cuda-gdb missing from CUDA toolkit 9 on OS X?
I just installed CUDA Toolkit 9, and cuda-gdb is no longer included on Mac OS X.
MacBook-Air:~ admin$ ls /Developer/NVIDIA/CUDA-9.0/bin/
bin2c				nsight_ee_plugins_manage.sh
computeprof			nvcc
crt				nvcc.profile
cuda-install-samples-9.0.sh	nvdisasm
cuda-memcheck			nvlink
cudafe				nvprof
cudafe++			nvprune
cuobjdump			nvvp
fatbinary			ptxas
gpu-library-advisor		uninstall_cuda_9.0.pl
nsight
This prevents remote debugging using Nsight from working. If I reconfigure Nsight to use cuda-gdb from CUDA 8, it complains as follows.
cuda-gdb version (8.0.127) is not compatible with cuda-gdbserver version (8.0.128).\nPlease use the same version of cuda-gdb and cuda-gdbserver.
Why is this occurring? This doesn’t seem to be documented anywhere. What’s the problem?
Just stumbled across this, too. It’s mentioned in the CUDA Toolkit Release Notes:
Chapter 3. Debugger. The cuda-gdb debugger is no longer included in the CUDA Toolkit installer packages for Mac OS.
There’s no mention why and what the alternative is?
That’s extremely disappointing.
I can understand not wanting to support OS X because few people deploy applications on non-Linux based systems.
However, dropping support for cuda-gdb also means that OS X no longer supports remote debugging. My company issues MacBook Pros to all our developers, so that’s what I work on, and I now have to use cuda-gdb on the command line over ssh. Some may prefer that, but I don’t. Big step backwards.
Anyone who managed to compile cuda-gdb from source (“x86_64-apple-darwin”) ? --> http://developer.download.nvidia.com/compute/cuda/opensource/9.0.176/cuda-gdb-9.0.176.src.tar.gz
I’ve tried but get compilation errors…
Ok I think I’ve managed to compile the thing and remote debugging seems to work, if anyone is interested in trying it out please let me know -->
Linus-MacBook-Pro:bin linus$ ./cuda-gdb
NVIDIA (R) CUDA Debugger
9.0 release
Portions Copyright (C) 2007-2017 NVIDIA Corporation
GNU gdb (GDB) 7.12
Copyright (C) 2016 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
and "show warranty" for details.
This GDB was configured as "x86_64-apple-darwin16.7.0".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word".
(cuda-gdb) set sysroot target://
(cuda-gdb) target remote 192.168.0.114:1234
Remote debugging using 192.168.0.114:1234
Reading /home/linus/cuda-workspace/BlackScholes/Debug/BlackScholes from remote target...
warning: File transfers from remote targets can be slow. Use "set sysroot" to access files locally instead.
Reading symbols from target:/home/linus/cuda-workspace/BlackScholes/Debug/BlackScholes...done.
Reading /lib64/ld-linux-x86-64.so.2 from remote target...
Reading symbols from target:/lib64/ld-linux-x86-64.so.2...Reading /lib64/ld-2.23.so from remote target...
warning: the debug information found in "target:/lib64/ld-2.23.so" does not match "target:/lib64/ld-linux-x86-64.so.2" (CRC mismatch).
Reading /lib64/.debug/ld-2.23.so from remote target...
(no debugging symbols found)...done.
(cuda-gdb) continue
Continuing.
Reading /lib/x86_64-linux-gnu/librt.so.1 from remote target...
Reading /lib/x86_64-linux-gnu/libpthread.so.0 from remote target...
Reading /lib/x86_64-linux-gnu/libdl.so.2 from remote target...
Reading /usr/lib/x86_64-linux-gnu/libstdc++.so.6 from remote target...
Reading /lib/x86_64-linux-gnu/libm.so.6 from remote target...
Reading /lib/x86_64-linux-gnu/libgcc_s.so.1 from remote target...
Reading /lib/x86_64-linux-gnu/libc.so.6 from remote target...
Reading /lib/x86_64-linux-gnu/librt-2.23.so from remote target...
Reading /lib/x86_64-linux-gnu/.debug/librt-2.23.so from remote target...
Reading /lib/x86_64-linux-gnu/f189ef8db8c3734c6a678e6ef3cb0b206d58b2.debug from remote target...
