mysql_binary_log_dump
#!/bin/bash
LEVEL=$1
DUMPDIR=/var/lib/mysql_dump
USER=root
PASSWORD=<pass>
if [ "$LEVEL" == "Full" -o "$LEVEL" == "Differential" ]
then
echo "Full/Differential"
mysqldump -u $USER --password=$PASSWORD --flush-logs --master-data=2 --all-databases --delete-master-logs > $DUMPDIR/dump.$$.sql
mv $DUMPDIR/dump.$$.sql $DUMPDIR/dump.sql
else
echo "Incremental"
mysqladmin -u $USER --password=$PASSWORD flush-logs
fi
