this is a follow-up of Can't use Cuda-gdb. I run into the same issue, but on Debian (testing). I also get
Could not find CUDA Debugger back-end. Please try upgrading/re-installing the GPU driver
[New Thread 0x7fff65a846c0 (LWP 58893)]
[New Thread 0x7fff652836c0 (LWP 58894)]
[New Thread 0x7fff61fff6c0 (LWP 58895)]
The CUDA driver has hit an internal error.
Error code: 0x1012400000001c
Further execution or debugging is unreliable.
Please ensure that your temporary directory is mounted with write and exec permissions.
I use cuda-repo-debian11-12-0-local_12.0.0-525.60.13-1_amd64.deb downloaded from https://developer.nvidia.com/cuda-downloads?target_os=Linux&target_arch=x86_64&Distribution=Debian&target_version=11&target_type=deb_local.
$ ls -la /usr/lib/x86_64-linux-gnu/libcuda*
lrwxrwxrwx 1 root root 53 Nov 30 13:43 /usr/lib/x86_64-linux-gnu/libcuda.so -> /etc/alternatives/nvidia--libcuda.so-x86_64-linux-gnu
lrwxrwxrwx 1 root root 55 Nov 30 13:43 /usr/lib/x86_64-linux-gnu/libcuda.so.1 -> /etc/alternatives/nvidia--libcuda.so.1-x86_64-linux-gnu
$ ls -la /usr/lib/x86_64-linux-gnu/nvidia/current/libcuda*
lrwxrwxrwx 1 root root 12 Nov 30 13:43 /usr/lib/x86_64-linux-gnu/nvidia/current/libcuda.so -> libcuda.so.1
lrwxrwxrwx 1 root root 20 Nov 30 13:43 /usr/lib/x86_64-linux-gnu/nvidia/current/libcuda.so.1 -> libcuda.so.525.60.13
-rw-r--r-- 1 root root 29716384 Nov 30 08:04 /usr/lib/x86_64-linux-gnu/nvidia/current/libcuda.so.525.60.13
Using CUDBG_USE_LEGACY_DEBUGGER=1 works as a workaround. I thought I report it, as I’d expect that the official downloads contain all the files that are needed.
Update: I forgot to mention that also apt-file search libcudadebugger.so doesn’t give any result.
Hi @volker.mische
I use cuda-repo-debian11-12-0-local_12.0.0-525.60.13-1_amd64.deb downloaded from CUDA Toolkit 12.3 Update 1 Downloads | NVIDIA Developer.
This link points to the CUDA Toolkit installation packages
libcudadebugger.so is a part of Nvidia GPU Driver package (e.g. Linux x64 (AMD64/EM64T) Display Driver | 525.60.11 | Linux 64-bit | NVIDIA )
E.g. for Arch Linux (Can't use Cuda-gdb) the distro GPU driver installer package re-packs the official Nvidia GPU driver package (https://github.com/archlinux/svntogit-packages/blob/packages/nvidia-utils/trunk/PKGBUILD ), so their installer has to be updated every time we add/remove files from the GPU Driver.
Assuming that Debian follows similar approach (rather then using the official Nvidia GPU driver package directly), the Debian packages would have to be updated as well.
Please note that I’m not using any packages from the official Debian distro repos. I’ve only installed Nvidias CUDA Toolkit from the link above. It contains those packages:
$ ls -la /var/cuda-repo-debian11-12-0-local
total 3091284
drwxr-xr-x 2 root root 20480 Dec 14 15:45 .
drwxr-xr-x 14 root root 4096 Dec 14 15:45 ..