Reading /lib/x86_64-linux-gnu/.debug/f189ef8db8c3734c6a678e6ef3cb0b206d58b2.debug from remote target...
Reading /lib/x86_64-linux-gnu/libdl-2.23.so from remote target...
Reading /lib/x86_64-linux-gnu/.debug/libdl-2.23.so from remote target...
Reading /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.21 from remote target...
Reading /usr/lib/x86_64-linux-gnu/.debug/libstdc++.so.6.0.21 from remote target...
Reading /lib/x86_64-linux-gnu/libm-2.23.so from remote target...
Reading /lib/x86_64-linux-gnu/.debug/libm-2.23.so from remote target...
Reading /lib/x86_64-linux-gnu/.debug/libgcc_s.so.1 from remote target...
Reading /lib/x86_64-linux-gnu/libc-2.23.so from remote target...
Reading /lib/x86_64-linux-gnu/.debug/libc-2.23.so from remote target...
Reading /usr/lib/x86_64-linux-gnu/libcuda.so.1 from remote target...
Reading /usr/lib/nvidia-384/libnvidia-fatbinaryloader.so.384.90 from remote target...
[Inferior 1 (process 10840) exited normally]
(cuda-gdb)
Hello, I’m trying to compile cuda-gdb on 9.1 toolkit but no success. Any suggestion/library to install/source file to modify?
Thanks,
Fabrizio
Sure thing! Here goes…
As a starting point go with the following ./configure options/flags (paths needs to be updated to fit your environment and CUDA-9.1 libraries):
./configure --program-prefix=cuda- --enable-cuda --enable-targets=x86_64-unknown-linux-gnu,m68k-unknown-linux-gnu CFLAGS='-I/Developer/NVIDIA/CUDA-9.0/include -I/Developer/NVIDIA/CUDA-9.0/extras/Debugger/include' LIBS='-lpthread' LDFLAGS='-lpthread -framework IOKit -framework Security -framework CoreFoundation'
Then I pretty much worked my way from there; make - debug - make clean/distclean - make (again). I can provide the patch set from cuda-gdb-9.0.176, mostly it’s about fixing some pointer casting errors.
Once it builds successfully you will have a ‘gdb’ binary under ./gdb
Good luck!
//Linus
Would you be so kind as to link the patch files required to build this?
Here goes; applicable for <<cuda-gdb-9.0.176.tar.gz>>
diff -r ./cuda-gdb-9.0.176/gdb/cuda-darwin-nat.c ../cuda-gdb-9.0.176/gdb/cuda-darwin-nat.c
143c143,144
<   CFDataRef reg_ref;
>   CFTypeRef reg_ref;
>   //CFDataRef reg_ref;
154c155
<   pci_id = ((uint32_t *)CFDataGetBytePtr(reg_ref))[0];
>   pci_id = ((uint32_t *)CFDataGetBytePtr((CFDataRef)reg_ref))[0];
diff -r ./cuda-gdb-9.0.176/gdb/cuda-events.c ../cuda-gdb-9.0.176/gdb/cuda-events.c
85,86c85,86
<        !cuda_options_gpu_busy_check () ||
<        !cuda_darwin_cuda_device_used_for_graphics (dev_id))
>        !cuda_options_gpu_busy_check () /*||
>        !cuda_darwin_cuda_device_used_for_graphics (dev_id)*/)
diff -r ./cuda-gdb-9.0.176/gdb/cuda-exceptions.c ../cuda-gdb-9.0.176/gdb/cuda-exceptions.c
111c111
<       filename = strrchr (sal.symtab->filename, '/');
>       filename = (char *) strrchr (sal.symtab->filename, '/');
diff -r ./cuda-gdb-9.0.176/gdb/cuda-iterator.c ../cuda-gdb-9.0.176/gdb/cuda-iterator.c
298a299,333
> cuda_iterator
> cuda_iterator_create (cuda_iterator_type type, cuda_coords_t *filter, int int_mask)
>   uint32_t i;
>   cuda_iterator itr;
>   itr = (cuda_iterator) xmalloc (sizeof *itr);
>   itr->type         = type;
>   itr->filter       = filter ? *filter: CUDA_INVALID_COORDS;
>   itr->mask         = (cuda_select_t) int_mask;
