Debian 12 proxmox gtx970 cuda ffmpeg error
Hi, how to fix error code gtx 970:
| NVIDIA-SMI 535.216.01             Driver Version: 535.216.01   CUDA Version: 12.9     |
| GPU  Name                 Persistence-M | Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp   Perf          Pwr:Usage/Cap |         Memory-Usage | GPU-Util  Compute M. |
|                                         |                      |               MIG M. |
|   0  NVIDIA GeForce GTX 970         On  | 00000000:08:00.0 Off |                  N/A |
|  0%   42C    P8              25W / 163W |      1MiB /  4096MiB |      0%      Default |
|                                         |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                            GPU Memory |
|        ID   ID                                                             Usage      |
|  No running processes found                                                           |
error:
[AVHWDeviceContext @ 0x566976a48c40] cu->cuInit(0) failed -> CUDA_ERROR_COMPAT_NOT_SUPPORTED_ON_DEVICE: forward compatibility was attempted on non supported HW
Device creation failed: -542398533.
[h264 @ 0x566976a47cc0] No device available for decoder: device type cuda needed for codec h264.
Stream mapping:
  Stream #0:1 -> #0:0 (aac (native) -> aac (native))
  Stream #0:0 -> #0:1 (h264 (native) -> h264 (h264_nvenc))
Device setup failed for decoder on input stream #0:0 : Generic error in an external library
cuda list:
dpkg -l | grep cuda
ii  libcuda1:amd64                       535.216.01-1~deb12u1                   amd64        NVIDIA CUDA Driver Library
ii  libcudadebugger1:amd64               535.216.01-1~deb12u1                   amd64        NVIDIA CUDA Debugger Library
ii  libcudart11.0:amd64                  11.8.89~11.8.0-5~deb12u1               amd64        NVIDIA CUDA Runtime Library
ii  nvidia-cuda-dev:amd64                11.8.89~11.8.0-5~deb12u1               amd64        NVIDIA CUDA development files
ii  nvidia-cuda-gdb                      11.8.86~11.8.0-5~deb12u1               amd64        NVIDIA CUDA Debugger (GDB)
ii  nvidia-cuda-mps                      535.216.01-1~deb12u1                   amd64        NVIDIA CUDA Multi Process Service (MPS)
ii  nvidia-cuda-toolkit                  11.8.89~11.8.0-5~deb12u1               amd64        NVIDIA CUDA development toolkit
ii  nvidia-cuda-toolkit-doc              11.8.0-5~deb12u1                       all          NVIDIA CUDA and OpenCL documentation
nvidia list:
ii  firmware-nvidia-gsp                  535.216.01-1~deb12u1                   amd64        NVIDIA GSP firmware
ii  glx-alternative-nvidia               1.2.2                                  amd64        allows the selection of NVIDIA as GLX provider
ii  libegl-nvidia0:amd64                 535.216.01-1~deb12u1                   amd64        NVIDIA binary EGL library
ii  libgl1-nvidia-glvnd-glx:amd64        535.216.01-1~deb12u1                   amd64        NVIDIA binary OpenGL/GLX library (GLVND variant)
ii  libgles-nvidia1:amd64                535.216.01-1~deb12u1                   amd64        NVIDIA binary OpenGL|ES 1.x library
ii  libgles-nvidia2:amd64                535.216.01-1~deb12u1                   amd64        NVIDIA binary OpenGL|ES 2.x library
ii  libglx-nvidia0:amd64                 535.216.01-1~deb12u1                   amd64        NVIDIA binary GLX library
ii  libnvidia-allocator1:amd64           535.216.01-1~deb12u1                   amd64        NVIDIA allocator runtime library
ii  libnvidia-api1:amd64                 535.216.01-1~deb12u1                   amd64        NVAPI runtime library
ii  libnvidia-cfg1:amd64                 535.216.01-1~deb12u1                   amd64        NVIDIA binary OpenGL/GLX configuration library
ii  libnvidia-egl-gbm1:amd64             1.1.0-2                                amd64        GBM EGL external platform library for NVIDIA
ii  libnvidia-egl-wayland1:amd64         1:1.1.10-1                             amd64        Wayland EGL External Platform library -- shared library
ii  libnvidia-eglcore:amd64              535.216.01-1~deb12u1                   amd64        NVIDIA binary EGL core libraries
ii  libnvidia-encode1:amd64              535.216.01-1~deb12u1                   amd64        NVENC Video Encoding runtime library
ii  libnvidia-fbc1:amd64                 535.216.01-1~deb12u1                   amd64        NVIDIA OpenGL-based Framebuffer Capture runtime library
ii  libnvidia-glcore:amd64               535.216.01-1~deb12u1                   amd64        NVIDIA binary OpenGL/GLX core libraries
ii  libnvidia-glvkspirv:amd64            535.216.01-1~deb12u1                   amd64        NVIDIA binary Vulkan Spir-V compiler library
ii  libnvidia-ml-dev:amd64               11.8.86~11.8.0-5~deb12u1               amd64        NVIDIA Management Library (NVML) development files
ii  libnvidia-ml1:amd64                  535.216.01-1~deb12u1                   amd64        NVIDIA Management Library (NVML) runtime library