-rw-r--r-- 1 root root 1662 Dec 3 10:09 0DD165C7.pub
-rw-r--r-- 1 root root 1141 Dec 3 10:09 cuda-0DD165C7-keyring.gpg
-rw-r--r-- 1 root root 2402 Dec 3 10:09 cuda_12.0.0-1_amd64.deb
-rw-r--r-- 1 root root 2458 Dec 3 10:09 cuda-12-0_12.0.0-1_amd64.deb
-rw-r--r-- 1 root root 1060086 Dec 3 10:09 cuda-cccl-12-0_12.0.90-1_amd64.deb
-rw-r--r-- 1 root root 2476 Dec 3 10:09 cuda-command-line-tools-12-0_12.0.0-1_amd64.deb
-rw-r--r-- 1 root root 34423422 Dec 3 10:09 cuda-compat-12-0_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 2434 Dec 3 10:09 cuda-compiler-12-0_12.0.0-1_amd64.deb
-rw-r--r-- 1 root root 158668 Dec 3 10:09 cuda-cudart-12-0_12.0.107-1_amd64.deb
-rw-r--r-- 1 root root 886392 Dec 3 10:09 cuda-cudart-dev-12-0_12.0.107-1_amd64.deb
-rw-r--r-- 1 root root 166884 Dec 3 10:09 cuda-cuobjdump-12-0_12.0.76-1_amd64.deb
-rw-r--r-- 1 root root 16323366 Dec 3 10:09 cuda-cupti-12-0_12.0.90-1_amd64.deb
-rw-r--r-- 1 root root 2542218 Dec 3 10:09 cuda-cupti-dev-12-0_12.0.90-1_amd64.deb
-rw-r--r-- 1 root root 188572 Dec 3 10:09 cuda-cuxxfilt-12-0_12.0.76-1_amd64.deb
-rw-r--r-- 1 root root 3983752 Dec 3 10:09 cuda-demo-suite-12-0_12.0.76-1_amd64.deb
-rw-r--r-- 1 root root 49878 Dec 3 10:09 cuda-documentation-12-0_12.0.76-1_amd64.deb
-rw-r--r-- 1 root root 27874 Dec 3 10:09 cuda-driver-dev-12-0_12.0.107-1_amd64.deb
-rw-r--r-- 1 root root 2672 Dec 3 10:09 cuda-drivers-525_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 2508 Dec 3 10:09 cuda-drivers_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 3302 Dec 3 10:09 cuda-drivers-fabricmanager-525_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 3266 Dec 3 10:09 cuda-drivers-fabricmanager_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 4538302 Dec 3 10:09 cuda-gdb-12-0_12.0.90-1_amd64.deb
-rw-r--r-- 1 root root 61156642 Dec 3 10:09 cuda-gdb-src-12-0_12.0.90-1_amd64.deb
-rw-r--r-- 1 root root 2542 Dec 3 10:09 cuda-libraries-12-0_12.0.0-1_amd64.deb
-rw-r--r-- 1 root root 2580 Dec 3 10:09 cuda-libraries-dev-12-0_12.0.0-1_amd64.deb
-rw-r--r-- 1 root root 2466 Dec 3 10:09 cuda-minimal-build-12-0_12.0.0-1_amd64.deb
-rw-r--r-- 1 root root 118610794 Dec 3 10:09 cuda-nsight-12-0_12.0.78-1_amd64.deb
-rw-r--r-- 1 root root 3946 Dec 3 10:09 cuda-nsight-compute-12-0_12.0.0-1_amd64.deb
-rw-r--r-- 1 root root 3338 Dec 3 10:09 cuda-nsight-systems-12-0_12.0.0-1_amd64.deb
-rw-r--r-- 1 root root 44331598 Dec 3 10:09 cuda-nvcc-12-0_12.0.76-1_amd64.deb
-rw-r--r-- 1 root root 49877234 Dec 3 10:09 cuda-nvdisasm-12-0_12.0.76-1_amd64.deb
-rw-r--r-- 1 root root 84698 Dec 3 10:09 cuda-nvml-dev-12-0_12.0.76-1_amd64.deb
-rw-r--r-- 1 root root 1959840 Dec 3 10:09 cuda-nvprof-12-0_12.0.90-1_amd64.deb
-rw-r--r-- 1 root root 58650 Dec 3 10:09 cuda-nvprune-12-0_12.0.76-1_amd64.deb
-rw-r--r-- 1 root root 16661478 Dec 3 10:09 cuda-nvrtc-12-0_12.0.76-1_amd64.deb
-rw-r--r-- 1 root root 13832322 Dec 3 10:09 cuda-nvrtc-dev-12-0_12.0.76-1_amd64.deb
-rw-r--r-- 1 root root 51388 Dec 3 10:09 cuda-nvtx-12-0_12.0.76-1_amd64.deb
-rw-r--r-- 1 root root 112557836 Dec 3 10:09 cuda-nvvp-12-0_12.0.90-1_amd64.deb
-rw-r--r-- 1 root root 23842 Dec 3 10:09 cuda-opencl-12-0_12.0.76-1_amd64.deb
-rw-r--r-- 1 root root 64710 Dec 3 10:09 cuda-opencl-dev-12-0_12.0.76-1_amd64.deb
-rw-r--r-- 1 root root 18526 Dec 3 10:09 cuda-profiler-api-12-0_12.0.76-1_amd64.deb