>   itr->num_elements = 0;
>   itr->num_unique_elements = 0;
>   itr->list_size    = 1024;
>   itr->index        = 0;
>   itr->completed    = false;
>   itr->list         = (cuda_coords_t*) xmalloc (itr->list_size * sizeof (*itr->list));
>   if (filter)
>     itr->filter.valid = true;
>   itr->current.dev = itr->current.sm = itr->current.wp = itr->current.ln = 0;
>   /* Iterators by physical coordinates can be lazy */
>   if ((type & CUDA_ITERATOR_TYPE_MASK_PHYSICAL) != 0)
>     return itr;
>   while (cuda_iterator_step (itr));
>   itr->completed = true;
>   /* sort the list by coordinates */
>   qsort (itr->list, itr->num_elements, sizeof (*itr->list),
>          (int(*)(const void*, const void*))cuda_coords_compare_logical);
>   return itr;
diff -r ./cuda-gdb-9.0.176/gdb/cuda-iterator.h ../cuda-gdb-9.0.176/gdb/cuda-iterator.h
39a40,43
> cuda_iterator cuda_iterator_create  (cuda_iterator_type type,
>                                      int int_mask);
diff -r ./cuda-gdb-9.0.176/gdb/cuda-regmap.c ../cuda-gdb-9.0.176/gdb/cuda-regmap.c
672c672
<   tmp = strchr (func_name, '(');
>   tmp = (char *) strchr (func_name, '(');
diff -r ./cuda-gdb-9.0.176/gdb/darwin-nat.c ../cuda-gdb-9.0.176/gdb/darwin-nat.c
2204c2204,2208
<       return darwin_xfer_siginfo (ops, object, annex, readbuf, writebuf, offset, len);
>         *xfered_len = (ULONGEST) darwin_xfer_siginfo (ops, object, annex, readbuf, writebuf, offset, len);
>         //return darwin_xfer_siginfo (ops, object, annex, readbuf, writebuf, offset, len);
>         return TARGET_XFER_OK;
diff -r ./cuda-gdb-9.0.176/gdb/doublest.c ../cuda-gdb-9.0.176/gdb/doublest.c
258c258
<       mant_bits = min (mant_bits_left, 32);
>       mant_bits = fmin (mant_bits_left, 32);
568c568
912c912
<       memcpy (to, from, min (TYPE_LENGTH (from_type), TYPE_LENGTH (to_type)));
>       memcpy (to, from, fmin (TYPE_LENGTH (from_type), TYPE_LENGTH (to_type)));
diff -r ./cuda-gdb-9.0.176/gdb/libcudbg.c ../cuda-gdb-9.0.176/gdb/libcudbg.c
66c66
<     CUDBG_IPC_REQUEST((void *)&ipc_buf);
>     CUDBG_IPC_REQUEST((void **)&ipc_buf);
104c104
125c125
145c145
198c198
220c220
243c243
267c267
290c290
313c313
336c336
367c367
392c392
418c418
443c443
467c467
491c491
515c515
547c547
572c572
598c598
623c623
651c651
674c674
702c702
724c724
744c744
765c765
786c786
807c807
828c828
857c857
884c884
928c928
952c952
982c982
1046c1046
1069c1069
1090c1090
1111c1111
1149c1149
1172c1172
1195c1195
1219c1219
1244c1244
1269c1269
1297c1297
1320c1320
1344c1344
1371c1371
1391c1391
1420c1420
1441c1441
1472c1472
1511c1511
1534c1534
1556c1556
1577c1577
1597c1597
1626c1626
1649c1649
1672c1672
1694c1694
1718c1718
1742c1742
1764c1764
1790c1790
1816c1816
1843c1843
1864c1864
1887c1887
1908c1908
1930c1930
1951c1951
1975c1975
2001c2001
2021c2021
2045c2045
2070c2070
2091c2091
2115c2115
diff -r ./cuda-gdb-9.0.176/gdb/source.c ../cuda-gdb-9.0.176/gdb/source.c
673c673
<       lastsep = strrchr(s->filename, '/');
>       lastsep = (char *) strrchr(s->filename, '/');
What about CUDA 9.2?
Haven’t tried out CUDA 9.2 on MacOS High Sierra yet, but I would guess the status remains the same? In that case the above stated patches should apply as well. Checkout -> http://developer.download.nvidia.com/compute/cuda/opensource/
Hi, did anyone was able to install cuda-gdb for CUDA 9.2?