ii  libnvidia-ngx1:amd64                 535.216.01-1~deb12u1                   amd64        NVIDIA NGX runtime library
ii  libnvidia-nvvm4:amd64                535.216.01-1~deb12u1                   amd64        NVIDIA NVVM Compiler library
ii  libnvidia-opticalflow1:amd64         535.216.01-1~deb12u1                   amd64        NVIDIA Optical Flow runtime library
ii  libnvidia-pkcs11-openssl3:amd64      535.216.01-1~deb12u1                   amd64        NVIDIA PKCS #11 Library (OpenSSL 3)
ii  libnvidia-ptxjitcompiler1:amd64      535.216.01-1~deb12u1                   amd64        NVIDIA PTX JIT Compiler library
ii  libnvidia-rtcore:amd64               535.216.01-1~deb12u1                   amd64        NVIDIA binary Vulkan ray tracing (rtcore) library
ii  nvidia-alternative                   535.216.01-1~deb12u1                   amd64        allows the selection of NVIDIA as GLX provider
ii  nvidia-driver                        535.216.01-1~deb12u1                   amd64        NVIDIA metapackage
ii  nvidia-driver-bin                    535.216.01-1~deb12u1                   amd64        NVIDIA driver support binaries
ii  nvidia-driver-full                   535.216.01-1~deb12u1                   amd64        NVIDIA metapackage (all components)
ii  nvidia-driver-libs:amd64             535.216.01-1~deb12u1                   amd64        NVIDIA metapackage (OpenGL/GLX/EGL/GLES libraries)
ii  nvidia-egl-common                    535.216.01-1~deb12u1                   amd64        NVIDIA binary EGL driver - common files
ii  nvidia-egl-icd:amd64                 535.216.01-1~deb12u1                   amd64        NVIDIA EGL installable client driver (ICD)
ii  nvidia-installer-cleanup             20220217+3~deb12u1                     amd64        cleanup after driver installation with the nvidia-installer
ii  nvidia-kernel-common                 20220217+3~deb12u1                     amd64        NVIDIA binary kernel module support files
ii  nvidia-kernel-dkms                   535.216.01-1~deb12u1                   amd64        NVIDIA binary kernel module DKMS source
ii  nvidia-kernel-support                535.216.01-1~deb12u1                   amd64        NVIDIA binary kernel module support files
ii  nvidia-legacy-check                  535.216.01-1~deb12u1                   amd64        check for NVIDIA GPUs requiring a legacy driver
ii  nvidia-modprobe                      535.161.07-1~deb12u1                   amd64        utility to load NVIDIA kernel modules and create device nodes
ii  nvidia-opencl-common                 535.216.01-1~deb12u1                   amd64        NVIDIA OpenCL driver - common files
ii  nvidia-opencl-dev:amd64              11.8.89~11.8.0-5~deb12u1               amd64        NVIDIA OpenCL development files
ii  nvidia-opencl-icd:amd64              535.216.01-1~deb12u1                   amd64        NVIDIA OpenCL installable client driver (ICD)
ii  nvidia-openjdk-8-jre                 9.+8u372-ga-1~11.8.0-5~deb12u1         amd64        Obsolete OpenJDK Java runtime, for NVIDIA applications
ii  nvidia-persistenced                  535.171.04-1~deb12u1                   amd64        daemon to maintain persistent software state in the NVIDIA driver
ii  nvidia-powerd                        535.216.01-1~deb12u1                   amd64        NVIDIA Dynamic Boost (daemon)
ii  nvidia-profiler                      11.8.87~11.8.0-5~deb12u1               amd64        NVIDIA Profiler for CUDA and OpenCL
ii  nvidia-settings                      535.171.04-1~deb12u1                   amd64        tool for configuring the NVIDIA graphics driver
ii  nvidia-smi                           535.216.01-1~deb12u1                   amd64        NVIDIA System Management Interface
ii  nvidia-support                       20220217+3~deb12u1                     amd64        NVIDIA binary graphics driver support files
ii  nvidia-suspend-common                535.216.01-1~deb12u1                   amd64        NVIDIA driver - systemd power management scripts
ii  nvidia-vdpau-driver:amd64            535.216.01-1~deb12u1                   amd64        Video Decode and Presentation API for Unix - NVIDIA driver
ii  nvidia-visual-profiler               11.8.87~11.8.0-5~deb12u1               amd64        NVIDIA Visual Profiler for CUDA and OpenCL
ii  nvidia-vulkan-common                 535.216.01-1~deb12u1                   amd64        NVIDIA Vulkan driver - common files
ii  nvidia-vulkan-icd:amd64              535.216.01-1~deb12u1                   amd64        NVIDIA Vulkan installable client driver (ICD)
ii  pve-nvidia-vgpu-helper               0.2.0                                  all          Proxmox Nvidia vGPU helper script and systemd service
ii  xserver-xorg-video-nvidia            535.216.01-1~deb12u1                   amd64        NVIDIA binary Xorg driver
nvcc
nvcc --version
Copyright (c) 2005-2022 NVIDIA Corporation
Built on Wed_Sep_21_10:33:58_PDT_2022
Cuda compilation tools, release 11.8, V11.8.89
Build cuda_11.8.r11.8/compiler.31833905_0