-rw-r--r-- 1 root root 2426 Dec 3 10:09 cuda-runtime-12-0_12.0.0-1_amd64.deb
-rw-r--r-- 1 root root 8831482 Dec 3 10:09 cuda-sanitizer-12-0_12.0.90-1_amd64.deb
-rw-r--r-- 1 root root 3254 Dec 3 10:09 cuda-toolkit-12-0_12.0.0-1_amd64.deb
-rw-r--r-- 1 root root 16338 Dec 3 10:09 cuda-toolkit-12-0-config-common_12.0.107-1_all.deb
-rw-r--r-- 1 root root 16382 Dec 3 10:09 cuda-toolkit-12-config-common_12.0.107-1_all.deb
-rw-r--r-- 1 root root 16362 Dec 3 10:09 cuda-toolkit-config-common_12.0.107-1_all.deb
-rw-r--r-- 1 root root 2398 Dec 3 10:09 cuda-tools-12-0_12.0.0-1_amd64.deb
-rw-r--r-- 1 root root 2880 Dec 3 10:09 cuda-visual-tools-12-0_12.0.0-1_amd64.deb
-rw-r--r-- 1 root root 39173086 Dec 3 10:09 gds-tools-12-0_1.5.0.59-1_amd64.deb
-rw-r--r-- 1 root root 1575 Dec 3 10:09 InRelease
-rw-r--r-- 1 root root 223182430 Dec 3 10:09 libcublas-12-0_12.0.1.189-1_amd64.deb
-rw-r--r-- 1 root root 235680192 Dec 3 10:09 libcublas-dev-12-0_12.0.1.189-1_amd64.deb
-rw-r--r-- 1 root root 3039934 Dec 3 10:09 libcuda1_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 2810602 Dec 3 10:09 libcuda1_525.60.13-1_i386.deb
-rw-r--r-- 1 root root 228464 Dec 3 10:09 libcuda1-i386_525.60.13-1_i386.deb
-rw-r--r-- 1 root root 2736378 Dec 3 10:09 libcudadebugger1_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 42716718 Dec 3 10:09 libcufft-12-0_11.0.0.21-1_amd64.deb
-rw-r--r-- 1 root root 85949762 Dec 3 10:09 libcufft-dev-12-0_11.0.0.21-1_amd64.deb
-rw-r--r-- 1 root root 635028 Dec 3 10:09 libcufile-12-0_1.5.0.59-1_amd64.deb
-rw-r--r-- 1 root root 1560692 Dec 3 10:09 libcufile-dev-12-0_1.5.0.59-1_amd64.deb
-rw-r--r-- 1 root root 41456626 Dec 3 10:09 libcurand-12-0_10.3.1.50-1_amd64.deb
-rw-r--r-- 1 root root 41694702 Dec 3 10:09 libcurand-dev-12-0_10.3.1.50-1_amd64.deb
-rw-r--r-- 1 root root 51320850 Dec 3 10:09 libcusolver-12-0_11.4.2.57-1_amd64.deb
-rw-r--r-- 1 root root 33653054 Dec 3 10:09 libcusolver-dev-12-0_11.4.2.57-1_amd64.deb
-rw-r--r-- 1 root root 93921990 Dec 3 10:09 libcusparse-12-0_12.0.0.76-1_amd64.deb
-rw-r--r-- 1 root root 95717042 Dec 3 10:09 libcusparse-dev-12-0_12.0.0.76-1_amd64.deb
-rw-r--r-- 1 root root 236440 Dec 3 10:09 libegl1-nvidia_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 492520 Dec 3 10:09 libegl-nvidia0_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 502280 Dec 3 10:09 libegl-nvidia0_525.60.13-1_i386.deb
-rw-r--r-- 1 root root 404888 Dec 3 10:09 libgl1-nvidia-glvnd-glx_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 404888 Dec 3 10:09 libgl1-nvidia-glvnd-glx_525.60.13-1_i386.deb
-rw-r--r-- 1 root root 248492 Dec 3 10:09 libgles-nvidia1_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 249816 Dec 3 10:09 libgles-nvidia1_525.60.13-1_i386.deb
-rw-r--r-- 1 root root 256336 Dec 3 10:09 libgles-nvidia2_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 257120 Dec 3 10:09 libgles-nvidia2_525.60.13-1_i386.deb
-rw-r--r-- 1 root root 461670 Dec 3 10:09 libglx-nvidia0_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 461414 Dec 3 10:09 libglx-nvidia0_525.60.13-1_i386.deb
-rw-r--r-- 1 root root 95304498 Dec 3 10:09 libnpp-12-0_12.0.0.30-1_amd64.deb
-rw-r--r-- 1 root root 92776458 Dec 3 10:09 libnpp-dev-12-0_12.0.0.30-1_amd64.deb