I have an error on the make step:
darwin-nat.c:2204:14: error: cannot initialize return object of type
‘enum target_xfer_status’ with an rvalue of type ‘LONGEST’ (aka ‘long’)
…darwin_xfer_siginfo (ops, object, annex, readbuf, writebuf, offset, len);
And how do you automatically apply the changes from the posted patch? (Sorry, I am newbie)
I’ve applied the changes to all these files manually (does anyone know how to do it automatically??)
I was not able to run ./configure with the options listed above.
After the following steps: ./configure -> make I got the following error:
ld: symbol(s) not found for architecture x86_64
clang: error: linker command failed with exit code 1 (use -v to see invocation)
Same here. We were using version 8 (which included it), but were forced to upgrade deepstream to version 3 and thus nsight with it. However, after using the patches above (quite time consuming), I am getting the same error as mr titan above…
It is sad. Not sure the reason for just removing things without so much as a heads up, but it is quite annoying how NVIDIA treats its customers. Thanks for the patch notes above, but no luck sadly.
If anyone knows or has direction, it would be appreciated, not like nvidia is going to help lol
Hi all,
Ok I will have another go at it with a more recent version of CUDA toolkit.
Any version in particular that is of more interest?
Now if just NVIDIA and Apple could get their stories straight… with MacOS 10.14 “Mojave” I no longer have CUDA support; neither for the dGPU 750M nor my external eGPU 1060 GTX.
Haha, yeah. I am not surprised. Too bad all of the things couldn’t play nicer together. But, thank you that would be awesome.
I tried your patches above on cuda version 10.1. Which, ‘seemed’ okay up until it went to do the final compile to make the cuda-gdb file, in which we got the above (still uncertain if its an osx toolchain issue, but been trying to see if i can compile it on ubuntu for darwin)
Although, TBH I’ve never used cuda on OSX, don’t really need to. We just use the OSX Nsight to connect to remote machines (far away) to build, debug, profile code against and the remote server listens, just use cuda-gdb on OSX to connect to that.
Anyway, it seems to be no trivial task so thank you.
Cheers
OK I managed to build the <<cuda-gdb-10.1.105.src.tar>> tarball with the above stated patches:
10.1 release
Portions Copyright (C) 2007-2018 NVIDIA Corporation
GNU gdb (GDB) 7.12
This GDB was configured as "x86_64-apple-darwin18.2.0".
(cuda-gdb) quit
Note that I had to add CXXFLAGS=’-I/usr/local/cuda/include’ (since cuda-gdb.c is building with g++ and is now looking for #include “cuda.h” when running ./configure:
./configure --program-prefix=cuda- --enable-cuda --enable-targets=x86_64-unknown-linux-gnu,m68k-unknown-linux-gnu CFLAGS='-I/usr/local/cuda/include -I/usr/local/cuda/extras/Debugger/include' CXXFLAGS='-I/usr/local/cuda/include' LIBS='-lpthread' LDFLAGS='-lpthread -framework IOKit -framework Security -framework CoreFoundation'
Please note that I used XCode_92 while building.
I’ll try to do some actual remote debugging towards a Ubuntu host and will let you know later how it works out!
Success!! Once I compiled the gdb binary I just copied it from the ./gdb src/target directory:
sudo cp ./gdb/gdb /Developer/NVIDIA/CUDA-10.1/bin/cuda-gdb
From there Nsight will be able to resolve the cuda-gdb binary required to do remote debugging:
Process /home/<yours_truly>/cuda-workspace/simpleCUBLAS/Debug/simpleCUBLAS created; pid = 4376
Listening on port 2345
Remote debugging from host 192.168.0.3
GPU Device 0: "GeForce GTX 1060 6GB" with compute capability 6.1
simpleCUBLAS test running..
simpleCUBLAS test passed.
Child exited with status 0
logout
Interesting… not seeing any of Mr linus.bjerstedt.blom comments any longer… oh NVIDIA…
Someone from NVIDIA needs to address this at some point. As it seems customers are being censored and left in the dark as to what is going on here. It is not the way “open-source” things work and extremely disrespectful to customers that use NVIDIA things. There is always another path with or without these things. Cheers.