-rw-r--r-- 1 root root 1467986 Dec 3 10:09 libnvcuvid1_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 1721258 Dec 3 10:09 libnvcuvid1_525.60.13-1_i386.deb
-rw-r--r-- 1 root root 281816 Dec 3 10:09 libnvidia-allocator1_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 286396 Dec 3 10:09 libnvidia-allocator1_525.60.13-1_i386.deb
-rw-r--r-- 1 root root 427540 Dec 3 10:09 libnvidia-api1_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 313480 Dec 3 10:09 libnvidia-cfg1_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 14098266 Dec 3 10:09 libnvidia-compiler_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 15440146 Dec 3 10:09 libnvidia-compiler_525.60.13-1_i386.deb
-rw-r--r-- 1 root root 10256150 Dec 3 10:09 libnvidia-eglcore_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 9688550 Dec 3 10:09 libnvidia-eglcore_525.60.13-1_i386.deb
-rw-r--r-- 1 root root 293508 Dec 3 10:09 libnvidia-encode1_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 300116 Dec 3 10:09 libnvidia-encode1_525.60.13-1_i386.deb
-rw-r--r-- 1 root root 268680 Dec 3 10:09 libnvidia-fbc1_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 273084 Dec 3 10:09 libnvidia-fbc1_525.60.13-1_i386.deb
-rw-r--r-- 1 root root 11625670 Dec 3 10:09 libnvidia-glcore_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 9775770 Dec 3 10:09 libnvidia-glcore_525.60.13-1_i386.deb
-rw-r--r-- 1 root root 6651478 Dec 3 10:09 libnvidia-glvkspirv_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 7503370 Dec 3 10:09 libnvidia-glvkspirv_525.60.13-1_i386.deb
-rw-r--r-- 1 root root 684644 Dec 3 10:09 libnvidia-ml1_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 658416 Dec 3 10:09 libnvidia-ml1_525.60.13-1_i386.deb
-rw-r--r-- 1 root root 441576 Dec 3 10:09 libnvidia-nscq-525_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 22765330 Dec 3 10:09 libnvidia-nvvm4_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 24444582 Dec 3 10:09 libnvidia-nvvm4_525.60.13-1_i386.deb
-rw-r--r-- 1 root root 250284 Dec 3 10:09 libnvidia-opticalflow1_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 243784 Dec 3 10:09 libnvidia-opticalflow1_525.60.13-1_i386.deb
-rw-r--r-- 1 root root 6669386 Dec 3 10:09 libnvidia-ptxjitcompiler1_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 7011402 Dec 3 10:09 libnvidia-ptxjitcompiler1_525.60.13-1_i386.deb
-rw-r--r-- 1 root root 17768510 Dec 3 10:09 libnvidia-rtcore_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 231280 Dec 3 10:09 libnvidia-wayland-client_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 14580794 Dec 3 10:09 libnvjitlink-12-0_12.0.76-1_amd64.deb
-rw-r--r-- 1 root root 11391674 Dec 3 10:09 libnvjitlink-dev-12-0_12.0.76-1_amd64.deb
-rw-r--r-- 1 root root 1761076 Dec 3 10:09 libnvjpeg-12-0_12.0.0.28-1_amd64.deb
-rw-r--r-- 1 root root 1436416 Dec 3 10:09 libnvjpeg-dev-12-0_12.0.0.28-1_amd64.deb
-rw-r--r-- 1 root root 139202200 Dec 3 10:09 libnvoptix1_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 31848 Dec 3 10:09 libnvvm-samples-12-0_12.0.94-1_amd64.deb
-rw-r--r-- 1 root root 54220 Dec 3 10:09 libxnvctrl0_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 120976 Dec 3 10:09 libxnvctrl-dev_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 1930 Dec 3 10:09 Local.md5
-rw-r--r-- 1 root root 836 Dec 3 10:09 Local.md5.gpg
-rw-r--r-- 1 root root 699664356 Dec 3 10:09 nsight-compute-2022.4.0_2022.4.0.15-1_amd64.deb
-rw-r--r-- 1 root root 286007576 Dec 3 10:09 nsight-systems-2022.4.2_2022.4.2.18-1_amd64.deb
-rw-r--r-- 1 root root 230536 Dec 3 10:09 nvidia-alternative_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 230524 Dec 3 10:09 nvidia-alternative_525.60.13-1_i386.deb
-rw-r--r-- 1 root root 253664 Dec 3 10:09 nvidia-cuda-mps_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 232196 Dec 3 10:09 nvidia-detect_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 586320 Dec 3 10:09 nvidia-driver_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 42203602 Dec 3 10:09 nvidia-driver-bin_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 228912 Dec 3 10:09 nvidia-driver-libs_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 228880 Dec 3 10:09 nvidia-driver-libs_525.60.13-1_i386.deb
-rw-r--r-- 1 root root 228480 Dec 3 10:09 nvidia-driver-libs-i386_525.60.13-1_i386.deb
-rw-r--r-- 1 root root 228900 Dec 3 10:09 nvidia-egl-common_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 228888 Dec 3 10:09 nvidia-egl-common_525.60.13-1_i386.deb
-rw-r--r-- 1 root root 228596 Dec 3 10:09 nvidia-egl-icd_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 228596 Dec 3 10:09 nvidia-egl-icd_525.60.13-1_i386.deb
-rw-r--r-- 1 root root 1504932 Dec 3 10:09 nvidia-fabricmanager-525_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 381764 Dec 3 10:09 nvidia-fabricmanager-dev-525_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 2548 Dec 3 10:09 nvidia-fs_2.14.12-1_amd64.deb
-rw-r--r-- 1 root root 60996 Dec 3 10:09 nvidia-fs-dkms_2.14.12-1_amd64.deb
-rw-r--r-- 1 root root 2398 Dec 3 10:09 nvidia-gds_12.0.0-1_amd64.deb
-rw-r--r-- 1 root root 2448 Dec 3 10:09 nvidia-gds-12-0_12.0.0-1_amd64.deb
-rw-r--r-- 1 root root 20562 Dec 3 10:09 nvidia-installer-cleanup_20151021+11_amd64.deb
-rw-r--r-- 1 root root 12238 Dec 3 10:09 nvidia-kernel-common_20151021+11_amd64.deb
-rw-r--r-- 1 root root 44302528 Dec 3 10:09 nvidia-kernel-dkms_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 3670272 Dec 3 10:09 nvidia-kernel-open_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 3667038 Dec 3 10:09 nvidia-kernel-open-dkms_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 44374522 Dec 3 10:09 nvidia-kernel-source_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 229432 Dec 3 10:09 nvidia-kernel-support_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 233676 Dec 3 10:09 nvidia-legacy-check_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 239204 Dec 3 10:09 nvidia-libopencl1_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 239224 Dec 3 10:09 nvidia-libopencl1_525.60.13-1_i386.deb
-rw-r--r-- 1 root root 61918 Dec 3 10:09 nvidia-modprobe_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 228892 Dec 3 10:09 nvidia-nonglvnd-vulkan-common_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 228884 Dec 3 10:09 nvidia-nonglvnd-vulkan-common_525.60.13-1_i386.deb
-rw-r--r-- 1 root root 228864 Dec 3 10:09 nvidia-opencl-common_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 228852 Dec 3 10:09 nvidia-opencl-common_525.60.13-1_i386.deb
-rw-r--r-- 1 root root 2743822 Dec 3 10:09 nvidia-opencl-icd_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 2600126 Dec 3 10:09 nvidia-opencl-icd_525.60.13-1_i386.deb
-rw-r--r-- 1 root root 85240 Dec 3 10:09 nvidia-persistenced_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 2435250 Dec 3 10:09 nvidia-settings_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 443100 Dec 3 10:09 nvidia-smi_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 21446 Dec 3 10:09 nvidia-support_20151021+11_amd64.deb
-rw-r--r-- 1 root root 731140 Dec 3 10:09 nvidia-vdpau-driver_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 722956 Dec 3 10:09 nvidia-vdpau-driver_525.60.13-1_i386.deb
-rw-r--r-- 1 root root 229172 Dec 3 10:09 nvidia-vulkan-common_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 229160 Dec 3 10:09 nvidia-vulkan-common_525.60.13-1_i386.deb
-rw-r--r-- 1 root root 228596 Dec 3 10:09 nvidia-vulkan-icd_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 228580 Dec 3 10:09 nvidia-vulkan-icd_525.60.13-1_i386.deb
-rw-r--r-- 1 root root 249660 Dec 3 10:09 nvidia-xconfig_525.60.13-1_amd64.deb
-rw-r--r-- 1 root root 167446 Dec 3 10:09 Packages
-rw-r--r-- 1 root root 45295 Dec 3 10:09 Packages.gz
-rw-r--r-- 1 root root 690 Dec 3 10:09 Release
-rw-r--r-- 1 root root 836 Dec 3 10:09 Release.gpg
-rw-r--r-- 1 root root 2360218 Dec 3 10:09 xserver-xorg-video-nvidia_525.60.13-1_amd64.deb
It contains the cuda-gdb package, so I would expect that it contains all files required to run cuda-gdb correctly.
Though I might missing the point here. Aren’t those Debian packages from the Nvidia website officially supported? Are they connected to the Debian project packaging effort?
And one more question: isn’t the Nvidia GPU Driver package included in the CUDA Toolkit installation package? I don’t seem to need to install any drivers after I’ve installed the CUDA Toolkit.
Yes, but the libcudadebugger.so is a part of the Nvidia GPU Driver package (which is not part of CUDA toolkit)
Most likely the GPU Driver package was already installer as a part of base Debian installation (e.g. if you use any X applications).
I believe the package is called nvidia-driver:
Yes, it is called nvidia-driver.
$ apt-cache policy nvidia-driver
nvidia-driver:
Installed: 525.60.13-1
Candidate: 525.60.13-1
Version table:
*** 525.60.13-1 500
500 file:/var/cuda-repo-debian11-12-0-local Packages
100 /var/lib/dpkg/status
515.48.07-1 1
1 http://debian.mirror.lrz.de/debian experimental/non-free amd64 Packages
510.108.03-1 50
50 http://debian.mirror.lrz.de/debian unstable/non-free amd64 Packages
510.85.02-6 400
400 http://debian.mirror.lrz.de/debian testing/non-free amd64 Packages
As you can see, the installed version comes from the CUDA toolkit package and not from the distro packages. To me it looks like that the driver are part of the CUDA toolkit package. What am I missing?
Sorry, my bad. I re-checked the repo - you are right, libcuda.so is provided by the libcuda1 package.
There is also a libcudadebugger1 package (libcudadebugger1_525.60.13-1_amd64.deb), which contains the debugger library - could you try installing it?
That works! How could I’ve missed that. Thanks a lot.
May I propose to change the packaging, so that libcudadebugger1 is automatically installed if cuda-gdb is installed?
Sure, this is something we missed when creating the debugger library package - we will get it fixed.
Thank you for reporting this!!
